Question about Fisher and Paykel DE08 Gas Dryer
Dryer wont turn on
I was drying clothes and then it just turned off!no noise or anything and it doesnt have power
    President:
  • 1,314 Answers
Turn your breaker off the on
Posted on Dec 31, 2007
Wont cycle to dry clothes
When the dryer door is open, you should be able to find a switch (it may be just a button protruding from the cabinet). The switch turns the machine off when the door is opened. It may be damaged or worn out.
Apr 04, 2014 | Maytag EPICz Electric Dryer
The dryer wont heat up the clothes dont get dry everything eles works on it the drum turns ok the timer works also it just wont dry the clothes
Hello,Sam
The usual reason a dryer will heat yet not dry the clothes is going to be a air flow problem. What ya need to check is for a blocked vent and or lint build up in the blower assambly.
By far though a leading cause of that on Maytag dryers is a broken blower wheel and therefore no warm air is being drawnthrough the clothes,to check that remove the front panel and the front drum support and in the lower left corner will be the blower asm. check to see if it moves free and doesnt seem to be attached to the motor shaft.
GENE
Sep 20, 2011 | Maytag MED5770TQ Electric Commercial Dryer
My dryer is squealing and have to run it twice to get my clothes dry
the squealing/squeaking noise is more then likely your drum rollers:
http://www.partselect.com/dryer+dryer-tears-clothes+repair.htm
the drying twice is a venting issue:
http://www.partselect.com/dryer+wont-dry-clothes+repair.htm
Feb 16, 2011 | Whirlpool LEW0050P Electric Dryer
I have a Kenmore 70 top load dryer that is not heating. And the timer doesnt turn off anymore either. Both items seem to have malfunction at the same time. Help?
This is typical. If the heating element is no longer working, the unit doesnt know to turn off due to the clothes still being wet. However, the timer has absolutely nothing to do with the heating of the unit. If the timer doesnt turn off the unit even when the time is short (example: 10 minute timed dry), the timer has a different issue. If you have merely set the dryer to dry the clothes (not a "timed cycle" to dry) then the dryer will continue to run as I have stated before. The dryer will run until the clothes are dry. Now, its time to address the heating part. Your dryer heating element has gone bad. It can be replaced if you are somewhat handy. You can pick one up from your local appliance store and it has simple instructions. Please make sure that you disconnect the unit from its power source prior to attempting any repairs. Safety First. You can also call someone to replace it for you and it shouldnt be too costly. Good luck on either option.
Feb 08, 2011 | Kenmore Dryers
Maytag gas dryer wont turn off when done drying in auto dry regular fabrics. does turn off in air fluff and auto dry perm. press. model # d3382
auto dry relies on a moisture sensor to say when its done. so your clothes arent dry enough according to sensor. perm. press. doesnt dry the clothes as much
Aug 01, 2009 | Dryers
My dryer doesnt work
check the door swich to be sure made up properly
Dec 29, 2008 | Kenmore 659 Electric Dryer
90 series dryer wont start
first check and see did any clohes fall down in the blower wheel,,from fillter no...check the belt that its not jammed,,check your idler wheel ...always unp[lug unit first.....now we will check motor ,turn unit on if you get a humming for about 10 to 15 seconds than a click,,replace motor
Dec 25, 2008 | Kenmore 63942 Dryer
My Electric dryer will not start.
you might have something stuck in the impeller. if there isn't anything stuck, you might require a new motor
Jun 28, 2007 | GE DWXR483EBCC Electric Dryer
Fisher and Paykel DE08 Gas Dryer Logo
210 people viewed this question
Top Fisher and Paykel Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Craig Butler
Craig Butler
Are you a Fisher and Paykel Dryer Expert? Answer questions, earn points and help others
