Question about Sylvania 6319CE 19 in. TV/VCR Combo
Sylvania (message on screen)
Sylvania tv - emission protege par pg-tv pops up. How do I get rid of this? Very annoying.
SOURCE: 32 inch sylvania tv
This problem is caused by your TV's V-chip setting.
To fix the problem:
Push the "Menu" button (on either the remote or the TV's fromt panel).
Use the "Channel Down" button to go to "V-CHIP SETUP"
Use the "Volume Up" button to select it.
In the V-chip setup screen, the rating that is selected by the user as viewable will allow that rating and only lower ratings to be viewed on that TV. (If TV-G) is selected, then any programs rated higher than TV-G will be blocked.
So, the easistway to get rid of any blocking is to set the rating to TV-MA (mature), and then any and all programs will be viewable on that set. Select "TV-MA" by hitting the "Volume Up" button after you have scrolled down to that rating with the "Channel Down" button.
Then hit "Menu" to exit out of the settings and saave your changes.
Posted on Jun 16, 2008
SOURCE: Sylvania 6313CB 13" TV/VCR replacemnt remote
We have a Sylvania 6313CB TV/VCR combo.  I bought a universal remote and the code would not work when I tried to program it to the "TV" button using all those possible codes listed in the books.  So, on the universal remote, there was a button named "VCR" and when I programmed in the code "0000" all worked.  This was a $6.00 universal remote named "One For All"  we bought at the Big Lots store.
Specifically, here is what I did:
Turned TV on Pushed the "VCR" button and light blinked once Pushed and held the "set" button until it blinked twice Released the "set" button and entered the numbers "0000" Pushed the on/off button and it worked including volume, channel up/down and channel change by entering the channel number.
Hope this works for you too.
Posted on Jan 16, 2009
SOURCE: PS3 (Pal) won't connect to Sylvania HD TV
I just figured it out last night - if you have used your playstation on an hd tv previously, it is set at the highest resolution possible - 1080p. You need to take it back to that tv, and go to display settings on your tv. If you select HDMI as they type of connection you'd like to make, it asks you what resolution your tv supports. In your tv instruction guide, it should give you this information. Check mark all of the resolutions your tv supports, making sure not to confuse 1080i and 1080p. After doing this you can take it back to your other television and it should work.
Posted on Feb 17, 2009
pgh_pa_guy
  • 2992 Answers
SOURCE: how to get wii game to work on tv i have a sylvania tv
The Wii console should have included a cable to plug into the AV Multi-out Connector. This cable has the plug for the Wii on one end, and three RCA plugs on the other. They are color-coded yellow for the video output, and red and white for right and left channel audio outputs. These plugs would go into the corresponding RCA input jacks on your TV (if it has them), and you would select that input using the TV remote or front panel buttons.
If your TV doesn't have A/V inputs, you need to get an RF converter. This device takes the A/V signals from the Wii and converts it to a signal on channel 3 or 4 so you can tune it in on your TV. These cost around $15 at Wal-Mart and other retailers.
If you have lost your Wii connecting cable or didn't get one, you can order replacements from online vendors.
Posted on Apr 01, 2009
SOURCE: universal remote code for a sylvania tv/dvd Model
I went to Radio Shack an purchased a 15 dollar Phillips universal remote and it worked after entering one code for sylvania combo tv's. I did the Happy dance and now I can watch my tv again.
ONE FOR ALL® URC6131n Universal Remote Control
JiggyChic
Posted on Apr 23, 2009
I own a Sylvania 6620LDF 20 in. EDTV-Ready LCD TV/DVD and my cousin punched the screen and a big amount of color lines are popping out no image comes out, crak is still there, tv can still turn on but no...
When he hit the screen, he most likely broke through the protective glass screen and broke the lcd screen that displays your picture. It's probably better for you to just replace the tv itself, it'll be more costly to repair the tv than to replace it.
Mar 06, 2011 | Sylvania 6620LDF 20 in. EDTV-Ready LCD...
Have URC-4330B03 want to program 13in sylvania TV
here's a link to the manual in pdf format: http://www.remotecentral.com/cgi-bin/files/rcfiles.cgi?area=other&db=devices&br=oneforall&dv=universalremote&md=urc43304devicebigeasy&kw=&st=&ar=&dt=&so=&pg=2&file=others/one_for_all/urc4330-manual.zip
Jun 20, 2009 | Sylvania Televison & Video
Need replacement lcd screen for sylvania 32"
Im nned tio find the location to download the soft ware for my wireless sound system Sylvania wireless sound system sa86011 ?
Feb 13, 2009 | Sylvania LC320SS9 32 in. LCD TV
Remote codes
Hello thank you for choosing FixYa.com for your answer my name is David.
I have found a list of codes for the rcu600m for the sylvania tv here they are
Code For Model RCU600M
Code 004 for Sylvania TV Code 006 for Sylvania TV Code 008 for Sylvania TV Code 019 for Sylvania TV Code 062 for Sylvania TV Code 068 for Sylvania TV Code 069 for Sylvania TV Code 075 for Sylvania TV Code 076 for Sylvania TV Code 077 for Sylvania TV Code 088 for Sylvania TV Code 116 for Sylvania TV Code 130 for Sylvania TV Code 132 for Sylvania TV Code 134 for Sylvania TV Code 161 for Sylvania TV Code 183 for Sylvania TV Code 196 for Sylvania TV Code 353 for Sylvania TV Thank you again for choosing Fixya.com
Was this solution helpful? Show your Appreciation by rating it:
Nov 08, 2008 | RCA RCU600M Remote Control
Programming it to a Sylvanvia TV model 6420FF
HOW CAN I GET PROTECTED PROGRAM TV-PG OFF MY TV?
To fix the problem:
Jan 27, 2008 | Sylvania 6432TE 32" TV
32 inch sylvania tv
To fix the problem:
Nov 23, 2007 | Sylvania 6432TE 32" TV
Sylvania 6319CE 19 in. TV/VCR Combo Logo
144 people viewed this question
Top Sylvania Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a Sylvania Televison and Video Expert? Answer questions, earn points and help others
