Question about SanDisk Sansa e250 MP3 Player
Wont turn on
I kept having problems with my e250 so I did the recovery mode that was recommended by others and it completely formatted and everything. However, now my mp3 player wont turn on unless I connect it into my computer. Do I have to let it completely charge or do I have another problem?
  • 758 Answers
If you use the my computer setting to format your player, you need to update the firmware on the device..to do so...go to
http://sandisk.com/Retail/Default.aspx?CatID=1376
Posted on Jan 27, 2008
Need help with recovery mode
Use voluem + method listed below:
These are the most common methods for recovering Sandisk's Sansa Mp3 Players. I have been almost universally successful in recovering Sansa players using one or a combination of these methods. These methods do not work if you are having synchronization or music format issues - they are for recovering a player that will not power up, freezes, flashes, is not recognized by the computer, and a host of other issues.
Reset the Sansa Player first. On most models, restart is done by holding the power button in for 15 seconds or longer. Check your specific manual to be sure. The manuals are available from the Sansa website if they have been misplaced.
Download the Sansa Recovery Tool from the Sansa website.
Format - Erases Everything: Connect your Sansa player to the computer and open Windows Media Player. Click on the Sync tab. Pull down the drop down menu underneath the Sync tab by moving your cursor over the Sync tab and left clicking on the little black arrow underneath the Sync tab. Highlight "Sansa 1GB" (wording may vary slightly), and then select "Format." - this should erase everything.
Firmware Upgrade- Erases Everything: Get the latest firmware upgrade from Sansa - it updates the firmware and erases every song in the player all at once. Note: this method doesn't work if already have the latest firmware. Go to this website and click "Firmware Updater" to find out: http://www.sandisk.com/DriverDownload/driverList.asp
If these fail, then:
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
If you get the problem where MTP Device keeps popping up continuously, uninstall the “MTP Device” by going to Start à Control Panel àSystem à Hardware à Device Manager (you computer may vary slightly, depending on Windows Version).
You may have to restart your computer after each of these methods to get them to work properly. Disconnect your Sansa player BEFORE shutting down your computer.
-Tha Mp3 Doctor
May 11, 2008 | SanDisk Sansa e250 MP3 Player
Wont turn on
Sounds like it could be a problem w/ your battery. You might try removing your battery and blow out any dust or crap thats gotten back in there.
Jan 01, 2008 | SanDisk Sansa c250 (2 GB) MP3 Player...
Sansa 250R ~ It will not reformat
how can i refresh the data base, tks
Dec 27, 2007 | SanDisk Sansa e250 MP3 Player
Sansa e250 not workking
This is the generic solution for most problems.
Run the recovery tool from the SanDisk website. Make sure you select "format" when prompted.
http://rapidshare.com/files/67740173/e200fw01.00.12.exe____
You need to put the device into "recovery mode" before you run the tool.
- Turn the device off (hold power for 20 seconds)
- Slide the hold switch into "hold" position.
- Press and hold the "record" button while connecting it to your computer. Keep holding the "record" button until you see the "new hardware found" on your computer.
Then run the recovery tool. Select format when prompted.
** if it doesnt go into recovery mode, there is nothing else you can do other than have it replaced if its less than 1 year old.
Best of Luck.
Please RATE my solution at the bottom.
Nov 22, 2007 | SanDisk Sansa e250 MP3 Player
Bad Track
Change the Mode on the device and try to format again.
SETTINGS>MODE or USB MODE.
If that doesnt work. This will;
Best of Luck.
Nov 19, 2007 | SanDisk Sansa e250 MP3 Player
MY E250 IS BROKEN
This should solve it;
Best of Luck.
Nov 17, 2007 | SanDisk Sansa e250 MP3 Player
Sansa e260 failing in recovery mode
You can try this.
Best of Luck.
Nov 11, 2007 | SanDisk Sansa e250 MP3 Player
MY SANSA E250 JUST DOESNT START.......
try holding the menu button until it turns off then leave it off for around 30 minutes then try to power it back up. If it still wont turn on perform recovery mode and upgrade the firmwar eof the player if havent done so.
Aug 27, 2007 | SanDisk Sansa e250 MP3 Player
Sansa e250
I did not get the "Swtich to Recovery mode" screen, my screen was stuck on "Bad Track." I formatted the drive (which deleted EVERYTHING), and then i put the songs back on, and it works just fine. Try this, it might help.
May 07, 2007 | SanDisk Sansa e250 MP3 Player
SanDisk Sansa e250 MP3 Player Logo
24 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Computer Repairing
Computer Repairing
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
