Question about Motorola Mobility RAZR V3
Mobile not working on p.c
Tells me it is "initializing please wait" communication port unavailable transmission cancelled.
PLEASE HELP IF YOU CAN.Thanks Dorothy
I have reinstalled numerous times and it still says initializing.. and phone image not available
Posted on Jul 06, 2008
    Brigadier General:
  • 7,752 Answers
Uninstall then reinstall the cd software for the mobile on to the pc then install usb drivers....hopefully you are working with a winxp pc and not vista...vista is to problematic.
Posted on Dec 31, 2007
I have a HP 44" Z3100 and after switching and saying "Initializing, please wait" it gives error 79-04 " Help needed urgently please!!!
Firmware issue:
1. Cancel all pending/que jobs
2. Disable nesting option
3. Dis connect data cable, restart the machine.. check...
4. Up load latest firmware.( read carefully read me file before up loading the firmware)
Jan 18, 2013 | HP DesignJet 1050c InkJet Printer
Network drivers are not worke propely
Instructions
    • 1 Check which communication port and interrupt your modem is set to use. Typically, these are hard-wired selections on the board itself. Changing the jumpers on the board changes the port address and interrupt number. You must give forethought to the consequences of the decision. There are only two interrupt lines usable and four port addresses that are possible. Only one port can utilize an interrupt number at a time.
    • 2 Change the port and interrupt assignment if required. Restart your system and see if this solves the problems. If not, find the documentation for your modem. You must now generate the proper initialization string for your modem to maximize your communications. Some of the settings in the initialization string determine the audible sound of the modem when dialing and connecting. More important settings have to do with number of rings to wait before hanging up, time to wait between redials, sensitivity of the modem to line noise and enabling or disabling the transfer mode of X2 or V.90 (the two formats for 56K communication).
    • 3 Find the modem driver that you are using and check that it is the correct driver. There are many drivers available based on manufacturer and model of the modem. Not only is the driver modem specific but also the recommended initialization string. Make sure your modem receives the correct initialization string in the setup file or preference window in the application that uses the modem.
May 13, 2011 | HP Pavillion DV6227 Notebook
I got a lg vu of ebay already unlocked, it wont let me send multimedia messages,At first it was saying service unavailable I realized that it was still on att mms, so i changed it to T-mobile mms, then i...
Go to Settings>More>Connection>Network Profiles and create a new profile. Enter these settings:
Bearer: GPRS
Authentication: PAP
User Name: [blank]
Password: [blank]
APN: epc.tmobile.com
2) Go to Messages>Message Settings>Multimedia Message>Message Center, click on options and choose New. Enter these settings:
MMSC URL: http://mms.msg.eng.t-mobile.com/mms/wapenc
MMSC Proxy: 216.155.174.050
MMSC Port: 8080
Connection Mode: TCP without Proxy
Network Profile: T-Mobile WAP
May 08, 2011 | LG Vu CU920 Cellular Phone
Web not working on sidekick 3 phone.
Sorry to tell you this, but unless you have the t-mobile sidekick data plan the internet, chat and email will not work. It is hard coded to use the Danger Servers for these services.
Aug 18, 2009 | T-Mobile Sidekick II
Mobile phone tools problem
uninstall it then try again...or try cleaning you mobile usb port then try again
Nov 10, 2008 | Motorola Mobility RAZR V3
SYNC LGKU990 to PC
This is what sorted it out for me.
When you go through the connection wizard on the LG PC Suite take note of the port number that it is using.
Then go to device manager(for win xp go to start/control panel/system, click on the Hardware tab then device manger) on your pc. Expand Ports(COM & LPT) and right click on LGE Mobile USB Serial Port and select properties. Take note of what port is indicated in brackets. Go to the Port Settings tab and select advanced. Change the com port number to what LG PC suite was using. Select OK, OK and try connecting again with the Wizard and see if you can transfer data etc
Let me know if that helped.
Sep 04, 2008 | LG KU990 Viewty
"Already in use..."
Normal 0 Start Skype then Go to "TOOLS", click on "OPTIONS," Then go to "Audio Settings" and click on it. Make sure both the Microphone and Speaker's are correctly chosen. Then "make a free test call." Wait till the voice tells you to record. Then when finished talking wait for the test persons voice to insure your audio transmission is working. Then go back to options and test your video settings. Click on Video Settings and proceed to set up you video camera. Also, you can visit this site for additional information to setup video.
http://www.skype.com/help/guides/video/
Hope this helps. Bud
Jul 21, 2008 | Logitech Webcam
Phone will not connect/communicate or is not recognised by my pc
I had the same problem myself with a v3i, check in the Hardware Manager of Windows if in the Modem section you have a "Standard Modem" listed, if yes, then uninstall it and restart MPT and there, after hitting F6, check the configuration and select the Motorola Modem you will there find (not the speaker modem thing or sth) and it should work.
Daniel Wamara
Aug 23, 2006 | Motorola Mobility RAZR V3
Motorola Mobility RAZR V3 Logo
37 people viewed this question
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
vince
D. E. Hev
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
