Question about Directv RC23 Remote Control
Follow setup instructions and still does not work
When I follow the instructions to set my remote to work with TV (sony) and DirectV device, the setup works well until I try to enter the code. When I try to input the code,a message saying "TV Keys aren't programmed" appear, with the options of "Program remote" and "Don't program" to select from. What am i doing wrong?
    Problem Solver:
  • 6 Answers
You are not sliding the switch at the top to tv mode do that and input code 10000 it should work
Posted on Dec 03, 2008
Rc65x not working with sony bravia
Direct TV rc65x code for Sony Bravia is 10000
Setup Instructions
  1. Set the "Mode Switch" to Device 1 (in the case of the rc65x set on TV).
  2. Press and hold the "Mute" button and the "Select" button until the visible LED blinks twice.
  3. Enter the 5 digit Code above.
  4. Try your new code and tell us how it worked!
    (It worked perfectly for our Sony Bravia using our rc65x remote)
    & Goodluck!
    http://www.ezremote.com/setupcodehelp/DTV2/dtv.html?product=DIRECTTVRC65SW2009#search
Jul 25, 2012 | Directv RC65X Universal Remote Control
Have direct tv service, bought a new 37 inch visio flat screen hd tv, need the code number to program my direct remote
could not find your brand at Directv.com but this may work: " You may still find a setup code that works for your device by stepping through the library codes in your remote. The following instructions will help you do this.
StepNSet
Set the "Mode Switch" to the desired mode such as TV for a Television.
Enter the code "991" followed by the "device number"
for Televisions
for "AUX 1" devices - VCRs or DVDs
for "AUX 2" devices - Audio
You can step through the setup codes for this mode by pressing the "Channel Up" key to go forward through the codes or pressing the "Channel Down" key to go back to the previous codes.
You can try out each code by pressing one or more function keys such as power, volume or digit keys.
When you've found the setup code that works for your device, press the "Select" key. "
Sep 02, 2010 | Universal Remote Control DIRECTV Universal...
Comcast Remote Control - Won't accept remote codes
To reset the remote control, just take out the battery from the remote control, and reinsert it after an hour or so. The remote control will reset itself.
After that try to set it up with the setup code said for your device. You might have to try many codes before getting a code that'll have the most functionality with your device.
Setup procedure and set up code list of many popular brand remote controls are given by these sites. http://electrohelponline.blogspot.com/ http://remotesearch.blogspot.com/
Mar 04, 2017 | Motorola Televison & Video
Need to program directtv remote to work volume on rca tv need codes for tv
You need to go in to menu and select setup. Than select remote set up. Follow the instructions on screen.
Jan 02, 2010 | RCA R10 DIRECTV
Direc TV remote won't work Receiver
call directv and they will walk ya thru reporgramming remote for reciever. or goto menu, setup, remote, then follow on screen instructions. i cant give u the exact instructions cause every reciever is a bit different and its different if one remote operates two directv recievers. ( like a bar would do to operate two tvs with one remote)
Jun 12, 2009 | Directv Universal Remote
Program remote for sony ht-5100-d
Use your Directv remote. Use code 10812, remember to program it to change tv inputs also. then program the same remote to control volume on your Sony receiver. Go to the menu on the directv box and follow the onscreen instructions.
Apr 24, 2009 | Sony HT-5100D System
Rc23
Push the MENU button on the remote, then complete the following steps: Parental, Fav's & Setup> System Setup > Remote > Program Remote. From here just follow the on screen instuctions. Good Luck!
Oct 26, 2008 | Directv RC23 Remote Control
WIll not work with Comcast, DirecTV, DishNetwork Remotes
Hello! I just got my Directv remote to work with my GE tv. I started by trying code 11922, and when that didn't work, I followed the Directv instructions to find a set-up code manually. After I followed the instructions below and doing it about 6-8 times, it started working! (So I guess the code 11928 - 11930 might work?) Good luck! I'm still having problems getting the "video" setting to work to switch inputs, but I'll keep trying...
  • Set the "Mode Switch" to the desired mode such as TV for a Television.
  • Press and hold the "Mute" button and the "Select" button until the visible LED blinks twice.
  • Enter the code "991" followed by the "device number"
    1. for Televisions
    2. for "AUX 1" devices - VCRs or DVDs
    3. for "AUX 2" devices - Audio
  • You can step through the setup codes for this mode by pressing the "Channel Up" key to go forward through the codes or pressing the "Channel Down" key to go back to the previous codes.
  • You can try out each code by pressing one or more function keys such as power, volume or digit keys.
  • When you've found the setup code that works for your device, press the "Select" key.
Oct 18, 2008 | GE 24GP653 24" TV
Trying to set my Directv remote to control my Orion TV........
Orion code is 11911 and to program your tv to work with a directv remote then follow these...
Setup Instructions
  • Set the "Mode Switch" to TV.
  • Enter the 5 digit Code above.
  • Slide the "Mode Switch" back to Directv and try adjusting volume and turning tv and receiver off using the off button and then back on with the on button just above the off button
  • Dec 28, 2007 | Orion1934 19" TV
    DirecTV RC64R RF Remote control
    Actually, you can go into the system settings by choosing "Parental, Fav's & Setup" then choose "system setup" then choose "remote" the IR/RF setup. Change it to IR and follow the instructions. Once I did that my remote worked on my DirecTV DVD HR22-100
    Nov 28, 2007 | RCA DRD480RE Receiver
    Directv RC23 Remote Control Logo
    252 people viewed this question
    Top Directv Televison & Video Experts
    john milligan
    rundiggity
    Are you a Directv Televison and Video Expert? Answer questions, earn points and help others
