Question about Emerson (557461) Radio/Cassette/CD Boombox
Emerson combination cd player radio model number PD52038
The locking mechanisim for the cd will not stay locked...a small staple came out of the mechanism and i can not ascertain where it belongs...i look on emerson's site for a manual but par usual found none...thank you
  • 6771 Answers
SOURCE: I need a plug in cord for an older Emerson Model PD6726PD6726
Radio Shack and Tv repair shops carry a variety of power cords.
Posted on Apr 19, 2012
0 characters
1 Points
How to fix cd player in boombox - freezes briefly before resuming
Oct 13, 2014 | Boomboxes
Apr 18, 2012 | Emerson Boomboxes
I have a electric/battery operated Emerson CD clock radio which works when plugged in. When I put new batteries in it won't play. Only plays with electricity. Help
You have to take the chord and disconnect it from the CD player.
If the chord is attached, but not plugged in, it still tries to run of the cable's power
May 17, 2010 | Emerson PD6810 CD Boombox
Cant close CD Lid.
Contact customer support at JVC America,they will help you there
Jun 01, 2009 | JVC RV-NB1 Radio/Cassette/CD Boombox
Pause button is stuck
hi soblessed,
the plastic push lock that holds the button is possibly broken, but hopefully the mechanism incorporated with the button has not been damaged because it was pushed too far.
to have this issue resolved, you may use something pointed to nudge the button from its place and free it from being stuck. Or you may remove the screws from the button, freeing the upper case from the lower case exposing the other side of the controls, so you can push the pause button out.
Apr 19, 2009 | Emerson PD6870RD Radio/Cassette/CD Boombox
My built in cd player is stuck on (err) and wont play cds
your solution would be to go to a google search for 2001 chevy tracker and see if anyone has the same problem. also check the manual if you have one. can you get the cd out? if there is no cd in put in a cd cleaner disk and see what happens. hopes this helps.
Mar 23, 2009 | Emerson PD6810 CD Boombox
Player just won't work
if this is just a player and not a radio/cassette/player.
make sure you have the button on cd and place a cd label up in it and see if you see the number of tracks if you do then hit play and you should hear the cd moving. If not put in a cd hit play and then open the cover to see if it turns at all if not then see if you can move the eye to the middle. this should solve it.
Oct 22, 2008 | Emerson PD6810 CD Boombox
power problem with transformer or faulty function selector switch or lock up , but try to see to make sure the selector switch is not on cd , if that don't work then unplug for a little while then try, if that don't work it will have to be tested to determine the problem
Oct 11, 2008 | Emerson PD6810 CD Boombox
Emerson PD6810 CD Boombox Error
My older model PD6810 had the spindle that holds the CD on the player missing causing the ER message to show and the player to stop working.
Aug 21, 2007 | Emerson PD6810 CD Boombox
Emerson PD6810
Unfortanatly, this is why Emerson only warranties these for 90 days, but I have heard and recommend that you contact Emerson and tell them you did not think that their product would break down after a mear 90 days and a lot of times, they will send you a new one, if you bug them enough. There should be a contact number in the owners manual. If you do not have the owners manual, go to: There is a contact link there. By the way, the problem you are having is a bad spindle motor or the laser optics are bad. Have you tried to clean the small laser lens off yet with a cotton swap and some good 90% or better alcohol? Good Luck
Jun 03, 2007 | Emerson PD6810 CD Boombox
Emerson (557461) Radio/Cassette/CD Boombox Logo
177 people viewed this question
Top Emerson Boomboxes Experts
Jonathon summesfield
Are you an Emerson Boombox Expert? Answer questions, earn points and help others
