RCA D52W23 52 in. HDTV CRT TV
Problem for RCA D52W23 52 in. HDTV CRT TV
I have an RCA D52W23 TV convergence problem
By rjflor on Oct 23, 2009
I have an RCA D52W23 projection TV. I was told it needs a convergence board. Where can I get the right replacement part, is it STK 392-180? I plan to replace it myself and am looking for instructions to do it.
Comments:
Nov 10, 2009
- I fixed my problem by checking the flyback for broken solder and found 3 pins that had broken solder so I resoldered them and my convergence issues were solved with no cost to me. Thanks to the info from TVREPAIRWORLD.
Best Solution
posted on Oct 24, 2009
Very Helpful)
tlm931
Rank: Guru  Televisions & Videos  Expert
Rating: 89%, 54 votes
bd pt no is 264103 check your local rca dist and servicers
Comments:
Nov 11, 2009
- that is usualy the case its usualy pin 11 and 12 of the flyback and a fuse some times opens and on some there is a ribbon connector that will cause some intermitant convergence and other problems
however you did not ask for help you ask where to get the part and a no for the part was provided
you did not ask for help in repairing unit .
either way glad you were able to repair it for now
have a great day
Was this helpful?
Yes
No
2 people thought this was helpful
Asker's Testimonial
" What a great site this is to get answers to questions very quickly. Thanks!!! " - rjflor
Solution #2
posted on Nov 10, 2009
Very Helpful)
mrrepair
Rank: Master  Televisions & Videos  Expert
Rating: 92%, 6 votes
STK392-180 is not a part# for a board. It's a part# for a component (IC). These sets do not use such parts.
All you need to fix your convergence problem is a little bit of solder, and a fuse. $3 will fix it.
You can get the fuse here: http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&item=220478092023
Was this helpful?
Yes
No
1 person thought this was helpful
Popular Solutions for RCA D52W23 52 in. HDTV CRT TV
Questions and Unsolved Problems for RCA D52W23 52 in. HDTV CRT TV
Do you recommend RCA D52W23 52 in. HDTV CRT TV?
Answer
Answer
my 62" rca picture won't show when i turn it on, and power light is on and turns off after... (More)
Answer
colors are separated a lil red blue green and video in whole is a little warped, and after like 5 to... (More)
Answer
the red and blue convergence crosses do not line up when i go to convergence. and my screen looks... (More)
Answer
my RCA television has power, the green light goes on, but the screen wont turn on, the green light... (More)
Answer
we adjusted the brightness on our 54 inch tv and the picture went out, it does not have a picture... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For RCA D52W23 52 in. HDTV CRT TV:
Top Projection Television Experts
Rank: Guru Guru
Solutions: 745
Experience: 30 Years of professional repair and design.
Ask Me
Find more Projection Television Experts
Top TV Repair
(859) 609-2887
SERVICE/REPAIR OF TELEVISION AND ELECTRONIC...
(316) 283-8873
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
