Question about ASUS VIA Apollo Pro133A Chipset CUV4X-C Motherboard
HardDrive will not copy (or mirror) to another HD
I tried to copy my 10GB Maxtor HD to a Maxtor 60GB HD and I get a error message "cannot copy hiberfil ,access is denied. My 10GB is full and I need to transfer to the 60GB. Thank you! Steve Aspen @ steveaspen@hotmail.com
    President:
  • 2,351 Answers
Acronis Migrate Easy Trial
The Trial version of Acronis Migrate Easy is fully operational but works only for 15 days.
Acronis® Migrate Easy 7.0 file size 41.5MB
http://www.acronis.com/homecomputing/download/migrateeasy/
Posted on Dec 31, 2007
Can't read HD-- I/O error
"Joecolvette" has probably got it right, I've seen this before. The HDD enclosure circuit board has a fault. Can be resolved by replacing the enclosure. Plenty on ebay, just ensure you buy one with the correct HDD interface (Sata or IDE).
Alternatively, if you have a tower with a spare port, you could take the HDD out of the caddy, install it in the tower as a "Slave" (check jumper settings) ensuring the system drive is set to "Master". Then you can check whether the HDD itself is at fault.
Apr 28, 2012 | Maxtor Computers & Internet
Backing up my Maxtor Portable Harddrive?
hi
visit www.fbackup.com and download the software to backup your data
Dec 26, 2009 | Maxtor Hard Drive
Cannot get external hard drive to work
- Make sure that the hard drive (HD) is properly connected to the computer.
- Try connecting it to a different computer to make sure that the HD is the problem.
- Check the Disk Management in your computer to see if the HD could still be detected. Once detected, reformat the HD and it should work again.
To check the Disk Management:
NOTE: Make sure that the external HD is connected and turned ON.
1. Right-click "My Computer" (XP) or "Computer" icon (Vista)
2. Select Manage and click on "Disk Management".
3. From the Disk Management, you will see a drive letters
4. Write down all the drive letters and then disconnect the Maxtor HD from the computer.
5. If there's a drive letter that disappears, then that is your Maxtor HD.
6. Reconnect the Maxtor HD and reformat it. You may right-click the drive letter and there's an option to format the HD.
If you're hearing a clicking sound while the HD is turned on, mostly, it's already defective.
Have a great day!
Oct 17, 2009 | Maxtor Hard Drive
Copied files disappeared as soon as they were copied over
Did you try to copy one picture file to your mini harddrive then change it properties to archieve only? After that you can rotate it freely without that annoying message.
If that does not go as expected. Could be virus infection. Both your miniharddrive and your computer is infected. Some do it by changing it properties to read only then hide it.
You should first start disinfecting. The files can be view by clicking tools in My computer then set to view hidden files then start exploring your minihard drive. Some infection only affects picture files.
Just for the thought.
Apr 13, 2009 | Maxtor 160GB OneTouch III Mini USB 2.0...
Harddisk
Can you recall what you were doing when you first got that error message? Try disconnecting the drive and then reconnecting it. If you still get the same message, check the Maxtor utility to see if there is some type of repair procedure that you can do without reformatting it.
Aug 23, 2008 | Maxtor Hard Drive
Open up the case
Well, since you are discarding the case, use a small flat head screw driver or something to pry the case open. Once inside, the HD will be plugged in to a circuit board and screwed in place. Unscrew it and carefuly unplug the HD from the circuit board. Then you can transfer it to another external HD housing.
Jun 19, 2008 | Maxtor OneTouch III Mini Edition (R01E100)...
Maxtor mini iii 120 gb HD
Uninstall the back up software, and choose another or reinstall it.
Oct 17, 2007 | Maxtor OneTouch III Mini Edition 120GB...
Harddrive monitor error
Placed them IN a computer or enclosure?
Oct 17, 2007 | Maxtor 80gb 7200rpm ATA 133 IDE HDD p/n...
Maxtor One Touch
The harddrive itself has gone bad, only solution would be to replace the HDD inside the enclosure :-( sorry.
Sep 15, 2007 | Maxtor OneTouch II Hard Drive
ASUS VIA Apollo Pro133A Chipset CUV4X-C Motherboard Logo
190 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
David
David
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
