Turn it off and on to print mode, hold down the %(set) button until it prints something. Then type in ur new tax rate (like 7% would be 7) and push tax+.
Question edited for clarity.
Question moved to model category.
Solution 10345: Using the Tax Rate Functions on the TI-1795 SV.
How do I use the tax rate functions on the TI-1795 SV?
Refer to the below instructions on how to use the tax rate functions of the TI-1795 SV. To set the tax rate:
1) Input the tax rate, for example, 6
2) Press [RATE]
3) Press [Tax+] To recall the tax rate:
1) Press [RATE]
2) Press [Tax-] To use the new tax rate in a calculation:
The following examples demonstrate how this is done on the TI-1795 SV (assumes the 6% rate in the above example has been set). Example: $12.00 + 6% = $12.72
1) Input 12.00
2) Press [Tax+] Example: $12.72 - 6% = $12.00
1) Input 12.72
2) Press [Tax-]
https://education.ti.com > general-information
Refer to the below instructions on how to use the tax rate functions of the TI-1795 SV. To set the tax rate: 1) Input the tax rate, for example, 6
go to PGM 3 then go to 1- Machine Feature go to 9-Tax Table go to 1- tax table 1 set tax rate to 5.0000 set Rounding to Round up set singapore Rounding to Round up if you are not using the 1 cent anymore set calculation Type to Table and Add on
Press ESC to go back to Tax Table window and choose 2- Tax Table 2 repeat the same steps as for Tax Table 1 but set the tax rate to 9.98
Please tell me how to do "TAX calculation".
A2
1. How to set "Tax Rate"
(1) If "Rate set" is printed above [%] key with your calculator, 1. Press [AC] and hold [%] for about two seconds. 2. Input Tax Rate and then [%]. * You can check Tax rate by pressing [AC] and then inputting [TAX+]
(2) If "Set" is printed above [%] key with your calculator, 1. Press [AC] and hold [%] for about two seconds. 2. Input [TAX+]. 3. Input Tax Rate and then [%].
2. How to calculate Price-plus-Tax and Price-less-Tax. (1) How much is Price-plus-Tax of 100? Press [AC], and input 100 [TAX+]. (2) How much is the Price-less-Tax of 105? Press [AC], and input 105 [TAX-].
Press the red "ON" button and hold it.
Press and hold the "% (SET)" button and hold it.
Release the red "ON" button.
Continue to hold the "% (SET)"
After a few seconds, "SET" will appear at the top of the screen.
Press the "TAX (TAX RATE)" button.
"M TAX SET %" will appear at the top of the screen.
Your current tax rate will now be shown in the display.
Enter new tax rate and press the "% (SET)" button.
Your new tax rate is now set.
press AC press RATE SET, hold for approx5 secs till you see "tax" "%" displayed type in new rate (say 20) press RATE SET (to confirm 20% as new tax rate)
SETTING YOUR TAX RATE you hold your set % button down for three seconds until set shows again, then hit tax rate button it shows your tax rate, change your tax rate then hit set your tax rate should be set.
cliff notes: hold set% button hit tax+ button change the desired % hit set done Do rate the solution.
1. Switch off the calculator
2. Switch it on again
3. Press and hold the tax button (set %) until the display changes
4. Enter the new tax rate
5. Press the tax button (tax +)
Any problems contact [email protected] - he emailed the solution to me and it has worked.
