SOURCE: I can't get on the
Yes, on the very front, from the left you will see a speaker, a button for bluetooth, next button is wireless enable/disable, then power indicator, battery indicator. For a visual, see page 22 of your user manual at the link below:
http://www.acerpanam.com/synapse/data/7117/documents/TM4200-ENG-OLM_1207.pdf
SOURCE: When I use Function to turn on my wireless
does that light has the wireless icon as well? if it does then you don't need to use the Function to turn your wireless on when that light in lit up... having it lit means the wireless is on...
SOURCE: All of a sudden I can't connect wirelessly to the
It is probably in the software. Typically you can go into the control panel and find the wireless icon. Within it will be a button to click on to turn the radio on.
SOMETIMES there is a physical button usually on the front or the font right corner that might be provided to turn the radio on.
SOURCE: my wireless switch wont enable. Not allowing me
well try to instal acpi utility for it and usualy should work
k once u log in to router u need to click on w/l settings and
Wireless Settings Wireless Network Name (SSID): Region: --- Select Region --- Africa Asia Australia Canada Europe France Israel Japan Mexico South America United States Channel: 01 02 03 04 05 06 07 08 09 10 11 Wireless Access Point Enable Wireless Access Point Allow Broadcast of Name (SSID) Wireless Card Access List Security Encryption (WEP) Authentication Type: Automatic Open System Shared Key Encryption Strength: Disable 64bit 128bit Security Encryption (WEP) Key Passphrase: Key 1: Key 2: Key 3: Key 4:
and if u want security password type any 10 digit no which u can easily remember one>and click apply do not hit generate>rate me solved if its helps136 views
