Front loader washing machines
Our child overloaded the washingmachine and now all we get is an error code of E3 can anyone tell me what it is so we can fix it
  • donk382 Aug 02, 2008
    Machine has worked well for over a year but now after it starts the E3 code appears and the machine stops. The manual suggested that there may be a loose wire. I checked the motor connections and actually thought for a minute that i had corrected it but no luck. Any ideas?
  • Anonymous Mar 29, 2014
    Overloaded machine and it has tripped out
  • 1,314 Answers
Need to know the brand
Posted on Dec 31, 2007
What does the E3 code mean on the 540 model and is there a fix?
Troubleshooting the "E3" error code in Maytag MAH6700 ...
Feb 20, 2011 - These codes in your (made-by-Samsung) Maytag washer might pop up during the ... In fact, the E3 error code means that the Machine Control wants to make the motor spin but won't do it because it's getting a weird reading from the tachometer.... MAH6700 and MAH8700 models (they use the same motor).
I have a samsung frontload washing machine. A code E3 is ... > Denise LaGrasse > Questions
Mar 15, 2014 - My samsung front loader is not working. do not no what E3 means. ...code F26 mean on a Kenmore Elite model 110.4708 washing machine?
How To Fix 3E Error Code On A Samsung Washing Machine
May 15, 2015 - Samsung uses the 3E error code to indicate a drive motor tach fault. ...If you're handy, you can fix your Samsung front load washing machine error code ....My samsung frontload washer shows e3 and the drum does not turn ...
Jan 06, 2016 | Washing Machines
Transmission or clutch assembly not engaging due to going out or slipping. even bad door switch
Sep 20, 2014 | Maytag Washing Machines
Washing machine cannot dry spin. error code E3
Can you verify the make and modle of your washing machine. Is it a top loader or front loader.
Sep 02, 2011 | Washing Machines
Maytag laundry neptune front loader washer MAH6700AWW. It is showing a E3 code error. what can we do for that
Hi, the E3 error means that the control board is detecting current going to the motor, but the motor won't turn properly. If the error code comes up all the time as soon as you press the power on button, then it means your control board is bad and reading incorrectly. If it only happens during a cycle, then you need a new motor unfortunately.
Jun 16, 2011 | Maytag MAH6700AWW Neptune Front-Load...
What is error code CL on my LG front loader?
LG washing machines indicating error code CL may have the child lock activated. Try holding down the temperature and eco/rapid options together to turn off child lock.
Nov 28, 2010 | LG WM0642H
We get an e3 error message and we have no idea what that means. The machine will start but then at some point it simply stops. we have been able to use the rinse and spin cycles to get the water out of the...
It's an over load error. Don't put alot of laundry in the drum.
Copy and Paste from the service manual
- Motor overloaded due to too much laundry (Nonsensing)
- The motor hall sensor terminal is not connected.
- PBA fault
- The motor driving error from the PBA is weak.
: Unstable relay operation, etc.
This error
occurs when an
interference is
generated due
to too much
laundry, etc.
Dec 28, 2009 | Samsung WF337AA Front Load Washer
We are getting error code E3. What does this mean
Looks like you have either a stuck drum (does not spin) or an electrical fault that make the washer think the drum is not moving.
From a 2006 Technical Bulletin:
E3: Machine control is attempting to drive the motor but is not seeing any tach response. Visual Check shows motor is not moving. (Locked or Hall Sensor fault.)
Specifically, it could be:
1. Spin drum stuck – Verify that the spinner moves freely to eliminate this cause.
2. Hall Sensor (integral part of motor) fails or is loose – When the Hall Sensor fails or becomes dislodged, the control doesn't recognize that the motor is spinning and shuts down. The result will likely be an “E3” code in the worst case, or “SUdS” if it is only getting a partial rpm reading. Check wire harness connector(s) to motor.
Unless you are really overloading your machine you likely have an electrical fault, or a failure in the drive train--especially if the problem is intermittent. Probably time to call in a technician.
Aug 13, 2009 | Maytag Neptune MAH9700 Front Load Washer
E3 error code will not wash, what does this error code mean?
i have a maytag washer and it says E3 and it will not work,does anyone know what that means please let me know...thanks
Apr 18, 2009 | Maytag Neptune MAH5500B Front Load Washer
My LG WD-1023C Automatic Front Loader Washing Machine is displaying a CL error code and will not turn on.
it could be that your machine has been child locked, look in yor manual it will tell you how to fix it, this happened to me , hope this heps you good luck
Sep 11, 2008 | Washing Machines
Bosch washer error code e3 what does it mean?
Error "E3" on a Bosch front loader means there is a problem with the door. Either it is not closed properly (user error or a blockage) or the locking mechanism has a fault. Check to see that there is no object shoved in the latch hole (our 2yo just did that) preventing the door from closing properly. If it is not that, a technician is advised. I tried to get into the machine to fix out issue but could not get to where the issue is.
Aug 02, 2008 | Bosch Washing Machines
Washing Machines Logo
143 people viewed this question
Top Washing Machines Experts
