I have an amana refrigerator with and ice maker. The ice maker will not fill with water. I have installed a new ice maker and it still will not fill with water. I have 120 volts going to the ice maker but only have 17 V going to the water valve. HELP!
Is there water or ice in the ice mold? If not put water in
it and see if it dumps the ice after it’s frozen.If there is ice, lift the cut off arm and let
it drop to see if it will start.
If it does dump the ice but don’t refill with water.
Try swapping the wires on the dual water inlet valve. Then
try the water dispenser. The water should go to the ice maker. This will tell
you weather or not the ice maker valve is working and if the line is clear.
The water inlet valve on the back of unit opens when the ice
maker needs water. If the valve doesn't seal good because of sediment or wear
it will continue to drip and when the water reaches the ice maker supply tube
it will freeze.You can take the water
line off the valve and watch to see if it drips.
A strainer before the inlet valve can also get stopped up restricting
flow.
the water and ice dispencer is malfunctioning. this morning it was spewing water all over the...
(More)
the water and ice dispencer is malfunctioning. this morning it was spewing water all over the kitchen. now, the buttons on the face wont work. tried unplugging it and plugging it back in to reset it but that didnt work. its stuck on the ice button now but no ice comes out when i push down the deal. is there a master reset button or anyway i can fix this? this is a jenn air side by side with the model number jcd2289atw
Jenn Air freezer (side by side) does not 'automatically defrost" now, is there a heating coil...
(More)
Jenn Air freezer (side by side) does not 'automatically defrost" now, is there a heating coil or something that could have gone out? Or how do I test what's wrong?, I'm tired of defrosting that thing ever 3 or 4 weeks. If you have pictures/diagrams that would be great too. I'm not a repair man or mechanic just an 55 yr old lady who can't afford repairmen & enjoy trying to fix things myself. Thanks Barbara
makes percolating sound only when freezer door is closed. It stops making the noise when door is...
(More)
makes percolating sound only when freezer door is closed. It stops making the noise when door is open and interior light on
