Question about LG CU500 Cellular Phone
Device List - Bluetooth
Is there a way when connecting via bluetooth to other phones to stop it prompting to enter a passcode. The receiver must enter the same passcode that you enter for the two devices to connect.
    Problem Solver:
  • 19 Answers
U can select " always allow" option. But before connecting every mobile want a code to which mobile u want connect
Posted on Jan 05, 2008
How do you pair a jawbone to a samsung t259 phone?
To set up Bluetooth on your phone
1. Go to Menu, select Connect or Connections or Connectivity:
Note! If the above steps do not work, please consult the user manual.
2. Bluetooth - Select On to enable Bluetooth.
3. My telephone's visibility - Select Shown to all if you want your device to be found by other Bluetooth devices. If you select Hidden, your device cannot be found by other devices.
4. My Bluetooth name - Define a name for your device. After you have activated your Bluetooth service and changed My phone's visibility to Shown to all, your phone and this name can be seen by other Bluetooth device users.
Sending data via Bluetooth
If your phone supports the Bluetooth 1.1 specification or earlier, you can only have one Bluetooth connection running on your phone at any one time.
1. Select or open the file you wish to send. For example, to send a photo to another device, open the Gallery application.
2. Select the file you wish to send, then select Options > Send > via Bluetooth.
3. The phone starts to search for devices within range.
Devices using Bluetooth technology that are within range will appear on the display. You should see a device icon, the device's name, the device type, or a short name. (A paired device is one where a Bluetooth connection already exists between your phone and the other device.)
• To interrupt the search, press Stop. The device list freezes and you can start to form a connection to one of the devices already found.
If you have searched for devices earlier, a list of the devices that were found previously is shown first. To start a new search, select More devices. If you switch off the phone, the list of devices is cleared and the device search needs to be started again before sending data.
4. Scroll to the device you want to connect with and press Select. The item you are sending is copied to Outbox and the note Connecting is shown.
5. Pairing (if this is not required by the other device, proceed to step 6.)
• If the other device requires pairing before data can be transmitted, a tone sounds and you are asked to enter a passcode. • Create your own passcode (1-16 characters long, numeric) and agree with the owner of the other device to use the same code. This passcode is used only once and you do not have to memorise it. • After pairing, the device is saved to the Paired devices view.
6. When the connection has been successfully established, the note Sending data is shown. Data received via Bluetooth can be found in the Inbox folder in Messaging. Tip: Pairing is a means of authentication. The users of the devices using Bluetooth technology should agree together what the passcode is, and use the same passcode for both devices in order to pair them. Devices that do not have a user interface have a preset passcode.
Checking the status of the Bluetooth connection
• When the Bluetooth icon is shown in standby mode, Bluetooth is active.
• When the Bluetooth icon is blinking, your phone is trying to connect to the other device. • When the Bluetooth icon is shown continuously, the Bluetooth connection is active.
Receiving data via Bluetooth
When you receive data via Bluetooth, a message alert tone is played and you are asked if you want to accept the message. If you accept, the item is placed in the Inbox folder in Messaging.
Disconnecting Bluetooth
A Bluetooth connection is disconnected automatically after sending or receiving data.
Jun 15, 2011 | Cell Phones
Tip
Mobile Phone Contacts Via Bluetooth
<p> <ul> <li>Install the hardware for Bluetooth. If you do not have the latest drivers, download and install them.</li> <li>Insert the software CD that was provided with your mobile phone and download the software. If you do not have this software, you can download it from the manufacturer's website.</li> <li>Turn on Bluetooth on your cell phone. Ensure that it is visible to your accompanying devices. Also make sure that Bluetooth is enabled in both your system and mobile phone.</li> <li>Click on your "Start" button and then your "Control Panel." Double-click on "Bluetooth Devices." Click on "Add Device." Once it is done searching, pick your mobile phone from the list.</li> <li>Choose any of the options on the list if you are prompted to enter a passcode. You may also proceed without using a passcode.</li> <li>Enter your selected passcode if you chose one, ensuring that it is the same one on your phone. Your mobile phone and computer can now communicate with each other.</li> <li>Run the software that came with your mobile phone. You will get options to "Backup" or "Sync" your phone depending on the software and the make and model of mobile phone.</li></ul><br /> <p><br /> <p><br /> <p><br /> <p><br /> <p><br /> <p><br />
on Nov 30, 2010 | Cell Phones
Cant pair device without passcode
Hi, to set up Bluetooth on your phone
The phone will search for a couple seconds. If your headset is in paring mode, it will show up on the phone either with the name of device or something like this [unknown headset] or [b2.c3.f4.56.a1] (called a MAC address).
