Question about Kyocera Mita FS-1920 Laser Printer
Printing problems when i print out of the Kyocera FS-1920 printer it prints out a black line down the left hand side of the paper, how do i get rid of the line
  • Anonymous May 19, 2008
    I have a problem with Koyocera fs 1920 prints a line in the middle of the page. How do I fix this?
    Olga:0
  • 417 Answers
Hi there check that it isn't the drum unit by turning the machine off open the top cover remove the toner and underneath you will have the dev unit unplug and lift out then remove the transfer tray (the one you open if there is a jam) open side door remove waste tank then you have the drum unit now to remove there is either a push button or a screw do either one that corresponds and check the unit. If there is a black line on one side the only way to get rid of the line is to replace the cleaning blade as this has worn. you can clean the drum unit cleaning blade it may only be toner stuck under the blade all you have to do is rotate the drum the opposite way of operation and if you have to hand a air line just give it a blast failing this it will defently need replacing.
Hope this is of some help
Please rate me
Cheers J
Posted on Dec 31, 2007
When cleaning the wire, ensure you use the grid cleaner supplied with new toner cartridges. The wire runs over the moist pad. I cleans it up a treat
Posted on Mar 20, 2008
  • Kyocera Mita Master
  • 1,113 Answers
Cause your an Aussie..
Try cleaning carona wire, if not it can also be the drum (cleaning blade wears out)- replace drum unit
or it can be the fuser (hot bit at rear)
To check if drum or fuser, you stop a print about mid way and see if line is present before paper reach's the fuser.
If brave you can pull out the drum, remove toner then unplug dev unit (plug on left) unclick lock (grey tab) dev unit lifts out, then pull out cassette, then green handle slide process unit open, then left cover remove waste bottle, grey button press slide out drum, DONT touch it or leave in light, you should see your line on drum.
HOW to clean carona
Kyocera FS-1020D starts print 1/2 way down page
Internal tests like Report Prints are printed correctly? Make sure the Paper Size Format is setted correctly both on PC and Printer. Try not to use a Generic or Universal Printer Driver. Try installing printer with an Windows Vista driver if the Win7 and 8 drivers won't solve the problem.
Jan 22, 2015 | Kyocera Office Equipment & Supplies
My printer has started printing a black line down the edge of the paper?
Remove the laser print cartridge, shake it lightly, and place it back into your printer. That should solve the problem.
Mar 15, 2013 | Kyocera FS-1030D Laser Printer
Kyocera fs 1920 installed on windows 7 64 bit cassette 2 not showing
Download the KPDL drivers and after they are installed go to the printer properties, then device settings and select how many paper feeders you have "in addition" do the 1st tray. So if you have two trays just pick "one" for that option. Then you will be able to scroll back up and choose what paper type it is.
Lastly, set your Printing Preferences in the properties if you want to specify a specific tray/cassette to print from or just let the printer auto select.
Jul 27, 2012 | Kyocera Mita FS-1920 Laser Printer
My printer is flaking. i am printing a heavy color image on a kyocera fs c8026n. any help?
If by "flaking" you mean that the print is rubbing or flaking off then there are 2 possibilities. If you are using thicker than standard 20lb bond paper then when setting up the print job make sure you are selecting thick paper on your paper setting. This is a common problem if your paper is thicker, shiny or anything other than standard.
The other possibility would be a fuser defect of some type. But that would tend to affect standard black and white prints as well.
Try the thick paper setting as it will slow down the paper speed thru the fuser and will "fix" the toner to the paper better.
Jan 15, 2010 | Kyocera FS-C8026N Laser Printer
Printing all pages as black
Open up the left side door and push in all of the chargers to make sure they are seated.
Jan 17, 2009 | Kyocera FS-C5015N Laser Printer
Network printing ok but word documents,e-mails etc problem
please make sure that the printer properties and printing preferences (right click the printer in the printer(&faxes) folder the paper sizes are set to match the printer,
then make sure that the documents you are printing are the same size.
on the kyocera printers you can also set a setting to override A4/LT
press: MENU, SCROLL DOWN, PAPER HANDLING > SCROLL DOWN, OVER RIDE A4/LT > ON, ENTER.
hope this helps.
Dec 15, 2008 | Kyocera Mita FS-1920 Laser Printer
Kyocera FS-1920 error message: "call service 6400:0295998"
Your drum unit is not seated correctly. Look inside for a bent drum ground clip.
Oct 19, 2008 | Kyocera Mita FS-1920 Laser Printer
Kyocera FS-C5016N
when you open the left cover you will see some green plastic things. If you pull these towards the left they will clean print heads and charge coronas.
If this does not fix the problem the you will have to remove the dev and drum units from the machine.
The print head sits on top of the drum unit and can be levered off with the three tabs gently lifted.
the entire print head can be remove once the black cover has been unhitched from the sides.
The print heads are not screwed in and what ever you do DO NOT TOUCH THE SCREWS on the print heads as they are only for density adjustment
Aug 08, 2008 | Kyocera Mita FS-C5016N Printer
Problems with Kyocera Mita FS-1920
Make sure that your paper sizes match in the control panel of the printer in Windows. It will not only cause the duplex not to work but could cause jamming problems as well. When printing in duplex mode, make sure it is turned on.
Jul 23, 2008 | Kyocera Mita FS-1920 Laser Printer
Kyocera Mita FS-1920 Laser Printer Logo
477 people viewed this question
Top Kyocera Mita Office Equipment & Supplies Experts
Adorjani Laszlo
AAAA262430
Marvin
Marvin
Are you a Kyocera Mita Office Equipment and Supply Expert? Answer questions, earn points and help others
