Question about Epson Stylus CX3810 All-In-One InkJet Printer
Epsonstyluscx3810printer my epsonstyluscx3810 does not work/doesnot print the red ink errror light flashes even after i changed the ink cartridge when we tried to print it dont print and sometimes the red light just turn on,i would like to know why?
  • Anonymous Jan 25, 2009
    The red light next to the ink icon is flashing. The printer will not print. Does this mean I am out of ink in one of my cartridges? How do I find out which one?
  • Epson Master
  • 1,879 Answers
Try reseating the ink cartridges
if you still get the red ink error light - call EPSON with the date&place of purchase of the said inks
Posted on Jan 03, 2008
Epson Stylus PHOTO R220 red lights keep flashing
I hope this will help you :)
* Green Power light flashes- The printer is receiving a print job, replacing an ink cartridge, charging ink, or cleaning the print head.
* RED paper light is On- If the CD/DVD try guide is open, close the CD/DVD tray guide, load paper, then press the paper button. Your paper ran out or multiple sheets loaded at the same time . Load paper and press the paper butoon to resume printing.
* RED paper light flashes- Paper is jammed in the printer. Press the paper button to eject the jammed paper. If the light is still flashing , open the cover and remove all paper, including any jammed or torn pieces. Then reload paper and press the paper button to continue printing.
* RED Ink Light Flashes - One or more cartridges are low on ink. Check the message that appears on your screen to determine which cartridge is low, or follow the instructions in " Checking the Ink Supply". Make sure you have a replacement cartridge.
* RED Ink Light is ON- One or more cartridges are out of ink or not installed. If you have just installed a new cartridge, it may be incomaptible with the printer or incorrectly installed. Reinstall it or replace it with the correct cartridge
* RED Ink and RED paper lights flash alternately- The CD/DVD tray guide was left open when you turned on the printer or when printing on paper. Just simply close it/
* Green Power Light is Off; RED paperand RED Ink Lights flashing- Paper may be blocking movement of the print head. Turn off the printer, then open the cover and remove any jammed paper or other foreign objects. Turn the printer back on again. Or it may have an internal error. Turn off the printer, wait a few seconds, then turn it on again.
Jul 06, 2011 | Epson Stylus Photo R220 InkJet Printer
I am having trouble changing the cartridge on the printer. The
im so sorry for the inconvineince that your having on this printer but let me help you.
if :
Red paper.jpg paper and red inkout1.jpg ink light flash alternately and green power.jpg power light is off possible problem: Paper may be blocking movement of the print head. Turn off the printer, then open the cover and remove any jammed paper or other foreign objects. Turn the printer back on again. If the lights are still on, that means the printer is having a hardware issue if: Green power.jpg power light is off; red paper.jpg paper and inkout1.jpg ink lights flash (quickly) possible problem: The printer may have an internal error. Turn off the printer, wait a few seconds, and turn it on again. If the lights are still flashing , that means the printer is having a hardware issue
Feb 10, 2010 | Epson Stylus C88 InkJet Photo Printer
Epson C46, changed coloured ink, won't print flashing red light
If the red light is flashing by itself, it means the printer thinks a cartridge is low on ink. Have a look at what the Status Monitor thinks (right click the printer Icon in the bottom Right-Hand corner and select Ink Monitor). This will show which cartridge it is. If it's the new colour cartridge, it means the cartridge is faulty (then replace it), or it is a refilled cartridge that hasn't had it's chip reset to "full". For this you will need a chip resetter, available on E-Bay very cheaply. If it's the black cartridge then replace it.
If both green and red lights are flashing, it usually means the Waste Ink Pads in your printer are saturated with ink and the waste ink "protection" counter has exceeded its limit. You can restore your printer to a working condition immediately by using the SSC utility - download from:
Install it, and double click the ssc printer icon in the bottom right corner (System Tray). Choose Configuration and set your printer type (C4x), then close the ssc window. Now right click the ssc icon in the sytem tray and choose Protection Counter. You should see that the current count is above the limit; then choose reset to set it to zero. You will need to fib about having changed the waste ink pads! Turn the printer off then back on again. This will stop the lights flashing and restore normal operation.
However, remember that eventually ink will overflow from the waste ink area and make a dreadful mess, so you must change the waste ink pads before this happens. This requires the disassembly of the printer.
If you decide to have a go at replacing the ink pads yourself, report back and I will provide further help. It is a pretty simple job once someone explains how to get the case apart!
Mar 11, 2009 | Epson Stylus C46 InkJet Printer
Red & Green Lights keep flashing on Epson Stylus Photo1280
I had the same problem. You need to reset the waste ink counter:
1. Turn printer off, unplug power cord. Disconnect computor interface cable (back of the printer).
2. After one minute, reattach power cord, but not the computor interface cable.
3 Hold down the LOAD/EJECT and CLEANING buttons simultaneously (cleaning button has ink drop on it) .
4 Turn printer on. Release all buttons as soon as the paper out light flashes.
5 Quickly press the cleaning button, and hold for 10 sec while paper out light flashes.
6 Release the button and the printer will initialize.
7. Once the initialization is complete, turn the printer off.
8. Reconnect the interface cable.
9. Turn the printer on and try to print your document.
This process worked for me. Good luck!
Feb 01, 2009 | Epson Stylus Photo 1280 InkJet Printer
Kodak EasyShare 5100 won't print
I have had the same frustrating problem.
I cntacted the Kodak live web chat help line and after removing the print head,switching the machine off for 1 min and reconnecting.Clean heads and recalibrate.
.....Still the same.
They then told me the print head was faulty and to contact Kodak for free repalcement.
Sep 15, 2008 | Kodak EASYSHARE 5100 All-In-One Printer
I had the same problem and I could not print read. I cleaned, put in new ink etc. Here's the kick.... I ran a nozzle check and noticed that the red and the cyan ink cartridges were reversed! I switched them and it worked fine. I don't know it that is your problem but it blew me away... such a stupid mistake, putting the ink in the wrong places.
Oct 11, 2007 | Epson Office Equipment & Supplies
Margin printing problems
Check your application's print settings (for e.g. MS Word). Then check the printer's properties and print settings. If nothing works you also try re-installing the latest printer driver. If you use MS word should check the page setup option, for paper size errrors. If the color of your margin is red and the red ink is out then you won't se the margin line.
Oct 09, 2007 | HP Color LaserJet 2600n Printer
Open Questions:
See all Epson Stylus CX3810 All-In-One InkJet Printer Questions
Epson Stylus CX3810 All-In-One InkJet Printer Logo
174 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
