Question about Epson Stylus CX4800 All-In-One InkJet Printer
Replaced cartridge, unrecognized
Hi
I replaced low cartridges with Epson brand refills. Can no longer print anything. All three colours (from batch 6901MC1) show as out of ink.
Help!
  • coldgreen Jan 07, 2008
    Changing the 3 new cartridges with 3 different new cartridges works now. Appears it was the batch because not one of the 3 cartridges out of that batch ever worked. Will return to vendor.
Try removing the cartridges and unplug the printer.
Plug it back in and try to install the cartriges.
Posted on Dec 31, 2007
I replaced my tri colour cartridge on hp2540 and keep getting message i need to buy hp cartridge how do i get it to print
1) If you replaced it with a refilled cartridge you may need the "latest" version of the cartridge in order to print with refills. See this link for more information: Updated HP 61 301 122 and 802 Ink Cartridges
If this cartridge is from their monthly print program you will not be able to refill it and taking it out and replacing it in the same printer can also through an error code.
2) Have you tried turning off the printer, unplugging it "FROM THE WALL" for three minutes and replugging it back in and turning it back on?
3) If one or the other cartridges have electronic problems, it will not print.
4)If an update was done on your printer software? Sometimes this will not allow you to use anything but HP. However, sometimes if you use an genuine HP and then go back to the refill it will reset it and work again.
Hope this helps you to understand this printer cartridge.
Jan 15, 2015 | HP Office Equipment & Supplies
Why is power button light blinking green on Epson SX200 printer?
Regarding your recent inquiry about the Epson T071 ink cartridge error message ("Ink Light is red", "Cartridge Not Recognized", "Replace Cartridge", "Installed ink cartridge is expended." or similar cartridge/printer alert message) associated with your Epson SX200 printer, the cartridge probably has a mis-programmed smart chip...
NOTE: If you had the cartridge refilled, the cartridge chip must be reset. Re-programming, which typically yields a green light to show success, it does not always result in correct smart chip reprogramming. It is also possible they may have forgotten to re-program the ink cartridge. If a compatible/clone cartridge, it could be a reprogramming issue or defective chip (which is common). Or, such a failure could be an electrical failure of the ink cartridge itself*. Unfortunately there is nothing you can do from home....the chip(s) need to be re-programmed (at refiller) or replaced with a new cartridge from vendor.
*OTHER POSSIBLE CAUSES OF FAILURE:
Either the external chip or internal ink sensor is electrically bad (the internal ink sensor detects if cartridge is really out of ink). If you return the cartridge to your retail refiller and they re-program the cartridge(s) a 2nd time but the "replace cartridge" message, or similar blocking message persists, then this is the likely cause and the cartridge will need to be replaced with a new one.
1) Confirm if this is just a nuisance/annoyance alert (i.e. "non-genuine" cartridge ) vs. an actual 'unrecognized cartridge' alert (i.e. Red X's on printer display / Windows pop-up message). Please visit the following Inkjet411 support page which will help you delineate the difference: http://inkjet411.com/?page_id=73
2) On some Epson printer models you may need to scroll thru the menu options AT THE PRINTER'S CONTROL MENU (i.e. right arrow key) to help determine which specific ink cartridge is actually causing the 'Unrecognized Cartridge' error condition. On the other hand, for general 'non-genuine' cartridge alerts, typically you can bypass these errors by clicking thru the acknowledgement prompts or via the arrow keys: http://inkjet411.com/?page_id=1939
3) We suggest you remove all the ink cartridges, inspect the smart-chips condition (on rear side) and ensure there are no cuts/gashes or ink residue present on the micro-chip surfaces. To be sure we suggest you clean the micro-chip surfaces; click here to see 2 different pictures of this along with cleaning instructions: http://inkjet411.com/?page_id=1939
4) If the error continues (following ink tank re-programming a 2nd time), then we suggest you install a new genuine Epson ink cartridge into the printer to verify the permanent PRINTHEAD is functioning ok. Here is how the PRINTHEAD works: http://inkjet411.com/?page_id=2054
NOTE 2: Following refilled cartridge installation, your printer/computer may display an ink alert message such as "non-genuine cartridge" or "you have not installed genuine Epson ink cartridges" - these are COMPLETELY NORMAL alerts when using refilled ink cartridges. Press proceed/continue/accept/yes/OK to dismiss the prompt. In some cases you may have to scroll over using the arrow keys to dismiss the alerts. Additional alerts may be displayed the first time you go to print or copy - dismiss the alerts accordingly to resume normal print operations. For more information on Epson ink cartridge alert messages please visit: http://inkjet411.com/?page_id=1939
CAUTION: Be advised, the use of compatible/clone cartridges (i.e. sold thru the internet from overseas) are known to be problematic and may cause printer errors or permanent PRINTHEAD damage (especially for 3rd party inks which contain volatile organic compounds or VOCs). We do NOT suggest refilling these types of ink cartridges.....refilling of Epson original/genuine ink cartridges is only suggested!
