Question about Mitsubishi VS-50703 50" Rear Projection Television
Mistsubishi vs 50703 problem
The picture is stuck on "loading VCR Plus data" it will not go away, the only buttons that function is the volume the channel, menu,....will not work???
  • DFOS Jan 03, 2008
    I have unpluged the tv for a along period of time, what should i do call person to come out or scrap it?
  • 4,402 Answers
Unplug tv and plug it back in.
Posted on Dec 31, 2007
My Mitsubishi VS 50703 is fed from a DVR into input Ant A. I get sound, but no picture, until I press the 'menu' button on the TV remote; then the picture appears in the PIP window for a few...
Try resoldering the vertica IC. Very common problem. When vertical drops out the CRTs go into blanking ( shutdown no picture) but the menu and on screen displays will still work. Resoldering the IC will usually solve the issue.
Jul 15, 2011 | Mitsubishi VS-50703 50" Rear Projection...
Have sound but no picture. We have comcast and can only see a small screen in upper right corner after pushing the menu button. In this picture, I do see my comcast channels and I am able to change them...
Look inside front panel under RHS picture tube for leaked fluid. If you see a puddle on signal board, take tv to street - it is unrepairable then. The coolant is poisionous.
If that looks ok, then make sure you're using original Mits. remote.
Hope this helps.
Jan 18, 2011 | Mitsubishi VS-50703 50" Rear Projection...
Vs 50703 mitsubishi power led comes on solid no picture no sound
Press menu on the remote to check picture. if ok, check signal source(eg. dvd, cable etc). Press input or device and menu button in the front panel at the same time to get error code.
Dec 29, 2009 | Mitsubishi VS-60609 60" Rear Projection...
Mitsubishi VS-50703 Picture Foggy
Open up the back and look for coolant leaks in the CRT's. If you are curious as to what it is, it's the same type of stuff they use to make antifreeze. If you see something wet, it should feel slippery if you get it on your fingers and rub them together.
May 10, 2008 | Mitsubishi VS-50703 50" Rear Projection...
Sansui tv/vcr combo is stuck on highest volume.
If you have the remote,have you tried it ?
Have you tried the volume button on the front of the set ?
If neither the remote or the button will work, then you may have a problem with the microprocessor IC (system control). If this is the case, then the set might not be economical to repair.
Perhaps the volume "up" button is stuck ?
Feb 08, 2008 | Sansui COM312AD 13" TV/VCR Combo
Mitsubishi VS-50703 blurry after move
A halo effect usually means the coolant in the CRTs need replacing in the effected color usually blue goes first followed by green. red seems to be less prone for some reason.
Jan 14, 2008 | Mitsubishi VS-50703 50" Rear Projection...
Televison & Video Logo
93 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
