Question about Universal Office UNV-38961 Shredder
Ativa DQ120D Motor has not been running. When I put a piece of paper in, the overheat/overload lights come on. I believe everything is seated correctly.
  • jrooney03 May 11, 2010
    I have the same problem with my office shredder. I have cleared all the paper jams.
    Have used the lubricating sheets faithfully
  • 579 Answers
The mechanism is overloaded. No doubt from debris inside. need to to tak it apart, clean it all up, relube, and reassemble.
Posted on Dec 31, 2007
My ativa LD 800 shredder all of a sudden runs continuously instead of just when I put paper in the mouth piece. Is there a "secret button" I don't know about?
Not a secret button but a paper sensing switch in the blades. I would unplug it and contact Ativa to find out if its easy to unjam the switch. The blades are very sharp so I do not recommend fixing it yourself without checking with Ativa.
Jul 11, 2018 | The Office Equipment & Supplies
I placed less than 12 sheets of paper in the ativa 1250 shredder. it's reading overload. can you help?
The problem seems to be the plastic gears and/or bearing supports. Unless it is in warranty, it's going to cost you more to repair than replace, and even then Ativa's customer service is not the best and neither are their shredders: I suggest you look at http://www.complaintsboard.com/complaints/ativa-paper-shredder-c31646.html?page=2
Jun 29, 2014 | Office Depot Ativa DQ60M Shredder
Overload light keeps coming on but there is only 1 piece of paper at a time
Have you ever "oiled" the machine...get shredder oil and put some into the cutting blades and run the machine in reverse..then put some of the oil on some paper and run the paper thro" the machine.
Nov 18, 2010 | Royal VF1012mx Shredder
Ativa X1000 paper shredder that doesn't turn on
took the shredder section apart, cleaned out the gears of paper and a broken mount (plastic piece), and hand turned the electric motor to free it up. After assembly, the ready light works and so does the FWD/REV directions for shredding.
Nov 10, 2009 | Office Depot Ativa DQ60M Shredder
Red overload light is on
Try pouring some shredder oil into the throat where you normally insert the paper and run the machine in reverse.Put machine back into ready condition.
Put a piece of paper in the throat just enough so the machine should run but not all the way in so that the cutting mechanism catches the paper...all you want to do is make the machine run forwards but not actually be feeding in any paper.
If it wont even run in the forward direction you may have a pcb prob...give Royal a call at 1-800-524-0799 for parts assistance.
Jan 08, 2009 | Royal VF1012mx Shredder
Shreader Malfunction
If the gears are stripped it will cost more to buy them and pay for the shipping if it is not under warranty. You also have to think if the gears are stripped what caused this to happen. It probably put a lot of stree on the motor also. So you may not have a loy of time left on your motor. I hope this will help you.
Sep 26, 2008 | Office Depot Ativa DQ60M Shredder
SPL 1506X Shredder
Have you looked for hidden staples in the machine. Sometimes they can be hard to spot.
Aug 01, 2008 | Office Depot Ativa DQ60M Shredder
Something is jammed
I was able to unjam an ATIVA DX 180 D shredder now the shredding blades won't turn but the motor is running.
Jan 08, 2008 | Office Equipment & Supplies
Ativa DQ120D shredder
I had the same problem with my Shredded. In the centre of the paper feed slot is a little sensor that detects when you put paper in, it breaks some sort of light beam that is connected to the motor circuit.
Over time paper dust gathers on this sensor, covering it completely and fooling the machine to think that there is ALWAYS a piece of paper being fed into the shredder, the result being that the motor just runs continuously.
Clear the dust from this sensor and you'll fix this particular problem - a toothbrush worked great for me - don't use it to clean your teeth afterwards :-)
FIXYA!!!
Dec 11, 2007 | Office Equipment & Supplies
Universal Office UNV-38961 Shredder Logo
269 people viewed this question
Top Universal Office Office Equipment & Supplies Experts
k24674
jasbo
jasbo
Marvin
Marvin
Are you an Universal Office Office Equipment and Supply Expert? Answer questions, earn points and help others
