Question about GE JVM1650 1000 Watts Microwave Oven
Cooktop light - night light only
This is in regards to the lights underneath the unit that illuminate the range top below. There are two light level settings, High and night light. When the light button is pushed and "high" setting shows on the display, there is no light, but when you push it one more time, the night light comes on. Ive tried replacing both bulbs at the same time and also unplugged the unit to see if that would "reset" anything, neither changed the issue.
  • 1 more comment
  • russbt Feb 10, 2008
    night lights or exhaust fan will not work, everything else is operating great
  • Anonymous Mar 18, 2008
    The microwave works fine but since I tried to change the cooktop light bulbs the new bulbs I've purchased do not work at all. The GE microwave is fully funtional outside of the cooktop lights.
  • denisstjean6 Jan 06, 2009
    GE microwaveJVM1860
  • GE Master
  • 9,098 Answers
We see this a lot. The problem is on the control panel, which we regularly repair nationwide for $39.95 postpaid.
This light failure often occurs when a bulb goes out and the filament shorts, or when the bulbs are removed or installed without first unplugging the oven from the power line. Either can cause such a failure on the controller.
Details of our service and critical safety information and disassembly information is at our site, and our link is at our listing here on FixYa: http://tinyurl.com/yzjozk
We're happy to help and we appreciate your thoughtful rating of our answer.
Posted on Dec 31, 2007
TYPE BULB FOR PANASONIC NNP295 COOKTOP LIGHT
Halogen Cooktop/Night Light Replacement
Be careful as the Cooktop Light Cover and the bulb may be
hot.
1. Unplug microwave oven or disconnect power.
2. Loosen the screw to open the Cooktop Light Cover.
(Be careful not to lose the screw.)
3. Replace the old bulb with a new one.
(use Max. 125 V, 30 W, Wide Pin Capsule Type/GY8.0~9.0
recommended)
do not touch a new Halogen bulb with bare hands.
Fingerprints may result in shorter life. Remove fingerprints
with alcohol.
If this bulb is not available locally, contact your local
Panasonic dealer. Part number is F612E6Z00AP.
4. Reinstall the Cooktop Light Cover with a screw
Dec 02, 2014 | Panasonic Microwave Ovens
Tappan microwave vent motor and cooktop lights not working
see this test . God bless youThis microwave oven repair is only for over the range(OTR) models. First, with microwave still installed, gain access to the control board and check for voltage from the fan relay. If you are not getting voltage from the fan relay on the control board, and your display says fan is on, then you need a new control board.
Again, this microwave oven repair is for OTR models. If you know your light bulbs are good and your display is telling you that they should be on, check the light relay on your control board. If no voltage is found at that relay, then replace the control board. Otherwise your problem is in the light socket, wiring, or wire connectors. You can get to all of that by unscrewing 6-8 screws under the unit and taking the bottom panel off.If voltage is present and the wiring that you can see looks good, then you will have to take the unit down and test for voltage at the fan itself. If the voltage is present there, then test the motor itself and/or start capacitor for the motor. The fan motor assembly will slide out of the top of the unit after you take it down and unscrew 2 screws. Below, in the list of component testing, you will see how to test the motor and start capacitor. get the part from
www.repairclinic.com
Apr 04, 2013 | Tappan Microwave Ovens
Advantium display reads "nite"
The first thing I would suggest is a hard reset. Unplug the unit for a minute or so. Then plug it back in, set the clock and try again.
If that doesn't work, leave it unplugged for about 5 minutes. Feel free to contact me directly (see below) if you have other questions.- William E. Miller, AS-EET
pupista@gmail.com
http://www.MicrowaveControl.com
Microwave Oven Control Panel Repair Nationwide
"Recycling by repairing since 1982"
Nov 30, 2017 | GE Advantium 120 Convection/Microwave Oven
Elec-ignighter on gas stove top not working
Here is a tip that I wrote to give details about why your cooktop will notspark to light the burners..
Cooktop Range Stove spark ignition does not work
heatman101
Aug 20, 2011 | Microwave Ovens
I have a jenn-air stove The igniter went out on all 4 eyes on the cook-top
Here is a tip that I wrote to give details about why your cooktop will not spark to light the burners..
heatman101
Dec 25, 2010 | Microwave Ovens
Although I have changed the light bulbs, the lights that illuminate under the microwave onto the stove top will not work. This is a Kenmore over the stove Microwave Oven Model 721.80592402. Have their...
We see (and repair) this a lot. The problem is on the control panel, which we regularly repair nationwide by mail for $39.95 postpaid with a one-year guarantee.
At our Web site, you can get details of our service, plus we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
The lights can can be inoperable or stuck on or stuck in "night light" mode. Sometimes this will similarly affect the fan operation or inside light, too.
Sep 08, 2010 | Kenmore 80599 Microwave Oven
Panasonic NN-P295 Cooktop Light not working
We see (and repair) this a lot. The problem is on the control panel, which we regularly repair nationwide by mail for $39.95 postpaid in about a week.
This can often also affect the exhaust fan operation, too. The lights and fan can be inoperable or stuck on too.
Feel free to contact me directly (and please remind me of your full model number) for more information & help.
William E. Miller
prototech@usa.net
http://www.microwavedisplay.com
Jan 23, 2009 | Panasonic NN-P295SF Microwave Oven
No power
I would say a cooktop lamp got shorted by the moisture.
Assuming your circuit breaker is good, the main problem would probably be a blown 15A or 20A ceramic fuse inside the unit.
Once that's replaced, if the hood lights and /or exhaust fan still don't work, then your control panel would need to be repaired, which we do for $39.95 nationwide.
If you or someone you know decide to work on it, we have *critical* safety, disassembly, and troubleshooting info at our site, and our link is at our listing here on FixYa: http://tinyurl.com/yzjozk
If and when you remove or install cooktop lamps, the power to the oven must be unplugged or turned off at the breaker.
Mar 15, 2008 | Goldstar MV-1526 Microwave Oven
LG MP- 1482s INTERNAL LIGHT CHANGE
Manufacturers used to include access panels in the rear or side so you could easily change the bulb. That exposed the customer to 110V connectors, and that posed a real liability threat, so they stopped using them.
You now must generally remove the outer cover to replace the bulb.
In many over-the-range models, that can mean having to take the oven down from the wall! For safety's sake, that should be a two-person job and it's really helpful if you have your original installation instructions to do this.
Many models use one halogen lamp to illuminate the cooktop and another to illuminate the cavity. You must not touch them with your bare skin as the oils will shorten the bulb life.
Dec 01, 2007 | LG LRM1230W Microwave Oven
GE JVM1650 1000 Watts Microwave Oven Logo
171 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
vince
D. E. Hev
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
