Question about Consew 206RB
Breaking thread breaks thread when sewing heavy material or when you back up stitch
  • Anonymous Jan 19, 2008
    bottom bobbin breaks thread bunches up
  • 3 Answers
1. Make sure you are using the correct needle and thread for type of fabric and it is installed correctly. Make sure bobbin is threaded evenly. 2. Tread path - make sure the machine is correctly threaded. Then, with your finger, feel for burrs, nicks or roughness on any metal parts that contact the thread. Open the slide plate, remove the bobbin and inspect the bobbin case and hook. Remove the needle plate and examine the needle hole. Sand any rough areas with fine emery paper and blow away grit. If burrs or nicks remain on the needle, presser foot, needle plate or bobbin case, replace them with exact replacement parts, if they remain on the thread guides, take-up lever, bobbin hook or tension regulator, take the machine for professional service. 3. Loosen thread tension by adjusting tension dial. 4. Clean feed dog, bobbin case, and tension discs. Unplug the machine. Use a small, stiff brush to wipe dirt and lint off the machine head and the needle bar area. Raise the presser foot and the needle to the highest position, open slide plate and remove the bobbin and needle plate. brush away dirt and lint from the feed dogs and bobbin case and remove any tangled thread with your fingers. Use a soft cloth to clean between the tension disc on the tension regulator. 5. Also check tension on presser foot
Posted on Dec 31, 2007
Thread keeps breaking
increase the needle thread tension up more
May 11, 2018 | Sewing Machines
Fy5318 breaking thread on multiple layers of material, how to adjust?
either the thread is old, or the tension is to tight.
or there is a bind some where in the line layout.
you mite goto there website and look under FAQ section for other help
or
www.youtube.com/sewing/canvas/material/
www.youtube.com/fy5318/multiple/layers/of/material/setup/
www.ask.com/sewing/multiple/layers/of/material/and/setups/
Sep 17, 2015 | Yamata Fy5318 Mechanical Sewing Machine
Stitch failure
try these suggestions
The top thread breaks
1. the needle thread is not threaded properly
2. The needle thread tension is to tight
3. The needle is bent or blunt
4. The needle is incorrectly inserted
5. The needle thread & the bobbin thread are not set under the presser foot when starting to sew
6. the threads were not drawn to the rear after sewing
7. The thread is either to heavy or to fine for the needle
8. Try a different spool or cone of thread
Apr 11, 2013 | Sewing Machines
It wont stitch tee/shirt material it misses stitchs
If machine misses stitches consistently, it can be several things.
Needle not installed correctly, not threaded correctly, Bobbin case not installed correctly, make sure the bobbin itself is inserted correctly and spinning in the correct direction.
Finally, machine may need service the timing is off. All actions of a sewing machine are carefully "timed" to form a stitch while sewing. Sewing things that were too heavy for the machine or you hit the bobbin case while sewing can knock the machine out of adjustment.
Let a professional do the maintenance on your machine. Some may opt to show you how to do more in depth maintenance yourself at home.
Cheers,
Feb 01, 2013 | Sewing Machines
The bottom stitching looks like a line and not stitches the top stitching is fine
whether its bias or straight does not matter to machine. loosen the bobbin tension and put more tension on take up spring by inserting a screwdriver in the slot of the top thread tensioner. turn to right.
Dec 13, 2012 | Juki DDL8300N Sewing Machine
try adjusting the top thread tension and see if that helps
also try changing the thread.
also change the needle--make sure it's the right needle for the fabric
being sewed.
Thread keeps breaking using husqvarna
The needle thread breaks
Oct 30, 2012 | Husqvarna Sewing Machines
The needle is threaded top and bottom but when I run the machine to sew the thread isn't sewing on to the fabric..I'm not sure but I think the thread around the check spring holder is midway or rather not...
Recheck the threading on the top side. When you pull the thread at the needle is there tension on it? If there is no resistance than there's no tension. If it breaks it is either not threaded correctly or the tension is way too tight.
If that is correct and the the thread on the bottom has a little bit of tension when you pull on it, it should stitch --- However not stitching at all can be from having the wrong needle, wrong brand, type, or in incorrectly. Sometimes even the wrong size can prevent stitching, like when youre sewing through heavy/thick material and using too small a needle.
Check out those three things and then see if it won't sew correctly for you.
Apr 21, 2011 | Euro-Pro 801B Sewing Machine
While sewing the thread will break
Take a small piece of material and take several practice runs of a straight stitch. If the cotton breaks try adjusting the small tension wheel (numbered 1234 etc) . To decrease tension turn to a lower number. Adust as necessary until you get a satisfactory stitch.
Jan 30, 2011 | Brother SE350 Mechanical Sewing Machine
I keep having problems with the stitching on my machine. 1) when you sew the stitches looks normal from the top but when you turn the material over it looks like one big tangled mess. 2)When it does...
It is usually in your top threading, make sure that your thread match in bobbin and top threads. Mixing sometimes causes a problem. Also make sure that nothing is tangled. Also, check your needle and put a new one in just to be sure, then check your manual for size of needle and what kind of project you are doing. Hope this helps.
Sep 26, 2010 | SINGER 7470 Sewing Machine
Consew 206RB Logo
284 people viewed this question
Top Consew Sewing Machines Experts
Michael Galve
Michael Galve
Oloyede Monsuru
Irene Tulloch
Are you a Consew Sewing Machine Expert? Answer questions, earn points and help others
