Does not spin
The loader does not spin will not spin
  • flavernes May 23, 2008
    my washer will agitate but it does not spin all of the time. some times it goes for weeks without spinning then one day it spins. sometimes it will spin thru 2 or 3 loads then decides not to. it is aggravating and I am sick of wringing out clothes.
  • Anonymous Apr 28, 2009
    Kenmore front load washing machine works fine, but won't go through the final spin
    President:
  • 1,314 Answers
Check the lid switch
Posted on Dec 30, 2007
Use Top Loader or Front Loader detergents Do you need to dissolve all powders or liquids before washing Can you alter spin time or speed
the use of liquid detergents is recommended over powders in washing machines as they do leave a mud build up over time in the bottom of the wash bowl
no they do have to be dissolved before use
spin speeds are set in the machine program and cannot be altered
spin time is set in the machine program and cannot be altered
use the recommended detergents for the machine because if you use top loader detergent in a front loader it will froth up excessively and cause problems for a front loader machine
the suitability of use for the detergent ( powder or liquid) is clearly marked on the labelling on the bottle or packet
Feb 24, 2015 | Poulan Pro 16-Inch 38 cc Anti-Vibration...
My washer works but it will not work in the spin cycle
Every washing machine, top or front loader, has a safety feature that disables the spin functions and that is the lid switch/lock for top loaders and door switch/lock assembly for front loaders. This is to prevent injury when the lid/door is opened during a high speed spin. Check lid/door switch harness and connections. Replace lid/door switch assembly if no issue found with the harness and connections.
Sep 30, 2010 | Kenmore Washing Machines
My frigidaire fron loader will not spin during wash cycle but will spin when placed on spin
If the drain pump is working correctly and you can get it to spin manually, then the board is faulty. Had the exact same problem with an Lg front loader 40 min. ago.(have to replace the board.)
Jun 14, 2010 | Frigidaire Affinity ATF7000E Front Load...
My machine is not spinning when spin is selected
HI. if this is a belt driven top-loader, or front-loader, more than likely, the belt has slipped off the drive pulley, or the belt has failed. Now, if this is a top loader, with a direct drive assembly. the motor coupler will be the culprit in this case.
Oct 13, 2009 | Washing Machines
The washer runs through entire cycle but when it gets to the spin cycle the motor clicks on but does not spin
Hi there....you havent stated whether its a top loader or a front loader.....top loader 1st.....
usually caused by a defective drive clutch..this will require the drive mechanism to be removed and a relacement clutch fitted
front loader 2nd...this is usually caused by failed spin windings in the motor..worn carbon brushes in the motor.or a failed programmer....
regards Sir Galahad
Aug 16, 2009 | Washing Machines
During spin cycle washer spins fine but toward the end of the cycle it spins out of control like it is out of balance? Any help is greatly welcomed.
Some front loaders have a super high speed at the end of the spin. Front loaders don't like small loads, the laundry does not spread out evenly enough for a balanced spin.
May 08, 2009 | Frigidaire ATF6000ES Front Load Washer
Kenmore elite calypso top loader clothes still wet after spin
more than likely the machine has a bad clutch or motor.. in most cases it is cheaper to just buy another top loader.
Mar 06, 2009 | Kenmore 24032\24036 Top Load Washer
Washer won't drain or spin
top loader ??? or front loader??? if top loader you have broken your lid switch, will fill, agitate, but when it comes to drain/spin for safety reasons if the unit doent recognize the lid closed it will not advance...if yo have a front loader then i would suspect that something has gotten into the pump assy and preventing drainiing of water therefore will not spin
Mar 02, 2009 | Kenmore Washing Machines
Front loader problems
call repair before warranty runs out...possible door switch if it's a loud humming noise ..try pressing in on door latch side to see it hum changes
Sep 06, 2008 | Frigidaire GLTF2940ES Front Load Washer
Washing Machines Logo
383 people viewed this question
Top Washing Machines Experts
Marvin
Marvin
