I have a lg 42pc3dv plasma tv. it made a loud pop and picture went out. Sound is good. Can you help in letting me know what to test and what the reading should be. I am very mechanical. Work as a tech for Audi Porsche.
Looking at it from the back, the board on the left is the ysus. You should see a big red cable coming from the power supply board in the middle of the set going to the ysus. Near the red cable plug on the ysus should be a fuse. Most likely the fuse has blown. If it is you need a ysus PCB. Check out encompassparts.com. If you get a new board be sure to set all the controls on the new board to match the old board. If you don't you will have little sparkles all over the screen when it comes back on. I hope this helps. You may want to check all fuses on the power supply and the zsus which is on the right side of the set. I have seen both the ysus and zsus be bad together. Good luck and thanks.
