Question about Onkyo TX-SR575 Receiver
Everything works but the subwoofer
I just bought the TX-SR575 and hooked it up. Everything is working great except the subwoofer. I am using the same cables that I used with my old reciever. The sub worked just fine with the old one?
  • 45 Answers
SOURCE: No power!
okay, this seems like either the fuse hase blown in the actual mains plug, or the mass fuse inside the device, it looks like this very small glass fuse, same size as an ordinary fuse, its just seethrough. see if you can get a replacement for it, you may need 2 open the unit to check if it has blown, it will be black or a "burnt" colour from inside! if you dont want to open it, take it to any electronics store, they are bound to check for you, but these fuses don't cost more that $1 or 50pence!
hope this helps
Posted on Dec 22, 2007
  • 7 Answers
SOURCE: Subwoofer jack not working
Try using another cable. Such as a spare Component cable. As a general rule if the cable is large in diameter it will do the job. You dont have to buy a Woofer cable specifically, as stated above a Component cable will be more than enough.
Posted on Feb 04, 2008
SOURCE: jvc home stereo subwoofer
please sent the circuit of STK subwoofar system
Posted on May 16, 2008
SOURCE: Barely hear subwoofer
I had the same problem initially, but going through the auto speaker setup, the receiver boosted output to the subwoofer to compensate. Seems ok now.
Posted on May 31, 2008
SOURCE: hooking up a Klipsch
Need to confirm that you have a subwoofer cable which is a coax cable. I have seen this sort of issue when using a standard RCA cable. If you need a cable you can order it at
Good luck..
Posted on Nov 25, 2008
Tx-sr575 7.1 - is there any use in connecting and old power amp and equalizer to this receiver? If so, how?
Ya mean like to hook up Bose 901's? Nevermind.
Utility is in the imagination of the dreamer.
Any analog processor can occupy the Tape Out/In loop. However, it will only affect stereo analog sources and, once engaged to monitor, it will disable any digital audio source.
An external amp COULD be slaved off the tape Out (or the anticipated EQ Out, but it won't be volume-controlled by the Onkyo. You would need an AVR with at least Front L/R pre-outs.
Aug 12, 2011 | Onkyo TX-SR575 Receiver
I have just tried to plug in a microphone on my TX-SR575 and now we can't get any sounds whatsoever.. PLEASE HELP!!!
Please tell us WHERE you attempted to get a mic to work on this unit. It might shed some light on what got blown up.
Mar 05, 2011 | Onkyo TX-SR575 Receiver
When i load a purchased cd everything works fine except there isnt any sound. The radio works great
Does it work for regular CD's?
If you have an amplified system, you may have the wrong wires hooked up for the "remote".
Swap power antenna and remote blue wires and it should fix the problem.
Feb 28, 2011 | Car Audio & Video
How to hook up my subwoofer
It sounds like you're doing everything right. Did you define the sub to the Onkyo (Subwoofer = Yes, page 22)?
Let's prove the sub works. Set its volume about half-way, cutoff= 170Hz. Temporarily connect an RCA cable from its Line Input to one of the Tape Out connectors on the Onkyo and play some FM through it. If it's alive you'll hear the low end of the music.
Don't buy into the hype that there are different pedigrees of RCA (or speaker) cables that will make an audible difference. Save your money.
May 04, 2010 | Onkyo TX-DS696 Receiver
SR573... Does it support NTSC/PAL?.
There's no mention of either NTSC or PAL in any spec sheet.
This link leads to Onkyo and the rear view of the amp lacks the voltage selector.
The manual for the similar model SR575 says the North American model does not have the voltage selector. Too bad. Under the general specs for the variants of this family of receivers they list the following power specs. I have no idea where you have to go to buy one from the "Others" group.
Power Supply North American: AC 120 V, 60 Hz
European: AC 230 V, 50 Hz
Others: AC 120/220-240 V, 50/60 Hz
AC 220 V, 50/60 Hz
Some aliases for the SR575=
You could do what I did over 30 years ago. Join the Army, go overseas and buy one in the PX. Every HiFi product we bought in the PX in the 70's had the dual voltage feature.
Apr 07, 2009 | Onkyo TX-SR573 Receiver
Program Time Warner Remote RT-U62CP-1.17 to work ONKYO TX-SR575
i bot a new tv i don't have the book for the time warner remote so i don't know how to program it to work the tv it only works cable box
where can i find how to program remote that comes with time warner cable
Dec 26, 2008 | Onkyo TX-SR573 Receiver
Hooking up a Klipsch
Good luck..
Nov 25, 2008 | Audio Players & Recorders
Onkyo TX-SR575 I bought this unit at a flea market. Comes with everything including the manual except for the remote control. Manual is somewhat difficutl to understand. Stand by red light keeps...
The unit is in protect mode. The outputs are fried in all likelyhood. This can be repaired. Figure on $5-$15 for parts plus the local labor rate for the total repair cost.
May 21, 2008 | Onkyo Audio Players & Recorders
Hooking up ps3
Check system in TV Format Setup:
Dec 28, 2007 | Onkyo TX-SR803 Receiver
Onkyo TX-SR575 Receiver Logo
18 people viewed this question
Top Onkyo Audio Players & Recorders Experts
Are you an Onkyo Audio Player and Recorder Expert? Answer questions, earn points and help others
