Question about HP LaserJet 4L Printer
Hp 4l will not print
Paper runs through printer but comes out blank does this with test page and when I print from computer. I was having problems with it not wanting to take paper and now its doing this. I have tried to replace toner but still no luck.
  • Littleal Dec 31, 2007
    the transfer roller seems to be in the correct positionand it is a hp toner with plastic removed
  • F. Price Jan 06, 2009
    I have an HP 4L that I purchased in 1993. It always worked fine until this week. Now it will only print blank pages. I have replaced the toner cartridge, re-installed the print driver, air dusted and brushed the cartridge housing area, and carefully air dusted and brushed the mirror. Still getting blank pages. I saw a very old post on this thread (2004) where someone had the same problem and was able to fix it from advice he/she got here. However, I couldn't find the reply post that remedied the problem. Any help will be greatly appreciated.
Sounds like that Hi Voltage power supply is faulty. This power supply is responsible for the voltage that causes the toner powder to be attracted by the paper... no voltage, no image on the paper.
Posted on Mar 04, 2009
    Welcome Back:
    Visited the website for 2 consecutive days.
Sorry, but Solution #1 didn't help. I am using an HP original toner cartridge (tape removed) and as far as I can tell the transer roller seemes to be in the correct position. The roller has minimum play, a 16th of an inch left or right, and appears to have been designed that way.
Posted on Jan 07, 2009
  • 417 Answers
Just a silly question I take it you have removed the tape from the toner cartridge. Well do have to make sure of these things. It is possible that the transfer roller has come out of position to check it should be a black roller that sits under the toner cartridge when install. The roller is in the machine at all times. The other thing are you using HP originals cartridges as this could be a factor.
Hope this is some sort of help
please rate me
Cheers
J
Posted on Dec 31, 2007
PAPER FEEDS INTO PRINTER BUT COMES OUT BLANK
HP DeskJet f4280 Spitting Out Blank Paper. - HP Support ...
h30434.www3.hp.com > Printers & All-In-Ones > Print Issues
Solved: I can hear it printing, but the paper is blank when it's finished. ... Mark as New; Bookmark; Subscribe; Subscribe to RSS Feed · Highlight · Print · Report ... green checks say every thing is good to go, but the test print comes out blank,. ... Reinstall the cartridges into the product, and then gently close the cartridge door.
my printer is printing blank pages, and i just changed ink
Nov 18, 2015 | Office Equipment & Supplies
Won't print from computer
Try borrowing another suitable printer lead and test with that. If the printer can do a self test, it is likely the printer is not the problem. If that does not work, if you can, use another printer with your computer - but set it up first. Failing that come back for more help
Apr 21, 2014 | HP LaserJet 4L Printer
HP LaserJet 4L quit working It's connected to my PC and it's on. All 4 lights are on; 2 green and 2 orange. When I try to print, the paper goes through but nothing is printed on the paper.
Empty cartridge maybe?
Otherwise it's simple: selt-test page(by printer button) printed ok - it's outer problem. Self-page is blank - it's inner problem. And so on... use Golden Section method
Jan 10, 2014 | HP LaserJet 4L Printer
My hpf44880 printer prints out blank sheets of paper what do I need to do to get it to print with ink on the paper?
please follow these steps:
1.please print a test page from printer(hold down power and cancel(red X)buttons for 3 seconds together and release both of them..it will print a test page
2.if it is blank :please take out the cartridges.
clean the metallic contacts with lint free cloth
clean the ink cartridge slots with a cutip
disconnect usb cable
unplug the power cable from the back keeping cartridges out
hold down power key for 30 seconds
reconnect power cable
reinstall the cartridges
3.print a test page again from printer if printer is quiet
4.if the test page is still blank..u need another set of cartridges
5.if test page isn't blank and u print blank pages from computer,do the following:
6.if printer s/w is already installed..please go to devices and printers(printers and faxes in win xp)
7.please click on add a printer
8.select driver manufacturer as HP,and driver as deskjet 990c(this is the generic driver for all HP printers)
9.follow the onscreen instructions,and finish installation
10.try printing with this driver
Jan 24, 2011 | HP F4480 All-In-One Printer
Reading no paper paper tray is full
Instructions
  1. Check the display for an error message. If the display reads "Clearing paper from printer," the engine has detected a jam and is attempting to eject the jammed pages automatically. These pages will often be blank.
  2. Check the display for "Performing PRINT/STOP TEST" or "Performing SERVICE TEST." Either of these messages indicates that the printer is going through a test procedure that may eject blank pages.
  3. Reduce the amount of paper in the input tray if the printer is feeding multiple blank sheets at a time. The printer will pull extra pages through if the input tray is overfilled.
  4. Replace the paper in the input tray with the correct size if needed. If the 4600 printer detects the paper as an incorrect size for the print job, it may eject the paper without printing anything on it.
  5. Replace the ink cartridges if certain colors are blank on the page. Replace the black cartridge if printing a black text document that is coming out blank. The printer may attempt to print even if the ink level is low or empty, but will unable to print anything on the page, causing it to come out blank.
  6. Remove the sealing tape from newly installed cartridges. The tape covers the print heads and should be removed before installing the cartridges. If the tape is left on, it will prevent ink from getting on the pages as they print.
  7. Press the "Check mark" button on the control panel to enter the printer menu. Run a diagnostic so the printer can attempt to determine the cause of the blank pages printing. Press the up or down arrow to select "Diagnostics." Press the "Check mark" button. Press the "Down" arrow to highlight "PQ Troubleshooting." Press the "Check mark" button. The printer runs a diagnostic and returns to a ready state when done.
Jan 08, 2011 | HP LaserJet 4600 Printer
HP 920c Deskjet feeds blank paper constantly. Will not print. Just shoots paper out.
deskjet 920c will not print, green light flashes and blank paper comes out. Printer will print test page perfectly.
Nov 07, 2009 | HP DeskJet 920c InkJet Printer
HP laserjet 4L paper jam after printing one page.
You need the pick up rollers replaced. Call your service centre to replace pick rollers as these are feeding the pages crocked
Aug 31, 2009 | HP LaserJet 4L Printer
HP laserjet 4L wont print from computer
reinstall the printer driver.
Windows operting system have the printer drivers. you don't need to download it.
if you really want to, goto HP.com>> service and support.
Oct 21, 2008 | HP LaserJet 4L Printer
HP Laser Jet 4L Printer Model #C2003
Try lowering the toner density using the printing software or the printer menu.
Feb 03, 2008 | HP LaserJet 4L Printer
HP LaserJet 3550 spits out blank paper when job sent from computer but prints fine when printing directly from printer
Try connecting the printer via the USB port on either one of the computers. Then test if the machine prints fine then likely possibility is that the Network interface card is faulty remove the network card and install in a different slot and test. If the same thing happens then reinstall the drivers and test.
Hope this helps
Thanks J
Jan 27, 2008 | HP Color LaserJet 3500 Printer
HP LaserJet 4L Printer Logo
121 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
