Question about JVC GR-DVM50 Camcorder
JVC Gr-DVm50 switch/button broke
My GR-DVM50 has done great over the years. But now the on/off and play swtich/buttons have come off. There is a ring that turns Play, Off, Camera, 5 Sec and a round rocker switch that controls Record, FF, Rew, Stop. Both came off and won't go back on. I tried snapping it in but it won't stay.
Any suggestions on how to fix or get new parts?
  • knightf Feb 24, 2008
    Exact same problem with my GR-DVM50. Any help would be appreciated. Too good of a camera to junk.
  • kalajian Dec 28, 2008
    Mine just poped off exactly as you described after 9 years! It has really held up on all fronts, it has been dropped and banged around a few times. I opened up the cover and witnessed the construction of the wheel that poped off.... it is in my opinion a bad design.
    I am very handy so I am going to attempt to finagle something and secure it. I will report back if successfull.
    If anyone else has had success, pls do share.
To fix the problem you need to replace 2 parts. The first part is the centre round rocker switch and the other part is inside the camera. It looks like a very thin, flat round aluminum disc.
The disc has 5 holes in it that matches up the with the small black points on the back of the round rocker switch. It's a very bad design fault with the camera because how it's held in place is simply a matter of aliening the rocker switch black points with the five holes you can see and push it in tight.
After years of use the five plastic points wear down and become to thin because of all of the moment or the holes they fit into gets worn out and then there is no contact for the rocker switch to be held in place.
Hope that make sense
Posted on Mar 15, 2009
Posted on Apr 06, 2009
I have the same issue. I was told that they entire cover would have to be replaced at a cost of over $200. This was about a year ago. I couldn't get any assistance from the factory. I have since found out that this has been a high frequency problem with this model.
Posted on Jul 23, 2008
10 year old recordings on mini-DV tape JVC 60ME shows pixilations. This is worse on the first half of the tape than the last half. I have rewound the tape a few times and it does help some, but I still...
This is usually caused by an oxidized or defective Audio/Video drum. Try running a cleaning tape through the camera. If this does not solve the problem the camera will need to be repaired qualified service technician.
My name is Rick and I'm a professional repair technician with over 20 years in the business and have repaired many of these. I'm semi retired and work from home with little overhead so I can keep repair costs low. If you decide to have the camera repaired, please click HERE for a directory listing that suits your needs.
If this response has been of any help to you, please be sure and give a positive vote for me on .
Sep 20, 2010 | JVC GR-D240 Mini DV Digital Camcorder
I'm getting an E04 ( error) when I try to record or play
Here is some information regarding the E04 error message from
"JVC notes that you are also given a malfunction code when the unit is placed into safeguard. If it displays code 01, 02, or 06 you should remove
the battery and powersupply and wait for a while. Code 03 and 04 indicate that you should eject and reinsert the tape.
If neither of these solutions work, your only alternative is to bring it to a shop or send it to JVC for diagnosis or repair. Unfortunately, there is no other way to clear the condition."
This doesn't seem uncommon, and indicates a bad tape is loaded, or unfortunately, that the camcorder requires servicing.
May 22, 2009 | JVC GR-DVM50 Camcorder
Shows fault E04 remove & reattach battery
Do a search of this problem and you will ind that every JVC owner is having the same problem. I finally got mine "reset" by powering the unit on in payback mode while holding down the "play" button. Then, turn it back off and power it on in the camera mode while holding down the "rec" button. This seems to have reset it and I've not had anymore issues SO FAR!
Good luck with it.
Apr 28, 2009 | JVC Video Cameras
JVC GR-DX97 Zoom Control Button on top
You have a bad zoom unit/zoom controller. It is common on these units.
Oct 22, 2008 | JVC GR-DX97 Mini DV Digital Camcorder
Download mini DV tapes to my PC?
You need a Fire wire port to download your videos. It works very well
Jul 23, 2008 | JVC GR-DVM50 Camcorder
Flickering screen from lens but ok in playback mode
Just ring them up, send out your camera and in a week or two it comes back working fine! I have done it and can say that JVC support is A*
Apr 14, 2008 | JVC GR-D31EK Mini DV Digital Camcorder
the only way you could remove it manually is by removing the covers and applying power to the capstan motor its alot of work.
Nov 17, 2007 | JVC GR-DVM50 Camcorder
I'm looking for internal spares for jvc GR D290 camcorder
No spare and no repair now you have opened it. Water damage is likely to have done more than you describe any way.
Aug 05, 2007 | JVC GR-D290 Mini DV Digital Camcorder
JVC GR-DVM50 Camcorder Logo
212 people viewed this question
Top JVC Video Cameras Experts
Larry Stiles
Larry Stiles
Are you a JVC Video Camera Expert? Answer questions, earn points and help others
