Question about Belkin (F5D7230-4) Router (587009)
Connecting router i put in set up cd 4 router when looking 4 internet step 4 computer disconnect from internet then reconnect router stii has no internet connection how do i fix
    Sergeant:
    Champion:
  • 310 Answers
In the address bar type 192.168.1.1 or 192.168.0.1 if you get the sign in window your router is comunicating with your pc. the problem probably with your modem
I’m happy to assist further over the phone at https://www.6ya.com/expert/james_1cb31da1bc8c6102
Posted on Dec 31, 2007
I just reset my dell computer back to factory setting. How do I now reset up for internet connection. My provider is verizon and I am using internet explorer
You want to reset your internet connection???
If yes then follow the given steps....
Step 1
Turn the modem so that the back of it is facing you. Locate the power supply cord connected to the back of the device.
Step 2
Gently unplug the power supply cord and leave it unplugged for about 10 seconds. If you also have a router connected to the modem, disconnect the power cord of the router as well.
Step 3
After about 10 seconds reconnect the DSL modem power cord. Wait for the status lights on the front of the unit to come on. They may blink at first before turning solid green, or they may first illuminate as orange, then turn green, depending on the modem model. The "Internet" and "Incoming" lights may continue to flicker, this is normal operation for modems.
Step 4
After the modem is reset, reconnect the router power supply if you have a router. Wait a few minutes before resuming normal Internet use.
If you need any kind of technical assistance you can contact support cell
Jan 19, 2013 | Computers & Internet
Haw can i install Belkin wireless router N300 without the CD
You can install Belkin wireless router N300 without the CD just visit here to know how to set up without CD. https://wirelessrouterexpert.com/customer-support/contact-belkin-customer-service
Apr 10, 2012 | Belkin F5D7234-4 Router
Lose wireless sometimes therefore no internet
There are many reasons why this might be happening.. You could try the following steps..
1) Disconnect the power from router for a minute and reconnect and check. 2) Try changing the wireless channel and Network name and try re-connecting. 3) Check if there is an firmware update for your product and update if any update is available. 4) If none of the above steps work you will need to reset and re-config your router. ( For that you need the CD given with the router and you will need the ISP settings.)
Hope this helped
Feb 17, 2011 | D-Link AirPlus G DI-524 Wireless Router...
Dlink DSL-2640B LAN & Internet keep disconnecting , very random and it's painful
1) Disconnect the power from router for a minute and reconnect and check. 2) Try changing the wireless channel and Network name and try re-connecting and in change LAN slots at the back of the router. 3) Check if there is an firmware update for your product and update if any update is available. 4) If none of the above steps work you will need to reset and re-config your router. ( For that you need the CD given with the router and you will need the ISP settings.)
Hope this helped
Feb 15, 2011 | D-Link DSL-2640B Wireless 11/54Mbps ADSL2+...
Hi have belkin n150 and we keep getting chucked off the internet , what could the proplem be?
2) Try changing the wireless channel and Network name and try re-connecting and try changing the LAN slots at the back of the router if you facing the same issue even in wired connection.
Hope this helped
Feb 13, 2011 | Belkin F5D7234-4 Router
Wireless Internet is failing.
Hope this helped
Feb 13, 2011 | Belkin F5D8236-4 Router
Enthernet cannot connect
First Check if you are able to go online on modem..if not disconnect the power from the modem adn connect it back after a minute. If its still not connecting contact your Internet service provider. If you able to go online with modem please follow the below steps.
2) Try on different slots on the oruter if its wired. If wireless is the issue then try changing channels and network name.
Hope this helped
Feb 07, 2011 | D-Link DIR-615 Wireless Router
MINE IS A NETGEAR DG834GU V5,INTERNET KEEPS ON CUTTING AFTER ABOUT 10MINS FROM REBOOTING.WHATS THE PROBLEM
First connect the modem directly to the computer and see of the problem persists..if yes contact your internet service provider..if the problem doesnt show up with modem then please follow the below steps..
Hope this helped
Feb 07, 2011 | NetGear DG834G Router
UNABLE TO CONNECT TO THE INTERNET THROUGH COMCAST
To setup your router
first check..
Connect Cable modem to the computer using an Ethernet cable without the router installed and make sure that the Internet connection is active. If it is not, contact your Internet Service Provider. If it can go online,
to setup connectionwith router ..
Step 1:
Connect the Cable modem to the router’s WAN or Internet port.
Step 2:
Connect the computer to any available numbered port (1, 2, 3 or 4).
NOTE: In this example, we’ll connect the computer to port number 3.