Epson T068 thru T130 Ink Refilling Services & Additional Cautions: http://www.youtube.com/watch?v=Jp575rE9y0Q
NOTE 3: If, after replacing the cartridge(s), with brand new Epson Original ink cartridge(s), is the only solution which corrects the problem, then you likely have a defective cartridge (internal ink level monitoring circuit), unrelated to the refilled cartridges. If, after replacing the cartridge, or cartridges, with brand new Epson Original ink cartridges, does NOT correct the problem, then you may have a defective PRINTHEAD (i.e. permanent electrical sub-assembly which the cartridges plug into). For more information please visit our support page which explains the natural degradation of PRINTHEADs over time: http://inkjet411.com/?page_id=2934
For any additional questions please contact us directly: Inkjet411help@gmail.com
-Thank you
Sep 03, 2014 | Epson 20 Ink For Stylus S20 Sx100 Sx200...
My cyan colour is finished, i have to print a black colour documents, printer is not allowing to print, please help
switch to black and white on the printer settings.make sure ignore colour warnings are turned off
if that doesnt work youll need to replace the cyan,get it refilled for less or order online to reduce cost
Mar 07, 2011 | Epson Office Equipment & Supplies
I replaced all of the cartridges with Epson, but the black won't print. After some nozzle checks, black is getting low and STILL no black printing occurring... what going on? Now the other colors are...
Nozzle cleaning uses a lot of ink, that's probably why the other ink cartridges are registering low on ink. Are you using refilled cartridges or brand new? Also, have you had the cartridges for awhile? I've found that the nozzles can become clogged either from not using the printer for awhile or because it's a recycled cartridge that didn't have the nozzles cleaned before it was refilled. When that happens, unfortunately, sometimes it takes a lot of cleaning cycles before the printing comes back. Let me know more about the cartridges you have.
Mar 03, 2011 | Epson Stylus CX7400 AllinOne InkJet...
Printer ink cartridges contain ink but printer says not!
The chip on the cartridge tells the printer how much ink is left in the cartridge. If the chip says the cartridge is empty, it won't print no matter how much ink is left. That said I think you got refills that didn't get the chips reset or compatibles (non-Epson brand cartridge body) with poorly made chips that expired before they should have. You need to have all the cartridges installed with functioning chips to use your printer. You need to buy new cartridges of the ones your printer thinks are empty. I recommend Cartridge World for refills because they make a quality product that doesn't have these kind of "novice" refiller problems. I would never buy refills or compatibles off the internet because you get what you pay for.
Oct 26, 2009 | Epson Stylus DX4200 All-In-One InkJet...
Hi, I have an Epson DX4200 I run out of the three colours ink cartridges, but just put in a black cartridge and is not printing. As far as know, it should print black if my black ink is full, even if the...
I have an Epson color printer ,but not the same model. If any of the colors of ink or out it will not allow one to print anything until the cartrage is replaced. It is built that way to stop the ink for totally running out . I just read this in this months comsumers reports magizine. Sorry.
Dec 11, 2008 | Epson Office Equipment & Supplies
HP colour cartridge no. 22 won't print
if the test pages come out OK then the problem can not be the printer !!!!!!!
it must be from the application
Sep 04, 2008 | HP Color LaserJet 2600n Printer
Black Toner replaced
Replace Toner with gen cartridge.
Or Take cartridge back as faulty after checking that it was opened and installed correctly.
Check display on printer for indications that maybe it needs one of the 3 colour toners indicators are Y,C or M
K is black
Oct 20, 2007 | Epson Aculaser C1100 Printer
Epson Stylus CX4800 All-In-One InkJet Printer Logo
214 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
