Question about Frigidaire FRS3R5EMB Side by Side Refrigerator
Water dispenser lever
Where would I buy a lever for a frigidaire glrs237za. The one on there has broken off
  • 1,314 Answers
Any appliace part store can just have right model off serial#plate in top of frigde compartment
Posted on Dec 31, 2007
The ice dispenser on my Frigidaire refrigerator model number GLRS237ZAQ2 will only dispense crushed ice, even with the switch is for cubed ice. Any idea what is wrong?
its right in the manual,rotate the auger 90 degrees till it slides back in the hosing at the back of the freezer and your problem should be solved
Apr 17, 2010 | Frigidaire GLRS237ZA Side by Side...
Water dispenser lever is broken
1st, unplug or turn breaker off for refrig. 2nd, remove the slide out drip tray, 3rd, remove the 3 bottom screws at the bottom of the dispenser bezel (behind the drip tray). 4th, remove the bezel (slide up about 1/4" and pull forward, gently), WHEN DOING THIS BE VERY CAREFUL YOU DON'T ACCIDENTLY UNPLUG THE CONTROL BOARD FROM THE MAIN BOARD. 5th, remove the 3 screws holding the dispenser mechanism in place. 6th, remove the water dispensing hose from the dispensing mechanism., 7th, carefully unplug the power supply to the main board. hold down the clip to do this. 8th, with the dispenser out, remove the water dispenser lever plug from the coil board, 9th, remove the 2 screws for the metal hold downs for the lever pivot.
chances are, you will have difficulty removing the water hose from the dispenser unit. I did. I also had a harder time trying to get it back in. The factory hose is pretty rigid and I figured there mus be a better way. I had some 1/4" clear hose from home depot. I got a piece of 1/4' tubing and made a splice from the factory tubing to the clear, flexible tubing. The flexible tubing allows you to have additional tubing to play with and makes the job much, much easier. good luck
Apr 07, 2010 | Frigidaire Professional Side By Side...
My water dispenser lever broke, how can i replace it
order a new one, it is fairly self evident when the part arrives how to put it in
Nov 01, 2009 | Frigidaire FRS3R5EMB Side by Side...
Ice dispenser lever will not return to off
hi thre,
it was already defective,have replace on it., pull it out,and have it for sample you can buy this on rerigeration and aircondioning supply.where near your place.or have it do by your service technician.have a nice day,don't forget to rate me,thank's a lot
May 02, 2009 | Frigidaire FRS26H5AS Side by Side...
Icemaker not working,water is fine,no water to the icemaker.
What is the temperature inside of your freezer. It has to be at least 17 degrees or below for the ice maker to work.
Dec 21, 2008 | Frigidaire GLRS237ZA Side by Side...
Water dispenser lever on door broken off.
Yes, the levers are easily ordered and replaced.
get manual, obtain part number, order part, replace part. use these websites for help
Oct 15, 2008 | Frigidaire FRS26R4A Side by Side...
Water dispenser lever on Frigidaire
My Frigidaire side by side is a little different from tech17's solution. It has no slots for a screwdriver to pry it off. It is a model FLSC23F6D55 manufactured 3/05. There is a semicircular spill tray in the bottom of the recessed water station. Just pry out the tray, from the bottom corner of the frame from the side and or bottom. (I did this with a knife blade.) This tray is a snap-in fit. Then you will see three phillips head screws in the bottom of the frame. Take out these three screws and remove the frame by lifting up on it and pulling out at the bottom. Then take out three more phillips mounting screws to remove the processor card and key pad. You will then see the top of the water lever mounting. The lever comes out by removing two more screws that hold the pivot shaft of the lever. (These last screws are a little more diffiucult to get to, but not anywhere near impossible.) I wish you well.
Nov 18, 2007 | Frigidaire FRS3R5EMB Side by Side...
Frigidare side by side Gallery fridge
sounds like you water is spilling out instead of going into ice maker... check the inlet spout for ice or other blockage
Oct 10, 2007 | Frigidaire GLRS237ZA Side by Side...
Frigidaire FRS3R5EMB Side by Side Refrigerator Logo
69 people viewed this question
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
