Question about Hyundai ImageQuest HP4240 42 in. Plasma Television
Plasma wnt stay on
Hello, we havent used the plasma for over a year,the red light is on,when we switch tv on, green light comes on, picture flashes for a second, then it goes back to standby, please help
We turn the plasma on the green light comes on then goes to red and the tv will not come on.
  • 1,113 Answers
Power supply fault, really need service manual and multimeter to locate components that are causing the issue.
If it was OK when it went into storage then you may have a dry solder joint on one or more components.
see....
Notes on the Troubleshooting and Repair of Television Sets Version 3.26 (4-Sep-07) Copyright © 1994-2007
Samuel M. Goldwasser
--- All Rights Reserved ---
For contact info, please see the
Sci.Electronics.Repair FAQ Email Links Page.
Reproduction of this document in whole or in part is permitted if both of the following conditions are satisfied:
  1. This notice is included in its entirety at the beginning.
  2. There is no charge except to cover the costs of copying.
TV doesn't work after being in storage So the TV you carefully stuffed in a corner of the garages is now totally dead. You swear it was working perfectly a year ago.
Assuming there was absolutely no action when you turned it on, this has all the classic symptoms of a bad connection. These could be cold/cracked solder joints at large components like transformers, power resistors, or connectors and connectors that need to be cleaned or reseated. By 'no action' I mean not even a tweet, bleep, or crackle from anything. To narrow it down further, if careful prodding of the circuit board(s) and various large components with a well insulated stick does not induce the set to come on, even momentarily, check the following:
  1. Locate the horizontal output transistor. It will be in a TO3 metal (most likely on an older set) or TOP3 plastic package on a heat sink. With the set unplugged, confirm that there is no voltage across C to E and then measure between them with an ohmmeter. In at least one direction it should be fairly high - 1K or more. This confirms that the HOT is probably good. (There is also a slight chance that there is a low voltage regulator in addition to the horizontal output, so don't get them confused. The horizontal output transistor will be near the flyback transformer and yoke connector.)
  2. Trace back from the HOT collector to the flyback and through the flyback to the B+ feed from the power supply. Clip a voltmeter between this point and the HOT emitter. Make sure the leads are well insulated and can't accidentally short to anything. (This test can be performed across C to E of the HOT but if the horizontal deflection were to start up unexpectadly, the meter could be damaged by the high voltage pulses on the HOT collector. But if you can't find the B+ source, it may be worth the risk.) Plug it in and turn it on.
    • If the problem is in the low voltage (line) power supply, there will be no substantial voltage across C to E. You should be able to trace from the power line forward to find the bad part though a schematic will help greatly.
    • If the problem is in the startup circuit or horizontal oscillator/driver, then there will be something on the order of 100 to 160 V across C to E. In this case, a schematic may be essential.
This text refers to CRT tv's but thought it may be helpfull
Posted on Dec 31, 2007
    Sergeant:
    Champion:
  • 347 Answers
Here is a maunal if you think it will be usefull.
reasoner, try to unplug it for some minutes, then conect it back and see f the problem continues.
  • Santiago Vallejo
    Santiago Vallejo Dec 31, 2007
    Hi again reasoner,
    If you cant acces or didnt find usefull the first link here you will find a very good troubleshooting and other links to solve your issue.
    If it didnt work, or you want to ask me somthing feel free to do so.
2 Suggested Answers
jerryg50
  • 1689 Answers
SOURCE: plasma wnt stay on
I have had this problem in some models of plasma sets before. In most cases the power supply and main drive boards had to be replaced. In a small number of cases the failure was the screen itself.
In all cases, the cost of the repair was expensive. For the screen failure, the set was scrapped.
Jerry G.
Posted on Apr 12, 2008
PANASONIC VIERA TH-42PZ82BA 42" PLASMA TELEVISION 1080P Full HD
Your TV is showing symptoms of power supply failure. It needs to be repaired or replaced. The remote has nothing to do with the power supply problem
Mar 21, 2013 | Panasonic Viera TH-42PZ85U 42 in. Plasma...
It switches on ,green light stays on fr seconds then red light flashes, no picture or sound
count the blinks of the light and that will tell you where the problem is located.
Feb 18, 2013 | Panasonic VIERA TH-42PX80B 42 in. Plasma...
Plasma tv green light flashes 5-6 times then stays green but no picture or sound
Remove one at a time the Y sus and Y buffer cables that go to the power board and see if the set stays on then, you may have a distorted pic, replace the board that makes the set stay on...there are some transistors on the buffer board that give issues a lot and I'd guess that's where your issue is at
Jan 27, 2018 | LG Televison & Video
My power comes on, then the green LED light switches to red, and flashes 6 times over and over. I tried the fix on youtube with the IC capacitors for the 50PF9731D/37 even ordered the $1 capacitors but...
I am definitely a girl explaining this because I don't know the correct parts of the tv. Here goes. We had the same problem last year, called philips they advised I do a software update on the tv because that fixes everything....wrong. The light still flashed and no picture. I called them back and they said I had to find a philips tv repair to take it into....got lucky because there was one close by. Come to find out it was some board inside that cost $400 to repair. I thought cool it's cheaper than a new tv! Worked great until about 2 weeks ago the tv turns on and the light is green and picture pops up a minute later. Oh boy more problems! As I sit here right now my tv no longer has a picture. The green light is on but nothing. It's funny because we had it repaired this time last year. I'm fed up and buying a new tv!
Nov 29, 2010 | Philips 50PF7321D 50 in. Plasma HDTV
Plasma tv stopped working
hi i have a pioneer plasma tv pdpro4e all it doses is flash green red green red and on the mediar reciver as well tv dont come on help please
Dec 31, 2009 | Televison & Video
Plasma TV Does Not Turn On - continous Red Flashing Light
Had a similar problem with my Sony. Unplug for 36 hours and try again.
Aug 29, 2009 | Philips 50PFP5332D 50 in. Plasma...
Flasing red light where the on light is
I have a philips pf50 9630a/37 tv may come on or it may not unplug it and take a chance then comes the 6 steady red flashes followed by 3 rapid red flashes the screen had been completely replaced by philips a year and a half ago
Mar 22, 2009 | Philips 50PF7321D 50 in. Plasma HDTV
VIORE LCD TV/DVD won't turn on
19 in wont turn on. red light just solid , unplugged for a day still same , is there a reset button
Aug 18, 2008 | Televison & Video
Philips 42" Plasma TV
no se como instalar la cam en miportatil
Apr 03, 2008 | Philips J44414
Plasma wnt stay on
Jerry G.
Dec 30, 2007 | Hyundai ImageQuest HP4240 42 in. Plasma...
Hyundai ImageQuest HP4240 42 in. Plasma Television Logo
74 people viewed this question
Top Hyundai Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Marvin
Marvin
Are you a Hyundai Televison and Video Expert? Answer questions, earn points and help others
