Question about Samsung SIR-S300W DirecTV DTV Receiver
Unit will not turn on Red light continues to flash
My unit will not turn on and the red power light continues to flash . I have tried unplugging unit and when plugged back in it will still not power on but the red light continues to flash
  • 19 Answers
SOURCE: Unit will only stay on for 20 sec. after you
Your dtb-h260f likely has a bad capacitor in the power supply. See this link for more information:
Posted on Feb 04, 2010
0 characters
1 Points
Motorola DCT700 won't power up.
its working correct... thats sounds normal
now you just need to wake it up. turn it on using the remote supplied by your cabe operator. if anything it may be your remote that isn't working. does a "cbl" light or anything light up on the remote when you press the cable box power button? if not try to find out how to put it in cable mode and try again.
wish i had more info
good luck
Aug 12, 2012 | Arris DCT700 DTV Receiver
When I switch on the Unit the Power Light/Indicator keeps on flashing and nothing happens on the tv. The unit was working perfectly for the first 2 days. What could the problem be?
Tries the unit unplug,replug it back like an hour later for the unit to reboot and restart itself back to the factory setting.The unit should be working now.If the unit still have the same problems,the unit must have to be taken aparts and troubleshoot and fixed it power supply circuitry side of it PCB board.
Sep 01, 2011 | Iomega ScreenPlay
I lost all the tv channels on channel master cm-7000 model and do not understand how to get them back?
First look at the indicator lamp on the front left side.
If it is:
off - check the power cord is plugged into a working outlet.
Amber - the unit is in standby, press the on button (left most), it should turn green
Green - the unit is in operate mode, check the antenna and cable connection.
Red - when power is applied, it will be red for up to 30 seconds. If it remains red, the unit is defective. This is a common problem due to several capacitors on the power supply and logic board that have gone bad. The unit is repairable by replacing these capacitors.
Jun 05, 2010 | Digi Channel Master/tal to Analog...
Daytek television will not turn on.
There is a switch on the bottom of the unit that has to be turned on. The power light will come on but not the screen until the switch is on.
Mar 27, 2010 | TV Receivers & DVRs
Philips FTR 9964 tries to switch on but light above power switch flashes red
Jun 05, 2009 | Philips FTR-9964 Tuner/Receiver for Plasma
No picture, no sound
we need a request on what the blinking red light means on your model number and manufacturer of TV, we can then try to see what the blinking light means,(although it doesn't sound good) You ca always unplug the DVR and see if there is a change, then you would know it was the DVR
Thanks for the rating
Apr 12, 2009 | TV Receivers & DVRs
My thomson DTI6300-16 red light keeps flashing
There is a known power supply fault on Thomson boxes. If you go to you`ll be able to order the parts needed. Be aware, you`ll have to be able to use soldering irons etc. as this requires you to remove components and refit new ones.
Dec 06, 2008 | TV Receivers & DVRs
Tv turns on briefly then goes out with red flashing status light
This is exactly intermitent problem, It needs to be trouble shoot at the repair shop if the problems occurs from power supply or high voltage.It needs a lot of test and equuipement to be accurate.And also the specific parts.
Nov 28, 2008 | Mitsubishi TV Receivers & DVRs
PLasma wont turn on
Unfortunately you need a repair man. The power supply is bad.
Nov 12, 2008 | TV Receivers & DVRs
Toshiba tv will not turn on
I have a toshiba tv and it will not turn on. There is a flashing green light that comes on, but there is no picture or sound.
Oct 31, 2008 | Toshiba DVD Recorder AND Series2 TiVo...
Samsung SIR-S300W DirecTV DTV Receiver Logo
37 people viewed this question
Top Samsung TV Receivers & DVRs Experts
Are you a Samsung TV Receiver and DVR Expert? Answer questions, earn points and help others
