Question about Ariston Technologies AW129NA 16 Lbs Front Load Washer
Maytag front loader door will not open
Errror code OE keeps flashing and dinging. Door will not open. I think it is in the rise cycle.
  • Anonymous Mar 25, 2014
    Why does the front load DRYER
    door pop open before the cycle
    is done drying.
    President:
  • 1,314 Answers
Try pause/cancel twice to open door open detergent disp look for a plastic string and pull it
Posted on Dec 31, 2007
I have a Westinghouse Mastermind 711 Front Loader Washing Machine which is flashing OE and the clothes inside are very wet. Can you please let me know what this flashing OE means....Many Thanks, ELena
Hello & Welcome to FixYa
OE is a drain error and is displayed when the washer is unable to drain water. Please check the drain hose and drain pump filter for any clogs to clean the error. Please get back to me if you have any other questions.
Kevin
May 27, 2011 | Westinghouse Washing Machines
My neptune frontend loader will flash the door lock for 2 seconds and then it will go off when ever i start the machine, i think my child opened it with out turning it off.. is something broken
HI- It is possible that the door lock was damaged if someone forced it open mid-cycle. The machine will not cycle unless the door lock engages. Will probably need a to get a Tech out to have a look. Good luck.
Sep 24, 2010 | Maytag Neptune MAH5500B Front Load Washer
I have an lg front loader washing machine...it keeps stopping mid cycle and gives a troubleshoot code of oe...i cant find my owners manual and the lg site is awful....can you help me?
OE is drain error..Most likely problem is partially blocked pump filter...This is accessed via the small door at floor level...Unscrew the pump cover and clear the filter..Any water in the machine will flow from the pump cover...Empty the machine first...Leaning it back can help....Good luck....Nomess
May 14, 2010 | Washing Machines
Front loader AWM 6100 - door open light flashes and won't wash
I think it may have try and get your local engineer out to have a quick look tell your thinking of buying new and what price can he supply 4. and you like a free estimate .
Feb 11, 2010 | Whirlpool AWM6100 Front Load Washer
Please help! My samsung 7kg J845 front loader keeps flashing UE on the error code (spin cycle) and I can't open the door. Sarah
Hi, I have the same washing machine and it flashes UE on the error code during spin cycle when I have one thing in there, or if the clothes are uneven. I usually have to wait until the lock light goes out, re-arrange the clothes and continue spin cycle. If it is just one item in there, I usually have to manually wring it out as it will keep saying error if I keep trying to spin.
Oct 22, 2009 | Samsung WF337AA Front Load Washer
Front loader wm2277hs washer with OE error sign
The LG error code OE simply means “the pump is blocked”.
Presumably the water isn’t being emptied properly.
As with all error codes it is possible that there is a cause other than the exact description in the error code explanation.
And from your original post, I see that you have checked the drain pipe and the pump filter..
Those are the only 2 things I would of asked you to check aswell.
As for the price, I cannot answer that as most manufacturers wont publish their prices unfortunatly.
Sorry I couldnt of offered more help.
Mike
Jun 10, 2009 | LG Washing Machines
Maytag Neptune Front Door Load, Problem
Hello Yery1975
Welcome
You said, you have a situation with my washer machine (Maytag Neptune front loader). It was making the noise several times as latching the door, then if would go off and you could not open the door, You found the under soap deposit cord but the situation is not opening the door or no, it is getting he machine to work. Whichever cycle you press, the door makes the locking noise several times, sometimes the door can not be opened and the lock door light is off, the thing is that whichever cycle you try the numbers on the electronic pad would go down several numbers and then it will again make the door locking noise and will stop there, the start button begins flashing and the machine does not wash at all on any cycle, neither it spins or rinses. Can you please, please, help me? Ohooo... some times after trying and trying get the FL code... you have tried keeping it disconnected from the electricity for long periods, plugging it back and all you can think off.... but nothing!!!
You did the right thing
The Maytag Neptune had a lot of very different defects that Maytag was, and is aware of still.
That is why they discontinued that model .
But if you call Maytag service this time, you may find that it will be one of those defects in their design and an authorized Maytag person will recognize which fault is taking place.
perhaps they may cover the parts if you bring it to their attention.
Thank You
Please remember to leave a rating
Oct 03, 2008 | Maytag Neptune MAH5500B Front Load Washer
Maytag Front Load Washer - SD error
hi there,
it appears that you have a door switch problem. the door latches on these machines are equiped with a mechanical switch and if this switch disengages in any way, the machine thinks that the door is open, even if it's not.
the code that you see is actually a "dS", which stands for door switch.
check the door latch, which is where the door switch is located.
thanks.
Sep 26, 2008 | Maytag Neptune MAH6700A Front Load Washer
Maytag Neptune Washer Door Locked
INSIDE THE SOAP LOADER THERE IS A LIME COLOR STRING PULL IT WILL UNLOCK LATCH
Apr 18, 2008 | Maytag Neptune MAH5500B Front Load Washer
Ariston Technologies AW129NA 16 Lbs Front Load Washer Logo
158 people viewed this question
Top Ariston Technologies Washing Machines Experts
Gerry Harvey
Gerry Harvey
Marvin
Marvin
Oloyede Monsuru
Are you an Ariston Technologies Washing Machine Expert? Answer questions, earn points and help others
