your main power assembly has blown a heat sink
the board runs around 2-300 and unless your very good with electronics, I would call a repait man...
Check your labor costs and add that to board cost
if you look around you might find a good guy that can get it done in just a few minuts and less than a hundred.. I live in Mass and 79.00 is my hourly labor for this repair..
blue convergence "+" in menu won't move vertically. red moves fine, blue moves...
(More)
blue convergence "+" in menu won't move vertically. red moves fine, blue moves horizontally. What do I do, we can't watch the tv at all?
i have a mitsubishi vs- 45609 projection t.v. it will not come on... there is power at the outlet...
(More)
i have a mitsubishi vs- 45609 projection t.v. it will not come on... there is power at the outlet but when i plug in the tv and hit the ppwer button nothing happens.no lights no noise.nada.can you tell me whats wrong???
My mitsubishi 45609 will not work with the cable connected. White noise. It acts as if the tuner is...
(More)
My mitsubishi 45609 will not work with the cable connected. White noise. It acts as if the tuner is bad. The a/v inputs work fine but not the cable input. I checked the cable with another TV and set the input to cable. Are there any fuses that could be bad?