Step 3:
Make sure the power adapter is plugged to an available power outlet.
Step 4:
check if you are able to go online wired..
if not your router has to be configured first,
you can also try power cycling your network set up,
Press and hold the reset button in your router for 30 sec with a pen or a paper clip with the power cable connected, then disconnect power for your router wait for 30 sec and then reconnect in back, restart your pc waith for all the lights to become stable in your router, then check if you r able to go online..
All the best...
Jul 07, 2008 | NetGear MR814 Wireless Router
How To Set Up PPPoE DSL Connections with a Linksys Router
This article describes how to manually configure a Linksys Router for broadband DSL that uses PPPoE (Point-to-Point Protocol over Ethernet) for authentication. For automatic configuration options, please try: 1. Linksys Easy Connect (see Answer ID 1650 for more information), or 2. The Linksys Setup Wizard CD-ROM software that came with your Linksys Router. Simply insert this CD-ROM into an online computer before connecting your Linksys Router, and the Wizard will provide step-by-step instructions on how to install and configure your router. If you are unable to set up your Linksys Router by using one of the above options, use the steps below to manually configure your router. NOTE: It is recommended that you print this article for offline reference. STEP 1: Before You Begin In order to set up your Linksys Router, be sure to first have the following: 1. A Linksys Router. 2. A DSL modem. 3. A working computer that can be wired in directly to the router for initial configuration and testing. 4. Two (2) standard Ethernet network cables. Linksys Routers come with one (1) standard network cable that you can use. 5. The PPPoE DSL username and password assigned by your Internet Service Provider. Depending on the provider, your username format might be similar to username, vzn123456, or an e-mail address (username@isp.net). If you are not sure what your username and password are, contact your Internet Service Provider for more information. STEP 2: Check Your Internet Connection Before installing your Linksys Router, it is important to first verify that you can successfully access the Internet by connecting directly to your modem (without your Linksys Router installed). 1. If you are connecting for the first time, follow the instructions provided by your provider to set up your modem and computer for online access. 2. Verify that you are able to access the Internet without any problems. If you are not able to get a connection, contact your Internet Service Provider for assistance. When you are able to access the Internet using your modem, continue to Step 3 and proceed with the installation of your Linksys Router. STEP 3: Connect the Hardware Follow these steps to connect your Linksys Router to your modem and computer. 1. Shut down your computer and unplug the power cords connected to your modem and Linksys Router if they are currently powered on. 2. Disconnect the network cable that connects to the back of your computer. 3. Connect the network cable that you just removed to the Internet port (or WAN port) located on the back of your Linksys Router. Your modem should now be connected to your Linksys Router. 4. Connect a second network cable back into your computer (into the same port that was disconnected in #2). 5. Connect the other end of the second network cable to one of the numbered ports located on the back of your Linksys Router (labeled 1, 2, 3, 4, etc.). Your computer should now be connected to your Linksys Router. The following diagram shows how your network should be connected. Verify that your connections are correct, and continue to the next step. 6. Plug the included power adapter into the router?s Power port. Then, plug the other end of the power adapter into a nearby electrical outlet to supply power to your router. 7. Turn on your computer. Do not turn on your modem at this time. Only your router and computer should be turned on for Step 4. STEP 4: Configure the Router Follow these steps to configure your Linksys Router. 1. On the computer that is connected to the Linksys Router, open a web browser such as Internet Explorer or Netscape. 2. Type http://192.168.1.1 into your browser?s Address or Location bar and click Go or press the [Enter] key on your keyboard. The IP address 192.168.1.1 is the default IP address of Linksys Routers. 3. A user name and password prompt will appear. Leave the user name field blank (empty), and type in admin (lowercase) for the password. The password admin is the default password of Linksys Routers. NOTE: The following username/password prompt screen will vary by operating system. 4. Once logged in, the router?s web-based Setup utility should load. In the section labeled Internet Connection Type, or WAN Connection Type depending on router model and firmware version, select the PPPoE option on the drop down list. Click here to view what an older Linksys router interface looks like. 5. Once PPPoE is selected, enter your PPPoE DSL username and password provided by your Internet Service Provider into the router?s User Name and Password fields. Depending on the provider, your username format might be similar to username, vzn123456, or an e-mail address (username@isp.net). If you are not sure what your username and password are, contact your Internet Service Provider for more information. NOTE: Be sure to
Feb 16, 2006 | Linksys EtherFast Cable/DSL Router
Belkin (F5D7230-4) Router (587009) Logo
27 people viewed this question
Top Belkin Computers & Internet Experts
Prashant M
Prashant M
jason
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
