I have tried to change the code on our door lock and now it isnt accepting any numbers at all - ive tried to restore the factory settings but dont know the original default code - help!!! my guests cant access the hotel
enter the factory code
press the first button (1-2) within 5 seconds
enter your new 5 digit code....each number must be entered within 5 seconds of each other
the doors should lock & unlock to confirm the new code is accepted
For Facto, remove the screw on the inside of the door on the door lock to get to the inner portion where you program NB : in order to change the lock code, the chime feature has to be on (3rd little button on right bottom) or it will not change. Make sure the chime is on. Press the program button once and when it beeps, change the code on the outside keypad and press lock. (I suggest you test it before actually closing the door by hitting the lock button. The lock barrel should come out, as if you had locked the door. Hit the lock button on the keypad and key in the new number. The barrel should return inside as if you had opened the door. If not, it did not program the new number. Try programming again.). Press the program button twice to change the second code and when it beeps, change the code on the outside keypad and press the lock. (Again, I suggest you test)
have you tried : Menu . Settings. Page down to restore factory settings. select. It should then ask you for decurity code, and providing you havent changed it, the default security code is usually 12345. Enter the code and off you go hopefully! Dont forget if this isnt the code for your phone, your phone will self lock if you enter it (or any incorrect code) 3 times. Hope this helps :-)
Follow these steps :
1- Save the important file and data on your mobile.
2- Type this code below on mobile screen :
*2767*3855# and wait until operation is finished.
After this operation ,the all lock codes in your mobile will be erased.
This option resets some of the menu settings to their original values. It does not delete data that you have entered or downloaded, or affect entries in your contacts list.
In the standby mode, select Menu > Settings > Restore factory settings. Enter the security code, and select OK. See "Change lock code," The default code is 12345.
