Question about Sony PlayStation Portable (PSP) Console
After starting a game, not able to control the game. Forward joystick doesn't respond and game gets stuck? It is happening with all the games.
  • Sony Master
  • 441 Answers
It is more than likely a problem with the Analog Joystick Assembly. This is a pretty common part to wear out in the PSPs, especially the earlier models. The following website sells them joystick assemblies for $14.95 for the 1001 PSP and a little more for the newer models. You can find the model number of your PSP on a label inside the back of the PSP if you remove the battery.
http://store.richspsxparts.com/pspanstasre.html
Posted on Oct 24, 2009
SOURCE:
My ps2 joystick L3 button stuck when i derict it to any direction .. it suppose to back into its center position but it doesn't it stuck and still unmoved untill i move it back to its original pos
I would suggest buying a new controller if you want to skip the hassle of trying to fix this one, but if you insist on keeping this controller, then there could be a way to fix it. First try your best to smoothly trace the joystick around in a circle, and see if that unsticks it. If this doesn't work, apart from buying a new controller the only other thing to do would be to open the controller up and put lubricant on the bottom of the joystick, this will most likely work, but you might damage your controller in the process.
Oct 11, 2012 | Sony PS2 Dual Shock 2 Controller...
My joystick doesn't works in god of war 2 in pc game
Check the settings of joystick in game controller and god of war 2 setting (in game). check them this solution is for joystick not working on in a particular game.
Aug 20, 2012 | Electric Toys
I have the heavy gear . i've changed my joystick, but the game doesn, recognize the new one
In Windows 7, Go to "Game Controllers" in your control panel, select your joystick from the list, click "Advanced," and under "Preferred Device" select your joystick from the dropdown menu.
It worked for me with my MS Sidewinder FF2 and Windows 7. BTW, SloMo is highly recommended to play Heavy Gear 1, as otherwise your gear will run in place in the game because it's running too fast.
Feb 27, 2011 | Activision Heavy Gear for Windows
Right joystick works fine going left to right, but is very sluggish moving up and down, and occasionally doesn't respond at all
1-try rettting game's control layout back to default...you might have changed the layout 2-is this problem happening in other games as well? if it does, then we can consider taking the controller for repair 3-there is always ebay and amazon to get you a new controller 4-do you have a wireless or usb adapter to connect the xbox controller to the pc? in windows 7 you can use the gamepad as a gamepad and in "callibration settings" you can test the buttons
game on!
Feb 24, 2011 | Microsoft Xbox 360 Controller
Genius MaxFighter F-16U ... When i get into ANY game with Joystic support .. Jet fighters and etc ... I Pull the joystic and it wont pitch ...also it cant go right when i pull the stick to the right . ...
Hi, When you set your joystick up using the in game controlls menu try this. Try setting the controls from the bottom up I will try to explain. Lets say in the controls menu from the top it starts like this> 1)Pitch forward 2)Pitch backward 3)Roll right 4)Roll left. Start with pitch backward and pull the joystick back, It should auto input the pitch forward control. Next you would move on to roll left, It should auto input the roll right control. Get what im saying, You should only have to input one direction the other should auto input. Had the same problem with my LG extreme pro for BF2. Hope this helps good luck!
Jan 04, 2011 | Genius MaxFighter F-16U. USB PC Joystick...
My psp joystick is having a problem.... the guy in the game is still going foward, but im not controlling it...even if i do it will still run foward it happen to my old psp before and then i threw it in...
dont throw this one in the trash. your analog stick on the psp is stuck in the forward position. just take your analog stick off and replace it to where it is centered.
Dec 14, 2009 | Video Game Consoles & Games
Ps2 controller lights up on analog but doesnt respond
u might could take it apart and where the joysticks is bend it the direction it is jerking.
the other that will light up could have a short so you could try to find and rewire it or check the conections in the remote.
Aug 22, 2009 | Video Game Consoles & Games
PS2 Controller Joystick Problem During Gameplay
If you've had the controller a long time weird things can start happenning. Usually the pads on the joysticks go first.
Try a different joystick(borrow a friends) and if it still happens you'll know its not the controller.Could be a glitch in the software of the game.
Eliminate each area. If a friend has the same game use their disc to try your controller with.
Take your controller to the video game store ask them to try it out on their game display models.If it's "busticated" you can buy a new one right away LOL.
Aug 03, 2009 | Sony PS2 Dual Shock 2 Controller...
Ps2 joystick or ports problem.
Maybe you need a new controller that happend to me one time.
Mar 28, 2009 | Sony PS2 Dual Shock 2 Controller...
Sony PlayStation Portable (PSP) Console Logo
96 people viewed this question
Top Sony Video Game Consoles & Games Experts
Ekse
shevantha perera
Damen Wong
Damen Wong
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
