Question about Acer Aspire 5500 5570-2609 Laptop
Mouse touch pad is too sensitive and erases information and relocates the cursor.
  • 81 Answers
Go to "control panel" and double click on "mouse"
Take a look around and you should find a setting to allow you to decrease "tapping" sensitivity.
Sorry I can't be more specific as each computer setting window is slightly different. I hope this helps.
Posted on Dec 31, 2007
I have a Dell Inspiron 1545 which has three problems, the battery discharges faster than when used by another computer of the same make, the screen lighting often blinks severally before it completely goes...
run crude cleaner to get the flicker and speed the laptop up
get a new battery... if discharges too fast.. like less than 45 minutes
cursor jumping around.. watch your touchpad..
commonly you are touching the mouse pad during some keystrokes
you can set the mouse pad sensitivity downward under control panel--> mouse---> synaptics mouse pad sensitivity also
Jan 21, 2011 | Computers & Internet
My cursor keeps jumping when I type on my notebook. I don't even have to touch the touch pad for this to can this be fixed?
Check the Mouse sensitivity
Click START - Click Control panel - Open MOUSE
Check the Sensitivity and adjust accordingly.
Jun 29, 2010 | Medion md40298 Notebook
I need help disbling this touch pad
You need to look into the user information manual for that notebook to see if there is a disable function. If nothing else works, Place tape over the touchpad and that should help. Additionally, you can look at your mouse sensitivity settings in Windows under control panel and reduce the sensitivity of the mouse.
Jun 29, 2010 | ASUS Eee PC 701 Notebook
While I type, often the cursor moves to the poit where the mouse icon is locatde, as if the touchpad has been pressed.
yeah you have touch sensitivity set to high in the touch pad and your wrist is hitting the touch pad. go your touch pad settings in the control panel and turn it down til when your wrist brushes it, it doesn't move the mouse.
Mar 23, 2010 | Dell F3534 Touchpad
My touch pad is SUPER sensitive, when I type, my cursor ends up all over the place. I read up on hitting the f7 key, but I am totally computer illiterate. When you guys say hit the function key, do you...
From Dell:
Customizing the Touch PadYou can use the Mouse Properties window to disable the touch pad or adjust the touch pad settings.
  1. Click Start keyboar4.jpg , and then click Control Panel.
  2. Click Hardware and Sound.
  3. Click Keyboard.
  4. In the Mouse Properties window:
    • Click the Device Select tab to disable the touch pad.
    • Click the Touch Pad tab to adjust touch pad settings.
  5. Click OK to save the settings and close the window.
Oct 06, 2009 | Dell Inspiron 1526 Laptop
Every time I type my cursor goes automatically to somewhere else. How do I turn off the touch pad on my laptop so it is not so sensitive?
Hi, You can adjust the sensitivity of the touchpad by going to Control Panel > Mouse > Device Settings > Settings > Touch Sensitivity.
Hope this helps
Chris (ziraffa)
Jan 04, 2009 | Gateway 7330GZ Notebook
Speed strip on touch mouse is too sensitive
remove the touch pad software if u have any installed for the touch mousepad
Nov 24, 2008 | Computers & Internet
Acerr Aspire 5315-2940
I don't know if you mean that your cursor suddenly moves as you are typing? If so, it is likely your touch pad is too sensitive. I have a mouse w/mouse pad but never disabled the touch pad. So i disabled the touch pad and it solved it for me. If you want to be sure it is the touch pad being over sensitive, then type a paragraph but keep your fingers and palms far away from the touch pad. If the problem improves, like it did for me, then the touchpad is too sensitive. You can go into the settings for the touchpad to change the sensitivity setting to make it less senstive and see if that works and it does not then press Fn +F7 keys to disable the touchpad.
Aug 26, 2008 | Acer NSK8458AN Keyboard
Cursor jumps around
If your cursor moves erratically on the screen (for example, if it jumps around the screen, moves at varying speeds, or selects items on its own), perform the following steps:
  1. Clean the surface of the touchpad with a dry, soft cloth to remove grease, sweat, moisture, or other liquids.
  2. Adjust the sensitivity of the touch pad:.
    1. Click the Start button and click Control Panel.
    2. Click Printers and Other Hardware.
    3. Click Mouse.
    4. When the Mouse Properties window appears, click the Pointer Options tab. (Figure 1)
      Figure 1: Pointer Speed
    5. Under Select a pointer speed:, click to move the slider bar closer to Slow.
    6. Click OK.
    7. Check to see if the touch pad still behaves erratically.
  3. If the touchpad still caused the cursor to behave erratically, attach an external mouse to your computer and restart your computer. Use the external mouse to see if your cursor still moves erratically.
Aug 14, 2008 | Computers & Internet
Acer Vista Laptop and cursor nightmare!!
Hi -
I've been having the same problem and it is MAJORLY annoying to be typing along, and have the cursor reappear on another line!
I had a heck of a time finding the place to disable the touchpad, since we use a USB mouse with the laptop. Turns out, someone else helped me find a simple way - hold down the Fn key (next to the left side CNTRL key), and hit F7. That toggles the touchpad off/on easily!
Also suggested by someone else, some mice can cause erratice behavior with Acer laptops, so perhaps try another mouse?
So far, I've been typing this response AFTER disabling the touchpad, and the cursor has not jumped around at all.
Good luck! : )
Dec 10, 2007 | Microsoft Windows Vista Ultimate Edition
Acer Aspire 5500 5570-2609 Laptop Logo
82 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
