Question about Yamaha HTR-5650 Receiver
No Sound Unit has power and switches between units but there is no sound.....Have tested the speakers on another unit and the are okay. The problem began after a lightening strike.
  • Anonymous Mar 13, 2008
    Power went off, on then off for 24 hours. After power came back on I could not get my receiver to play sound, had power but no sound. There is a messgae that stay on the screen, it reads 6 input channel.
    Sergeant:
  • 261 Answers
Your outputs IC'S are probably hammered. You can check these easy enough if you have a DVM. Digital Volt Meter. Let me know if you need more assistance. GURU JAY
Posted on Feb 07, 2008
Radio no sound
Is there not a loose loudspeaker wire or disconnect the speakers from the radio and check the speakers with a AA battery if okay when connected it should make a clicking noise if okay if the speakers are high power the click from them will be soft but even portable radio speaker will not get damaged with this test if you are scared of damaging it This is a standard test for checking loudspeakers
Mar 13, 2014 | Ford Car Audio & Video
Inoperative SS5 Speakers
so what is happening now?
are the speakers not functioning completely?
Oct 02, 2008 | Nakamichi SoundSpace 5 Shelf System
I have an Onkyo TX-SR606 AV Receiver. Problem is no sound from any channel from all sources! I checked all cables twice and put another receiver side by side to verify that speakers were not the issue! I...
That would leave the audio outputs as the problem, double check the speaker wires for shorts, if okay! I recommend a professional assess the unit for repair.
Mar 30, 2012 | Onkyo Audio Players & Recorders
Unit powers up, cd and radio seem to be operating properly, but no sound is heard, unit worked fine a few days before, all wires are conected, everything seems unchanged
Well...as you said...the unit powers up...so you don't have a "dead set".I don't know if the speaker can be disconnected from the unit.As a rule of thumb...it is very rare that both channels (left and right )fail at the same time...it is usually one channel while the other speaker still operates.This is what I want you to do...In a quiet room..get really close to the unit...Switch it on and listen for any sound from the speakers...get really close...you should hear a slight hum from the woofers and a high frequency "hiss" from the tweeters....If no sound is heard..switch the unit off..You should hear a "plip" sound...If not...switch it on again...you should hear a slight "bump" sound from the woofers...If you hear no sound from the speakers at all..there is a problem with the output stages of the amplifier section.If you do hear sounds fron the speakers,,Turn up the volume and watch for an increase visually on the display (such as ascending numbers).If there is no indication of a volume increase...The "mute" may be stuck on..Try switching it off and on...please let me know what happens after you do all the tests....Looking to hear from you......PEACE!!!
ok...
Jul 11, 2011 | JVC HX-Z3 CD Shelf System
Boston BA7500G Speakers with no sound.
Well we have eliminated the laptop as a problem,.. that is very good. As far as what the problem with your BA unit is,.. we only know that it does not function with an external device (laptop and mp3 player). you already mentioned that a sound test from the unit plays through all the speakers,. right? With that lets start with the most basic item that will cause this problem,.. the cable that comes from the BA unit and plugs into the laptop or mp3 player. Is the cable plugged into the right place on the BA unit? Does the cable disconnect from the the BA unit? if so, do both ends of the cable look the same or is there 2 ends (maybe red and white) that plug into the BA unit? Please let me know when you can and we can continue troubleshooting this.
Feb 08, 2010 | Boston Acoustics BA7500 Computer Speakers
Pioneer stereo receiver has sound and power problems.
i would suggest checking the wires on the speaker switch board, thats usually the main cause of this problem..but i dont recommend buying pioneers newer stuff
May 04, 2009 | Pioneer Audio Players & Recorders
NO SPEAKERS SOUND
Ok, there is a plug that looks green on the back of the unit. Match the color coding on the back of the unit and on the sound card. Make suire its plugged in the right hole because you got LINE IN- MIC and SPEAKER.. if its a 7.1 sound card then you probably got CENTER- RIGHT AND LEFT and so on.. check your cabling..
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
Apr 21, 2009 | Dell Inspiron 530 Desktop Computer
I have a 1998 Chevrolet Prizm. It has a Delco
This is one of two things either the power amp in the unit is damaged or the speakers are not connected. Remove the unit and check all connections. if all are connected properly ,then you will have to check the speakers .if the speakers are okay the power amp in the unit is blown ,probably from not connecting the speakers correctly.
Apr 08, 2009 | Car Audio & Video
Pioneer X MT- 2000 Stereo Bookshelf Unit - No sound!
It definitely sounds like it took a surge. yhe Power Amop IC in those things are pretty sensitive. Any decent repair shop should be able to repair it for under $125.
Sep 18, 2007 | Audio Players & Recorders
Jensen Subwoofer JPS-10
This sound is made by the automatic shutdown in the speaker. Jensen repaired my unit under warrantee.
Aug 27, 2007 | Jensen JPS10 Subwoofer
Yamaha HTR-5650 Receiver Logo
53 people viewed this question
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
