Question about Panasonic PT-56HX41 56" Rear Projection Television
48" sony KP-48570
I had a repairman out and he said the convergences were bad. The blue green and red. He said it would cost $550.00 to fix it. I can't afford that. The tv has like ghosts. For instance instead of seeing 2 eyes, you see 4.
Two ontop of two. He said everything else was good on the tv. If this is what's wrong with the tv where do I buy the part and how do I know which part to take out and put the new one in. He said I could buy the part but then you have to focus the tv. I just think I need some advise. Serial # on this is 9008041 RA-3. It was manufactured in Nov. 1999.
bestdarngood
  • 3037 Answers
SOURCE: Projection HDTV Pansonic 47" Curving blue and green colors on top and bottom of screen.
You will need to replace your two convergence I.C.s.They are two large IC mounted on a large aluminum heat sink.Replace both,look for any burned resistors near them,replace those if needed,and readjust your convergence. Good Luck
Let me know if you need any further help
Posted on Mar 29, 2008
  • 3 Answers
SOURCE: Problem with HD feed from satellite receiver
I just had my HD DTV installed this weekend, you have to leave it on 480p. I too purchased my tv in 2002. Per DTV, its an older model and you have to stay with the 480p to get the best possible picture. I have to admit, don't know what the 1080i looks like, but 480p is showing me a very good picture. Best I have ever seen on my TV.
Posted on Jul 21, 2008
SOURCE: Sony KP 53v75 blue convergence will not adjust
My Akai PT 5598HDI has too much red and is dominant and convergence board IC's has been replaced. No significant result. On the convergence adjustment on for red is very focused in the center and very brigth and dim along the borders while blue is very dim and blurry. Focused has been adjusted. Your thought.
Thank you,
Rey
Posted on Dec 01, 2008
  • 4234 Answers
SOURCE: convergence problem ,Help Please
Something is not right here. Is there any possibility that you can get the circuit designation (Rxxx) of the resistors that were "incorrect"? I am not aware of anything like this that can cause the "memory to be erased". The only memory in that area would be the factory convergence settings which can be modified from the service menu. Please try to supply the resistor IDs and I'll check on this.
Thanks,
Dan
Posted on Feb 13, 2009
  • 41 Answers
SOURCE: blue & red ghosts
Sounds like your convergence outputs are bad and you may also have some low value resistors that need replaced. That set probably has 2 outputs. Both will need replaced even if only one is defective. Kinda like headlights, if one is bad, the other isn't far behind it. Excessive heat kills the amps after a few years of use.
Posted on Jul 18, 2009
Have three different color images (red,blue,green)
It is symptom of convergence output ICs failure, replace convergence output ICs located on D board to fix this problem.
Call local tv repairman to replace defective ICs if you do not have prior experience of electronics stuff repair.
Thanks.
Dec 15, 2010 | Sony KP-51WS500 51" Rear Projection...
We have a Sony KP-48S75 48 rear projection television The picture has colors of blue, green, and red around the figures on the screen. what is wrong. Can this part be replaced without going to a...
Its convergence ICs, the STKs gone bad. The repair can be done only by person who knows about PCBs with embedded components. and good with soldering. You can down load the service manual for your tv from this fixya site tech support and decide how you would like to do it. You can check for costs and more FAQs on www.fixurtvs.com. If you are not sure best bet is to go for professional repair. Thanks if you took time to vote for me.
Mar 21, 2010 | Sony KP-48S75 48" Rear Projection...
Getting red, blue and green halos around images
I had a similar problem with red halos around images on my Hitachi rear projection TV. The problem was that the red convergence chip burned out. I replaced that and that fixed the problem. I found several forum posts on similar symptoms and fixes for Sony rear projection TVs by searching for "Sony rear projection convergence problem." Likely you've already tried the auto-convergence function for your set, if it has that.
Feb 28, 2010 | Sony KP-46WT500 46" Rear Projection...
I have a Sony wide screen (rear projection) and blue is starting to bleed thru all the other colors. I called a repair man and he told me it was the tube. He went further and told me the tube may not be...
common failure of this one is convergence.when unit is on does the blue or red not sit ontop each other.go into menu find convergergence see if you can adjust the red onto green then blue onto green.if not you have bad convergence ics part number STK392-560 use STK392-570,also check pico fuses(yellow) all 5 amp location ps8006,ps8002,ps8004
Sep 24, 2009 | Sony KP-46WT510 46" Rear Projection HDTV
Blue and red work good the green bows up and down on end
This is a convergence problem that could be as simple as bad connections on the pins of the convergence ICs or defective ICs. If you can solder, you can fix this yourself. The parts should be around $25-$50. Let me know if you wish to attempt this repair and I'll supply additional details and instructions.
Dan
Nov 17, 2008 | Sony KP-57WS500 57" Rear Projection...
Blue convergeance
Can you use a meter and solder? If you I can help you fix it. If not you will need to call a repairman. let me know what you would like to do!
Tim Nolan
Sep 13, 2008 | Sony KP-53S65 53" Rear Projection...
Sony KP-43HT20 convergence problem
Replace STK-392-110s or 150s upgrade with 180s replace both ics.
Jan 04, 2008 | Sony KP-43HT20 43" Rear Projection...
Sony KP-43HT20 ghosting effect.
may have bad convergence amps stk392-560 board location Ic8001 Ic8002 or the dcu unit is bad or the alignment drifted off and it needs service adjustments made to it.
Dec 28, 2006 | Sony KP-43HT20 43" Rear Projection...
Panasonic PT-56HX41 56" Rear Projection Television Logo
106 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
