McCulloch EB358A starts but acts like it is running out of gas
McCulloch EB358A starts good but acts like it is running out of gas.Have replaced filter.If you push the primer bulb it will pick up rpms and hold untill you let off the throttle.
Re: McCulloch EB358A starts but acts like it is running...
Ok you have what sounds to me a blockage in the carb. take it off and thouroughlly clean it. check the diaframs in the carb to see if they are hard and stiff. if they are hard and stiff replace them and clean the carb really well and see if this works.
McCulloch u spray starter fluid Power Generators Questions ...
www.fixya.com > Forum > Tags > u spray starter fluid > Power Generators
McCulloch power generators u spray starter fluid related questions and ... Question about 13HP 338 Cc Portable Generator # FG6000MK ... My 5700 watt 11 HPMcCullough generator wont ... My generator will start if I spray it with either but won'tstay running in less I keep ... The bowl has gas in it and the needle is clean.
Jan 13, 2011 - this generator McCulloch fg6000mk 11hp has no spark. I've checked the gas bowl , a small amount of water in the - McCulloch ... water in the bowl not much also sprayed a small amount of starting fluid in .... My 5700 watt 11 HPMcCullough generator wont start. I'm getting good gas to the plug but no spark.
Dec 2, 2008 - Question about McCulloch 13HP 338 Cc Portable Generator # ...evaporated. you might tryt a little spray starter fluid in the spark plug ... My generatorwill start if I spray it with either but won't stay running in ... The bowl has gas in it and the needle is clean. ... My 5700 watt 11 HP McCullough generator wont.
Its either sucking air in throgh a loose connection in the fuel line or the carb is stopped up. Take it apart very easy so you don't rip any gaskets, and clean evertthing with a can of compressed air blow all the tubes out real good. You may have to get a carb kit it that does not work.
But that sounds like what it is, running out of gas when you let more air to it.
Don't think you mean electric..Anyhow when adding gas for the first time start after 20years, add a pint of oil to gallon of gas. If it turns over and starts, then you can lean it down later. Google for spark plug or go to manufacturers site. good luck
ArboristSite.com Chainsaw thread (free to join) http://www.arboristsite.com/forumdisplay.php?f=9
There is some discussion about the proceedure in the McCulloch thread. Its a good little saw. I'm awaiting oiler parts on mine. HTH
Lou
I don't think I can help, but normal starting procedure for me is to put choke on, pull on recoil until it kicks over once. shut off choke and restart. Sounds like you have fixed almost everything & adjusted mag right. Rick
Found all the mcculloch manuals you could ever want on mcculloch product information site. Its run by mcculloch an you put the product weather chainsaw or strimmer whatever an the type in the next collum an press download then print it off all very easy. My manual was in german so made up i found stumbled on this.
