it is the problem of RAM so just reinsert the Ram then it can be sloved.if it is not clear then you can see u can check internal power cable and reset cable all those things then u can solved
I have a gateway gm5478 model pc with a 22inch lcd gateway fpd2275w monitor(purchased 12/07) for...
(More)
I have a gateway gm5478 model pc with a 22inch lcd gateway fpd2275w monitor(purchased 12/07) for family use and the monitor started giving me the no signal display about 3-4 months ago and has increased in frequency to the point now that I once it happens I can't get it to recognize the computer. Did all the usual fixes reset and powered everything down,disconnected and then reconnected after a couple of minutes.
i have an office jet 6210 and can't get the scanner to work on my computer/printer. downloaded HP...
(More)
i have an office jet 6210 and can't get the scanner to work on my computer/printer. downloaded HP solution center and it says,''no device has been detected'' please help.
my compaq persario 6000 needs to be restored, i have lost the floppy drive needed what can i do. ...
(More)
my compaq persario 6000 needs to be restored, i have lost the floppy drive needed what can i do. I've tried using a repair program but it says the C: partition1 is unknown and cant use this area.
I made a ecovery disk and it loads and then works, at the botom it says examining 19092 and I'm...
(More)
I made a ecovery disk and it loads and then works, at the botom it says examining 19092 and I'm pretty sure it freezes. What should I do?