Either way, select it, and hit OK.
The phone will now ask you for a "Pin" or "Passcode", which is a 4 digit number. Headsets will ALWAYS have 0000 (four zeros) as a pin or passcode. I have never encountered a headset with a different number as a passcode. I have been in wireless for 10 years, and still have not found a headset that has any different numbers.
Enter these four zeros and select "OK"
Hope that helped...
Thanks for using fixya...
Feb 07, 2011 | Cell Phones
Will not connect to my sonyericsson w995
i checked that your phone is compatible wd the parrot handsfree bluetooth.
turn-on your bluetooth of your phone
turn on bluetooth of your parrot handsfree see manual where the buton is located
From the phone:
* Go to MENU / SETTINGS / CONNECTIVITY / BLUETOOTH / MY DEVICES / NEW DEVICE
* Phone will search for available bluetooth devices
* Select Parrot Product from the list
* Enter Passcode "1234" and go to OK
* Accept the pop-up
* Devices are now paired and connected
fleche.gifSending contacts via Bluetooth
Jan 29, 2011 | Parrot Hands-Free Car Kit with LCD Display...
How to on or off bluetooth on w508i. even how to change setting of bluetooth
Hi, To set up Bluetooth on your phone
application.
Hope it helps .
Fill free to pass your comment.
Jan 08, 2011 | Sony Ericsson W508i Cell Phone
Pairing with a motorola bluetooth device
Hello, Barb.
Here are some instructions from the manual:
To set up a Bluetooth connection, do the following:
1. Select Menu > Settings >
Connectivity > Bluetooth.
2. To activate or deactivate the Bluetooth function, select
Bluetooth > On or Off.
Indicates an active Bluetooth connection.
3. To search for compatible Bluetooth audio devices, select
Search for audio enhancements and the device that you want to connect to the phone.
To search for any Bluetooth device in range, select Paired
devices. Select New to list any Bluetooth device in range.
Scroll to a device, and select Pair.
4. Enter the Bluetooth passcode of the device to associate (pair)
the device to your phone. You must only give this passcode when you connect to the device for the first time. Your phone connects to the device, and you can start data transfer.
Hope this helps.
Apr 19, 2010 | Nokia 6085 Cellular Phone
My nikia3110c mobile phone is not working properly
be sure that your bluetooth is turned on, then search for compatible bluetooth devices. Select NEW to list any new devices. once there is a compatible device, PAIR with the compatible device and enter your agreed passcode. try deleting some from the memory. sometimes when the MB of the game your are trying to receive is too large for your memory, you wont be able to receive it.
May 04, 2009 | Nokia 3110 Cellular Phone
How to connect blue tooth from pc to samsung cameramobile?
hi there!
While the specific user interfaces implemented by manufacturers may differ from device to device, there are still some very basic steps to go through in connecting two devices for the first time. Users should always conduct the pairing process in a secure environment.
Charge the Devices
If the devices are new Bluetooth devices, often they must be charged before they can connect or turn on. This is particularly true of new Bluetooth headsets, which must be charged before use.
Power Up the Devices
Power up the devices you are trying to pair. With some devices, like Bluetooth wireless headsets, powering up the device also initiates the pairing process.
Turn the Bluetooth Functionality On
The Bluetooth functionality in a device may or may not be turned on when you receive the device. For many computers, users will need to turn the Bluetooth radio on from the control panel or system preferences.
