Yamaha rx-v3300 av receiver
G`day guys and girls, when i try to power on the unit, it makes a click noise like nomal. exept the display remains blank and there is no output. i have checked all speaker connections. they seem fine. i have disconected the power for one minute, to see if the unit reset itself. still no result. look forward to your suggestion. thanks.
  • 579 Answers
Old amps with no display (no computer) are repairable for ever, but when the display goes out like in yours - it is pretty much not economically repairable. You can look inside for any obvious damage (black or blown parts) but thats doubtful. Check the voltages on the power supply. Should find 5v, 12v maybe a negative voltage. Could have lost a voltage regulator in the power supply causing the digital circuits to be down. good luck
Posted on Dec 31, 2007
Yamaha RX-V3300 Receiver shuts off on it's own.
A capacitor problem or overheat problem.
Feb 06, 2014 | Yamaha RX-V3300 Receiver
Left channel not working on a or b
Assuming everything is plugged in properly (check the manual to be sure), and you're using a setting that makes use of the left channel (try the Stereo setting to be sure), something has failed within the receiver. This type of receiver isn't designed to be user-serviced. You'll need to send it to a qualified repair shop or replace the unit altogether.
Dec 19, 2013 | Yamaha RX-V3300 Receiver
Yamaha RX-V3300 AC outlets are not working. Everything else works fine. Is there a fuse or reset button? I unplugged unit, waited >30 sec an plugged in again with no change. Thanks.
The total combined load allowed on the outlet is 100W. Make sure you are testing the outlets with a low-current device like a radio or low wattage incandescent lamp (25 or 40 W) or a night light (7 W). Also, be aware that you must have the receiver turned on for the device to work as the outlets are switched according to the main power.
If you still can't get them to work, it could be an issue with the fuse - you should take it in for service.
Mar 26, 2011 | Yamaha RX-V3300 Receiver
How do you reset Yamaha rx-v3300 receivers to factory settings? some of the settings got changed and we are not sure what they were
A reset would REQUIRE you to go through EVERY setting anyway, so why don't you just go through every setting manually and leave the ones that look ok alone?
Page 52 for remote reset
Page 78 for DSP reset.
Mar 13, 2011 | Yamaha RX-V3300 Receiver
Are there fuses i can reach with the RX-V3300 Natural Sound Home Theater Receiver
Look at the Impedance Switch on the back and make sure it is firmly in one or the other position and that it matches the impedance of your speakers.
Make sure no speaker wires are shorted to anything.
Unplug for 30 seconds and try again.
Mar 31, 2010 | Yamaha RX-V3300 Receiver
Just clicks no power. Already checked for touching wires and proper cooling. This unit has worked fin in the same location for four years. Any other ideas?
I had a similar 'drop out' problem with my Yamaha RX-V3300.
Problem- Possibly loose speaker connections.
I have banana connections which I unplugged; tightened speaker terminal connections at back of receiver and then reinserted banana speaker connectors- which remedied problem. There is possibly some kind of loose connection either caused by the banana plugs or at speaker connectors at the back of the receiver, which was remedied (i.e. possibly temporarily) by reinserting the banana plugs.
I also previously thought something was wrong with the main on/off power relay which was 'dropping out' and replaced it, but then 'drop out' problem returned a few days later. I reinserted and tightened speaker connectors, which has it working again.
Dec 22, 2009 | Yamaha RX-V630 Receiver
Input selector on my Yamaha RX-V596 stuck
Hi Dush
Sounds like the processor has locked up in the unit. Try powering it right down from the wall socket for a day to reset, and then retry operation. If that does not work, leave it disconnected for about 10 days to erase backup memory completely and then try again. Good luck. Don't forget to give me a "FixYa" rating if this works. If it doesn't, get back to me in here and we can talk more about it.
Sep 16, 2007 | Yamaha RX-V596 Receiver
Yamaha RX-V2400
Get another receiver! I had the same problem and had the power supply replaced $250 and after 3 months it started doing the same thing.  I just purchased a Pinoeer Elite VSX 90TXV.
Jun 04, 2007 | Yamaha RX-V2600 Receiver
157 people viewed this question
