Question about Coleman Propane Forced Air Heater w/Electronic Ignition (50,000-80,000 BTU)
Jumpstarter I want to know if you can buy the dcor ac cord for a pmj8160 and if I can get the manual on line
  • pwood7152 Jan 01, 2008
    The problem I am having is can I buy a dc cord and a ac cord for my pmj8160. And can I get the manual for my pmj8160
  • bg77 Sep 18, 2008
    I lost the AC charger for the unit. The manufacturer is out of business. The manual gives no details about the charger other than to say it is 12V.
    Problem Solver:
  • 18 Answers
Call the company that made it knucklehead
Posted on Jan 04, 2008
What does it mean FL on a Peak jumpstarter 900
read this
When the Jump-Starter is fully charged, the display will read FL. Disconnect the AC extension cord from the 110/120-volt AC outlet, and then disconnect it from the Jump-Starter AC charging
Amazon com Questions And Answers What does blinking FL means while...
Your manual is here
http://peakauto.com/wp-content/uploads/2017/01/Autotek-JS-PKC0AZ-Manual-031014.pdf
Mar 23, 2017 | Washing Machines
Sony Trinotron TV:
You must remove cover. Follo AC line cord inside . its not difficult
Apr 04, 2008 | Sony FD Trinitron WEGA KV-27FS100 27" TV
How do I recharge a Motor Trend jump starter
Get a recharge cord for the unit, plug it in and recharge.
Jun 28, 2014 | Power Center Jumpstart 11-411
I own a Vector Industrial Series 900 to jumpstart system and power. When we recently moved the cord was lost and now I am in need of buying the new cord. Is this availale?
I advise caution when using a standard battery charger to charge a jumpstarter via the main leads. Firstly if there is polarity protection it probably won't work and secondly the heart of the jumpstarter is a sealed lead acid battery which does not usually tolerate high charge currents without shortening the life of the battery.
This type of battery needs either the low charge current supplied by the original charger or similar or a sophisticated regulated charger.
If using a standard charger avoid using a high performance type and use only the type that provides a trickle charge.
Apr 07, 2014 | JUMP START SYSTEM
I need to buy a power cord for the 11-410
just make sure the specs for the replacement plug is correct:
AC ADAPTER
input: 110-115V 60Hz
output: 12V 500mA
pin size that plugs into the unit ~ 9mm or a bit tad over 3/16"
with that adaptor, it takes up to 36 hours to charge it up to FULL
with a comparable DC adapter, it takes only 8-10 hours
Dec 17, 2012 | Power Center Jumpstart 11-411
West Marine Seavolt Jumpstart 400 Mk2 Owners Manual
I need power cord for jumpstart 400mk2. What is the voltage, amps and + ok -? Thanks Laurie
Sep 29, 2011 | Cars & Trucks
I need to buy a power cord for the 11-410 Jumpstart w/ Compressor. How/where do I do that?
This item appears to have a DC input jack on the front. Bring it to your local Radioshack and they can get you a replacement adapter with the right plug and voltage.
Feb 26, 2010 | Power Center Jumpstart 11-411
Will not jumpstart
To recharge this unit at home use the AC charging adapter. Plug one end of the adapter into the AC/DC charger input port. Which is marked as number 7 on the image below. Then plug the other end of the adapter into a standard wall outlet. The charging port is located on the front of your power center and looks like the image below. If you did not get an AC charging adapter with your power center check the manual to see exactly what type you need. You will need to know the Voltage and AMPs of the adapter. Go to Radio Shack or an electronics store and purchase an adapter. It is very important that you make sure you get the right one. Your manual should tell you how many hours it takes to completely charge your power center.
Mar 13, 2009 | Power Center Jumpstart 11-411
Heating & Cooling Logo
349 people viewed this question
Top Coleman Heating & Cooling Experts
Bill Long
Paul Carew
Dan Webster
Dan Webster
Are you a Coleman Heating and Cooling Expert? Answer questions, earn points and help others
