Question about Samsung LN-T4665F 46 in. LCD Television
Display problem We are trying to use our flat panel TV as a monitor for our laptop. On the settings screen, the "PC" option is not highlighted, so I can't select it.
    Genius:
  • Samsung Master
  • 1,689 Answers
Make sure that the PC is output the compatible mode for your TV set, and everything is properly connected.
It may be possible that the set has the connector on the rear, but it does not have the option installed from the factory. I've seen this a number of times. Check the instruction manual for under the model number if the option is present.
If the option is in the TV set that you have, the cable is good, and the computer is in the proper mode to address the set, then it is possible that the input processor board in the TV has a fault where it cannot take in the signal from the computer.
Jerry G.
Posted on Jun 28, 2008
I have a 25" JVC
Try pressing Fn + F5 on your laptop to output the TV. Alternatively, on the display driver of your laptop there is a properties to use as a dual output.
Mar 11, 2011 | Televison & Video
I'm trying to figure out how to make the display show on a larger flat screen monitor. Any help would be appreciated. I found where you would change the resolution under Control Panel and it showed 2...
if you are trying to use a lap top to display on a Flat Screen TV, then hook the laptop to the TV with a 15 pin D cable or a HDMI cable(what ever connector you have in common), the switch the TV to PC and then look on your laptop for an ICON that shows a TV set and acomputer screen together. On mine it is hold down the function key and tap the F6 key( Fn+F6) on some computers it is the Fn+F5 key, this switches the display from the laptop out to the TV on to the Aux PC input.
Jan 22, 2011 | Computers & Internet
Video for my Acer laptop will not transfer to my 32 " Dynex TV . Have proper cord pluged into TV and computer and TV is sey on VGA setting ?? What my I be doing wrong ??
On your laptop, while it's plugged into the tv, hold down the Function Key and press the crt/lcd buttuon (Usually the F8 key)
That should cycle between the laptop screen and the tv.
If that doesn't work, Go into your Display settings,
greed03_5.png Where you see the 1 and 2
1 being your laptop and 2 your TV, Click and highlight the number 2 that's shown above.
In the drop down menu where it says "2. Generic PnP........." Click the drop down arrow and select your TV.
Below that, you can either use it as your main monitor by checking the first box. (This will bring up everything on your laptop screen to the tv. You will notice that your laptop screen will still be on too. It''s just cloned the display to the tv.
If you check the "Extend the desktop onto this display" You're laptop will be the main and your tv will be the extension of your laptop monitor....basically it'll be one big monitor.
If you use the extend option, all you have to do is drag and move what ever it is you want to see to the tv.
The way mine is setup, 2 on the left and 1 on the right. i can drag anything to the right of 2. if it was 1 on the left and 2 on the right, i can drag to the left.
if you run into problems like it's not dragging to the side you want, just click and hold on the highlited monitor and move it to the other side and click apply.
Any problems, give me a shout!
Hope this helps!
Dec 20, 2010 | Dynex Televison & Video
I connected my hp laptop to my pioneer plasma via svga cables. When i select my pc input using my tv remote it says "plasma display no input signal". How do I fix this?
Hello. You have to go into your Display Settings, in your HP Laptop, and chose the Dual Screen/Monitor Setting & make sure you check the "Extend my Windows Desktop onto this Monitor" Box. If you are trying to view your Internet Browser on your TV - you will need to Click on and Drag your Browser to the Right... of off your Laptop Screen and onto your TV Screen. This will take care of your problem!
Jan 11, 2010 | Pioneer PDP-5071HD 50 in. Plasma HDTV
Monitor will not display
Your display app controls that, try updating drivers/ software for graphics card on laptop.
Or press the monitor button (usually Fn + something) till it comes right
Aug 08, 2009 | Compaq Presario 705US Notebook
External monitor looks like the computer is in the safe mode
If XP:
Start->Control Panel->Display->Settings tab->Screen resolution->move marker to "more".
If Vista:
Start->Personalize->Display Settings->Resolution->move marker to "high".
Mar 12, 2009 | HP Pavilion dv4000 Notebook
Not able to connect my lap top to to the monitor
the laptop should have a special area under display properties and goto settings you should see 2 screens if not it might need the top addres bar settings change and you will have to choose which screen is the primary and secondary and if you click to verify the screens the screens should have a number of which is the primary is 1 and secondary is 2 on the screen and if you have the icon to change these setting near the clock then try right clicking it and it should be up a option screen and it should should have the option to output to monitor and screen....
Dec 01, 2008 | LG M1910A 19 in. LCD Television
I am trying to hook my 40 inch flat screen by samsung to my dell computer. i unplugged the cpu monitor and plugged it to my tv and the tv states that the mode is unsupported. What do i do?
Your computer is set to a resolution supported by your dell monitor but not the flat screen tv.
The easiest way to get it working is to turn the computer off, connect the flat panel to the computer and then turn the computer on.
To change the resolution of the flat-panel or monitor, right-click on the desktop, click on properties and then select the settings tab.
play with the screen resolution and find one that works best by trying each one and clicking apply. If you select a resolution not supported by your flat panel, computer will automatically revert to the previous resolution in 15 secs.
Feb 26, 2008 | Televison & Video
External monitor
Try going to Control Panel on your computer and going under the display option. Under Settings you will find two monitor options. On the display number two, try selecting that to extend your windows by checking the appropriate box.
Dec 26, 2007 | HP Pavilion ZV5220US (PF143UA) PC Notebook
Samsung LN-T4665F 46 in. LCD Television Logo
Jerry Greenberg
Jerry Greenberg
