Question about DVD & Blu-Ray Players
Song wega kd32fs170 has sound but no image
0 characters
1 Points
Sony CD Walkman D-EJO11
Laser pickup unit fault. Contact any service technician. Gopakumar Gopalan Google
Mar 07, 2014 | Sony DVD & Blu-Ray Players
How do I hook up my new HT-X50 home theater system to my Verizon HD "Motorola" cable box that my sony wega hd tv is hooked up to, so I can get tv shows and dvds to work with my home theater...
Hi evilfan,
If I may add to the postings of Ekse and TampaNative......
Depending on what available cables and connectors that you may have the basic idea is from the cable company in to your Motorola receiver then to your Samsung HT-X50 then to the Sony Wega as below image shows. All other additional devices such as another DVD player or an iPod Nano with Video Dock or anything else would have to be connected to the Samsung.
All external devices would have to be plug in the the different INPUTs as you may decide which is to which. What is important to remember is that everything goes through the Samsung be it incoming or outputs.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Mar 18, 2008 | DVD & Blu-Ray Players
When playing a CD the player will play the first 20 seconds of a song, then skip to the next song and then 20 seconds of that song, etc. I don't see any menu setting regarding any kind of skip feature,...
Tries it with other audio CD,if it have the same problems.Than the DVD player have a dirty laser eye scaner reader.Tries websites like, to buy a DVD player laser eye cleaner kit disc.
Dec 03, 2010 | Sony SLV-D300P DVD Player/VCR
Blu Ray player turns on, displays "Welcome on the screen. After disc is inserted, "Wait" appears on the the screen and then it freezes. What is wrong?
This sounds like your Sony player is not reading the disc.
I have bought faulty DVD discs before that have given this same fault!
- I assume you have tried a disc that you know works in another DVD player?
Remember, your Sony Blu-Ray should be able to play ALL REGIONS of standard format DVD discs, so you should get sound & images from any one you choose.
Nov 06, 2009 | Sony BDP-S350 Blu-Ray Player
No Picture on HDMI using Philips DVP5992.
You can try out by connecting the CVBS (Yello) out from player to TV and connect HDMI out from Player to TV. Goto CVBS input on Sony TV. Select set up and you should get the HDMI Video options availble. Try to change the resulution and check for Video on HDMI source.
Which disc you were playing PAL or NTSC? PAL should work for Europe.
Feb 08, 2009 | Philips DVP5990 DVD Player
Connecting and recording sony hdtv, rdr-hx780 recorder,sony dream system
I have the same system, except for the TV, I have a project (that part doesn't matter).
From your Sat. go straight to your AV receiver
Again from you Sat. (all of the AV outputs are all live), go out from either 1 or 2 and go to your recorder Line 1 in.
From you AV receiver go to your TV.
All you have to do is hit record and you will record whichever channel you are on. I am having difficulty getting it set up as a PVR, but will figure it out sooner or later.
Hope this helped.
Oct 20, 2008 | Sony RDR-GX300 DVD Recorder
VCR not recording higher-numbered channels
Yes coming in her VCR with Cable or ant, if she has satellite it would be different. Going out to tv from VCR. Then in is Input the Out is Output. RF cable connection or A/V inputs(jacks) either one same way of hookup.
Sep 15, 2007 | Zenith XBV442 DVD Player/VCR
DVD & Blu-Ray Players Logo
20 people viewed this question
Top DVD & Blu-Ray Players Experts
Are you a DVD and Blu-Ray Player Expert? Answer questions, earn points and help others
