Question about Panasonic AG-DVX100B DV Digital Camcorder
Panasonic DVX100B won't even turn on or reject tape after battery
I have DVX100b. I switched the battery out and now, it wont even turn on or reject the tape. I put the camera on the power outlet and that didn't even work.
Its completely dead. Any suggestions? How much does it cost to repair this problem? Should I contact Panasonic and send it to their repair center? Or does anyone have any recommended DVX100b repair places?
  • 1 more comment
  • Anonymous Oct 15, 2008
    same problem I'm going to try useing the auxiliary 2.1 mm power input located next to regular power input and or call a local technition.
  • Anonymous Oct 17, 2008
    i have the exact same problem. i was told this issue was related to the larger size batteries, however, i have since purchased smaller batteries with no luck. would like to know if anyone has found any solutions.
  • Dave Soucy
    Dave Soucy May 11, 2010
    Does the light on the battery charger/power supply light up?
SOURCE: How to use a panasonic DVX100B in the dark?
Your best solution is to get a on camera light or a 3 point lighting system but that can get quite expensive. Another solution is making a couple of adjustments on the camera which allow more light into the camera. Please note this will not give you any kind of a night vision type of thing and you really can't "shoot in the dark" but you can shoot in low light, this process will allow more light into the CCD's producing a better image in low light. What you are going to do is: 1st make sure the ND Filter is on the OFF position. Next you are going to want to find the IRIS button it is located to the left of the LCD monitor. Next open the monitor and press the iris button and make sure it is set on manual. After doing this, turn the iris wheel (next to the iris button) all the way down you will see it go from F-(what ever the number is) to OPEN. That will open the iris all the way allowing the most light into the camera possible. If your image is still too dark then find the GAIN switch is is located on the same control panel as the iris button. You will see 3 selectors, L (Low); M(medium); and H (High). First switch it to medium and if it is still too dark, crank it down one more to High (please note that turning up the gain lowers resolution). This is really all you can do in low light with the Panasonic DVX100b. Hope this helped!
Posted on Apr 02, 2009
kd24911
  • 90 Answers
SOURCE: No sound when recording
Please get your microphone tested, also, you can try testing the recording using external microphone.
It seems that the problem is with microphone contacts or internal loose connections.
Seem to be a minor one, hope it will be resolved with above methods.
Thanks.
Posted on Jun 17, 2009
electronios
  • 126 Answers
SOURCE: My Panasonic DVX100B: Loading deck won't eject the cassette
sorry but if so, the best you can do is to replace tape mechanism unit,there is no way to repair it is not so expensive part though.
Posted on Oct 14, 2009
Tnsiouxfalls
  • 617 Answers
SOURCE: HI, I recently purchased a
http://catalog2.panasonic.com/webapp/wcs/stores/servlet/ModelDetail?storeId=11201&catalogId=13051&itemId=94944&catGroupId=14571&surfModel=AG-DVX100B&displayTab=R
Pages 54 to 60 talk about transferring to a digital converter box.Remember this is an analog camcorder that records to a tape,you will need a digital converter to plug into your computer.Computers only work in digital,analog signals are not understood.My converter was only $25.It's Very time consuming downloading to your computer,it's done in real-time.Minute for minute,hour for hour.I've got 50 tapes to convert and it takes forever..............!
Posted on Jan 14, 2010
electronios
  • 126 Answers
SOURCE: How to clean Heads of DVX100B
Hello there! This kind of tape is abrasive and so when it starts to rotate the S-post is not rotating one and the tension gets higher than it use to be with a normal tape.The best solution for this problem is to rotate upper drum slowly by hand carefully and spray towards it a head cleaning spray.Then wait for 15 min.and blow hot air from a hair dryer inside mechanism for 10 seconds ,and by this action no more droplets will stay on the drum surface.Attention when you put the first tape wait for 15 seconds in pause or stop mode and after push REC or PLAY button.
Posted on Feb 02, 2010
Tape door won't close because tape tray won't go down
If the battery is charged, and the power is on, it may be jammed and in need of cleaning. If that is all normal the motor for the tape door may be damaged or has died. Insure tape position is correct and only push where marked.
Oct 03, 2015 | Panasonic AG-DVX100B DV Digital Camcorder
HI, I recently purchased a dvx100b. I hook it up to my computer via a firewire cable. For some reason my computer doesn't seem to communicate with the camera.
Jan 14, 2010 | Panasonic AG-DVX100B DV Digital Camcorder
How to connect lavalier mic to panasonic dvx100b
Pretty easy, connect it to the xlr connector (hope your lav do have xlr connector) then swith the external mic switch on, phantom power switch to on, and front switch to mic (not line) and ajust the level.
Sep 14, 2009 | Panasonic AG-DVX100B DV Digital Camcorder
DVX100B Batteries won't attach
you probably broke off the retaining button that is above the battery when installed that says Push to Release.
Apr 23, 2009 | Panasonic AG-DVX100 Mini DV Digital...
Apr 23, 2009 | Panasonic AG-DVX100B DV Digital Camcorder
Jan 05, 2009 | Panasonic AG-DVX100B DV Digital Camcorder
Time code problem -- footage disappearing
Menu setting - the time code is simply resetting itself.  If you intend to edit your footage with NLE software this will be a problem, otherwise no issue.
Jun 08, 2008 | Panasonic AG-DVX100B DV Digital Camcorder
The camera rejects the tape, I canĀ“t get it in
Have you tried a different tape? are you going from outside to inside? might have condensation just let it sit for an hour.
Dec 03, 2007 | Panasonic AG-DVX100B DV Digital Camcorder
How to download to pc
Put it to the bin - dawnted product
Oct 21, 2007 | Panasonic AG-DVX100B DV Digital Camcorder
DVX100B has no picture, no output on screen or to my laptop
Try a cleaning tape. It doesn't take much dirt to lose video playback with DV.
Jun 26, 2007 | Panasonic AG-DVX100B DV Digital Camcorder
Panasonic AG-DVX100B DV Digital Camcorder Logo
118 people viewed this question
Top Panasonic Video Cameras Experts
Kenneth Walker
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Panasonic Video Camera Expert? Answer questions, earn points and help others