Make the Devices Visible
As a security measure, some devices allow the Bluetooth functionality to be off, hidden, or visible. When trying to connect devices, users should make the devices visible so the devices can discover one another. After the devices are paired, users can set the devices to hidden if they have concerns about their devices being discovered by others.
Place Both Devices in the Connection Mode
After both devices are charged, powered up, and the Bluetooth functionality is turned on, each device needs to initiate a communication session. Typically, in a connection between two devices, one device acts as the “host” and the other device acts as the ”guest.” The device in the host role is the one with the user interface from which most of the connection setup will take place. A device can be in the host role with one device and in the guest role with another device. For example, in a phone and wireless headset pairing, the phone is the host. However, in a phone and laptop pairing, the laptop is the host.
Enter the Passcode
After the two devices have discovered one another, the user will be asked to enter in a passcode in one if not both of the devices. In some cases, like with wireless headsets, the passcode is a fixed passcode assigned to the headset by the manufacturer. In those cases, the user enters the assigned passcode into the host device. The user will find this passcode in the user manual. In other cases, the user will be able to enter in his/her own passcode. In these cases, the user will enter the passcode once into each device. It is highly recommended that users employ an eight character alphanumeric passcode for the one-time pairing process. After the passcode is entered, the devices will validate one another and complete the establishment of a trusted connection.
Deleting or Disconnecting Trusted Devices
When should a user delete or disconnect a trusted device? If one of your Bluetooth enabled devices is lost or stolen, you should unpair that device with all the devices to which it was previously paired.
How do you unpair or delete a trusted device? For devices like a mobile phone or computer, the user should go into the device connectivity settings and find the list of trusted devices. The user should then have the option of adding a new device or deleting a trusted device. Highlight the device you want to delete and push the delete button. A device like a keyboard or mouse, which only has a button or switch as a user interface, can only connect to one device at a time. To delete its previous trusted device, the mouse or keyboard just needs to be connected to a new device
Or you can try this:
Bluetooth Mobile Phone to Bluetooth Personal Computer
  1. Power up both the mobile phone and the personal computer.
  2. On the PC, open up the control panel and find the Bluetooth Device Wizard. This will assist the user in setting up a Bluetooth connection between the PC and trusted devices.
  3. Ensure the Bluetooth connectivity is turned on in the PC.
  4. Find the connectivity settings of the phone. Make sure Bluetooth connectivity is on and visible.
  5. On the PC, choose to find and add a specific Bluetooth device.
  6. Of the devices found, pick the mobile phone with which to pair.
  7. PC will generate a PIN code.
  8. Mobile phone will ask if you wish to be connected to the PC.
  9. After the user answers in the affirmative, the user will be prompted for the PIN code on the mobile phone. Enter the PIN code into the mobile phone, which the PC generated.
  10. Allow devices to complete the establishment of a trusted link.
  11. If prompted on the PC to choose the Bluetooth services, the user may have several services available. The user may be able to sync the phone and PC. The user may be able to set up dial-up networking (DUN) preferences so that the user can use the mobile phone as a modem for the PC over the Bluetooth connection. The user may be able to transfer files, like pictures or business contacts, between the mobile phone and the laptop.
  12. After choosing which services the user wishes to enable, the user can then finish the connection and exit the setup on the PC.
better yet go to this website: http://www.bluetooth.com/Bluetooth/Products/Devices/Generic_Pairing_Instructions.htm
Feb 16, 2009 | Samsung SGH-E251 Mobile Phone - Black
I can't receive any pictures or songs etc... via bluetooth
Hi! When it asks for a passcode enter 0000 as passcode, it will also ask a passcode from the phone from which you are recieving the files and on that phone enter 0000 as passcode and it will let you recieve the files.
Jan 04, 2009 | Nokia N72 Cellular Phone
LG CU500 Cellular Phone Logo
64 people viewed this question
Top LG Cell Phones Experts
skiffy99
skiffy99
Level 1 Expert
Raphael Josiah
Are you a LG Cell Phone Expert? Answer questions, earn points and help others
