Question about Hobart A200 Stand Mixer
Need cast iron bowl holder assembly for Hobart A-200
Looking for the above part to replace a broken arm.
  • 640 Answers
If your looking for the bowl yoke goto hobartcorp.com or call 18884hobart for the part number and price.
Posted on Dec 31, 2007
I have model A-200-D Hobart mixer. Serial # 1575984. It is leaking oil into the bowl. Who can I call to get an estimate to service or repair this machine?
The oil leeking into your bowl is old grease that has broken down into oil and is getting past your oil seal you need to take out all of your old grease and oil replace it with hi-temp grease or a good grade lithium grease and replace your agitor shaft oil seal
May 16, 2010 | Food Mixers
Hobart A-200 mixer (OLD!) runs hot & shuts down.
You have killed it by overloading the bowl. Hobart recomends no more than 65% bowl capacity on doughs & 75% on batters or icings. Replace the motor or the whole unit
May 25, 2009 | Hobart A200 Stand Mixer
A-200 mixer brush carrier orientation.
Hi. I can't help you with your first question...But I can help with your brushes problem. Unplug the mixer With the two inspection plates removed at the commutator end loosen the two screws of the brush holder which are above and below the motor bearing cover, they're the only larger screws now visible. Note the markings on the brush holder on the bottom right side where you removed the inspection plate. Rotate the brush holder to the other mark. Set the brush holder screws. Plug in the power. and start the motor. It should now be turning in the proper direction, if not, make small adjustments by loosening the set screws, and moving the brushes until it starts to your satisfaction. Be sure that the set screws are tightened when you're done. If you need further assistance, post a clarification.
I have the same spec. mixer as you do.
If this solution has assisted you, please rate it. Good luck! ricardok45
Mar 30, 2009 | Hobart A200 Stand Mixer
Hobart a-200 Removal of Stator Winding Assembly
they are not press fit but be careful they some times rust in the head and are a bit hard to get out. A wooden dowl fwom the front you can tap on it not the windings. Don't paint the inside it will never go back in.
Dec 25, 2008 | Hobart A200 Stand Mixer
A 200 mixer. the bowl lifting lever hits the bowl and guard.
If it hits the bowl its been dumped on the side and bent it. I have done this on sight I get a mapp torch and use a pipe wrench large one and heat it up at the bend where it goes in side and bend it out. or you can buy a new one take the head off four bolts under head and one roll pin inside easy to see and replace arm. The bending is quick and cheap. it will work like new be sure and clean and luber slides wd where it goes in neck.
Dec 23, 2008 | Hobart A200 Stand Mixer
Bought Hobart D300-T at auction
i have another for sale - working 1500,00 cdn
Oct 19, 2008 | Hobart D300 Stand Mixer
Welding bearing girdle for Hobart A200?
yes the cast can be welded(brazed). if you are able to weld this yourself, just remember before you can weld it, you have to heat it till it is cherry red then you can weld the piece. if your not qualified to weld it you can usually find a portable welding company to do this for you. hope this helps you please rate the solution...thanks
Sep 18, 2008 | Hobart A200 Stand Mixer
Mixer has just stopped
On the newer A200s, there is a reed switch behind the solid portion of the bowl gaurd. On the cage portion there is a magnet embedded in a plastic holder. Without it, the mixer won't run.
Hobart part # 438525
http://www.hobartlink.com/extranet/extranetmanualsandcatalogs.nsf/57866D624A678E7385256CB0007232DA/$File/F-19357%20(05-95).pdf
Apr 04, 2008 | Hobart A200 Stand Mixer
Hobart A200 Stand Mixer Logo
97 people viewed this question
Top Hobart Food Mixers Experts
Ross Keen
John Tripp
John Tripp
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Hobart Food Mixer Expert? Answer questions, earn points and help others
