without a complete voltage check
i cannot be 100 percent sure
and i would not reccommedf you going in unless your comfortable arounf HV
but it sounds like a heat sink on the control board
even at the risk of a bad rating
blue convergence "+" in menu won't move vertically. red moves fine, blue moves...
(More)
blue convergence "+" in menu won't move vertically. red moves fine, blue moves horizontally. What do I do, we can't watch the tv at all?
i have a mitsubishi vs- 45609 projection t.v. it will not come on... there is power at the outlet...
(More)
i have a mitsubishi vs- 45609 projection t.v. it will not come on... there is power at the outlet but when i plug in the tv and hit the ppwer button nothing happens.no lights no noise.nada.can you tell me whats wrong???
My mitsubishi 45609 will not work with the cable connected. White noise. It acts as if the tuner is...
(More)
My mitsubishi 45609 will not work with the cable connected. White noise. It acts as if the tuner is bad. The a/v inputs work fine but not the cable input. I checked the cable with another TV and set the input to cable. Are there any fuses that could be bad?
