Dishwashers
Problem for Hobart Dishwashers
Generic problem for all Hobart Dishwashers
Hobart AM 14 model pressure rise
By ssac349 on Oct 23, 2009
Hobart AM 14 model. Pressure rises to almost double normal after the sanitizing cycle. Is relieved by opening either a cold or hot water tap in adjacent sink.
Solution #1
posted on Oct 24, 2009
Not Rated)
traboH
Rank: Master
Rating: 94%, 9 votes
Are you refering to the water pressure gauge near the top of the unit?
If so, during the final rinse/sanitize cycle the gauge should read between 15 and 25 psi.( flow pressure ) and is usually controlled by a water pressure regulator piped into your plumbing near the machine. Once the cycle has finished, it's normal to see the gauge register much higher pressure readings ( static pressure ) This is the water pressure being supplied to your building. Pressures of 60psi+ are not uncommon. What, I think, you're describing is normal.
All the best.
Was this helpful?
Yes
No
Popular Solutions for Dishwashers
Questions and Unsolved Problems for Dishwashers
Answer
kitchen aid model number kudco31vbs is it good
Answer
who makes the best trouble free dishwasher today that is 18" wide
Answer
My dishwasher started making a noise like a bearing going out when it began the wash cycle. It is... (More)
Answer
The heat element got moved and melted the inside of the dishwasher causing water to flow out into... (More)
Answer
Rinse/Drying/End lights all are on and the dishwasher stops functioning at this point
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Dishwasher Experts
Top Dishwasher Repairmen
(423) 303-3783
Dishwasher parts delivered overnight nationwide....
 Appliance Parts Pros.com
(800) 470-7119
All the parts that you need for your Dishwasher...
appliancehelp.com
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
