Question about Gaggenau VF 230 Deep Fryer
Gaggenu VF 112-610 Deep Fryer
Will not heat up. Got it down to the element. Put 220 directly to the white wires coming off the element and it still does not heat up. Did continuity checks on switches thermostat etc. where can I get a new element? This happened while my wife was cooking. One batch came out done the next phiff
  • 1 Answer has a service link. The site is not really user friendly so enter the model number as VF 112610 and select the parts list. The heating element is listed at 158.00.
Posted on Jun 17, 2008
I just need a handle for the basket in my ultrex
Posted on Jan 02, 2008
How to remove heating element
In order to remove the heating element of a Cuisinart deep fryer you need to do the following:
1. Unplug the fryer.
2. Tip the fryer and put the oil into a container.
3. Put the fryer on its side, with the open top over the sink and a bowl in the sink beneath it. Leave it this way so most of the rest of the oil can drain.
4. Wipe the inside of the fryer with a paper towel.
5. Put several layers of newspaper on the counter and stand the electric deep fryer upside down on top of the paper. You will see that there are rubber feet under the base held in by screws.
6. Remove the feet and screws and you will be able to take off the base to expose the electrical workings inside.
7. Locate the heating element which has wires leading to it. Start by removing the wires leading to it and then loosen up and remove the heating element itself.
May 24, 2015 | Cuisinart Kitchen Appliances - Others
Is the heating element submergable in oil i have just never seen a heating element that is in direct contact with liquid and the paperwork doesnt say. I know that the way its put together it looks like it...
if a heating element is not immersed in a fluid ,it overheats and burns out
if it is designed to be in a fluid ( cooking oil or water as in hot water system) that is where it goes
If you are having doubts , you should not be doing the job so get in a professional to fit it
Nov 16, 2017 | Masterbuilt 20010306 Deep Fryer
I have an old GE deep fat fryer,m/n CK40B, which has no wiring diagram, I am trying to use it for my shop, but can't find any diagrams anywhere on this fryer. It was wired for 3 phase, I am trying to...
If you feed single phase into the line terminals, you will get only 1/3 the heat wattage. To get all heating elements working on single ph, you'll have to separate the common ends of the elements, then connect all 3 in parallel. Keep in mind, doing so will raise your line amperage x3 also. That may put you over the contactor's max rating. Another thing, the contactor will activate on only one sequence of single phase. You may need to move the line to another 2 of the 3 connections.
Feb 02, 2018 | GE Kitchen Appliances - Others
My high temp shut off sensor keeps popping, even though the oil isn't up to temperature. It happens if you put a lot of cold food in the basket or I have fried multiple batches of chips.
Hi there.
Check the sensing bulb of the hi limit device, it may be touching the heating element that's why it trips prematurely especially when you put load on fryer. If this does not correct the problem, your hi limit device may need replacement.
Jul 07, 2011 | Gaggenau VF 332 Deep Fryer
I want to fabricate my own deep fryer. I know how to work on the body, except for the electrical parts
For the electrical parts you will need, a Temperature sensor, a Temperature Control Module, The Elements to be Controlled. probably one or two 1500Watt elements. Heat proof wire (Teflon coated.) Heat proof Connector Blocks.
Jan 29, 2010 | Euro-Pro F1066 Deep Fryer
Deep-fryer thermostat
It is possible that the heater is shortened and it burns thermostat. Thermostat's are usually bimetal type mounted on ceramic so voltage does not matter a much.
Jan 13, 2009 | Kitchen Appliances - Others
Frymaster fryer mj45eusd
If this is an electric fryer you may have a shorted element that will continue to heat when ever the fryer is turned on,even when it is not calling for heat. If it has 3 phase power, the elements could be wired wrong
Sep 08, 2008 | Frymaster Dean Kitchen Appliances - Others
Deep fryer won't turn on
I had the same thing on a Presto deep fryer. I removed that back cover and traced the wires from the AC inlet. One lead goes to a switch that activates when you slide the heater into the case so the heating element will not turn on if it is not in the case. I removed the switch, pushed it in and out a few times, verified that it works with a multimeter, reassembled everything, and "presto", it works. Maybe I was lucky, but it worked for me.
Aug 21, 2008 | Kitchen Appliances - Others
Wiring diagram for wells f-67 deep fryer
OK what I have here is the link directly from wells on this fryer, this is the wiring schematic.
Hope this helps You
please rate me
Feb 09, 2008 | Wells F-67 21167 Deep Fryer
Gaggenau VF 230 Deep Fryer Logo
813 people viewed this question
Top Gaggenau Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Colin Stickland
Colin Stickland
Tom Chichester
Are you a Gaggenau Kitchen Appliances - Other Expert? Answer questions, earn points and help others
