I have a GE profile side x side refrig. (18 months) The outside wall of the freezer is collecting moisture and the cabinet next to the freezer is beginning to get moldy inside. (panty) The temp of the freezer is the amt recommended "0". Any ideas on what to do? Is there a product that I can adhere to the freezer that keeps the moisture off the cabinet? The cabients are built around the refrig and their isn't a lot of room on the sides of the refrig to play with.
Your owners manual , will tell you the minimum clearences for the refrig . If I have 2 refrig's on my test line , less than 2 " apart , both will emit moisture on the sides , depending on the weather . There has to be air flow on the sides and rear . Sorry this doesn't answer your question directly , but there is no product that can be installed , to stop this problem with the refrig . However , you may , pull the refrig out , and treat the faceing wood , with a waterproof paint or sealant . It sounds like this part of the cabinet , will not be seen . Plastic will not work , moisture will just go thru it . Yes , treating the faceing wood sounds like the most logical solution .
