Question about JVC AV-56WP74 56" Rear Projection HDTV-Ready Television
JVC projection tv
What is convergence and how do I adjust it?
  • SoonerFan08 Jan 03, 2008
    red shadows, I think the convergence is out, would like to replace, does anyone have the schematics for this tv JVC AV 56WP74? Or what the part numbers are?
    Thanks
    Novelist:
    Champion:
  • 232 Answers
Mike, convergence adjustments are in your menu, usually under "video" settings. You have to adjust red & blue onto the green, when you`ve done it correctly the "cross" will be pure white, if you cannot move either of the colors left, right, & up, down then the convergence IC`s have failed and will have to be replaced, hope this answers your question, BMW Rider
Posted on Dec 30, 2007
How to adjust the convergence on jvc av56wp30 hdtv
Start in the center of the grid and work you way out in circles....do small adjustments....its better to make several passes...Look on the tv repair tips page on www.TvRepairKits.com for more info.
Jan 29, 2013 | Philips Magnavox 9P6034C 60" Rear...
I CANT ADJUST THE RED VERTICAL LINES ON MY JVC REAR PROJECTION TV. i HAVE DONE CONVERGENCE AND MANUALLY ADJUSTED THE RED LINES HORIZONTALLY, BUT NO LUCK WHAT CONTROLS TO USE VERTICALLY
If it will not adjust up or down or left and right the convergence chips need to be replaced.
See attached photos of board that is in your set:
This can be a do it yourself repair and the parts do not cost a fortune.
Can I help?
SD TECH
Oct 16, 2011 | JVC AV-48WP30 48" Rear Projection...
Convergence
Try adjusting the convergence. If it won't move see below- (or hitting Magic Focus for some Hitachi’s) JVC usually have a sperate smaller board for convergence
convergence output IC problem. convergence board would have to be removed - remove and replace 2 STK IC's and check the surrounding resistors. Shops usually charge between $200-$400 Be sure to vote/rate me if this helped Thanks!
See link for more detail
http://www.ehow.com/how_4575598_yourself-projection-tv-repair-convergence.html
Oct 16, 2009 | JVC Televison & Video
I have jvc-56wp30 the color convergience is way off like a 3d picture. it will not converge.
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
This is a very common failure on these projection sets and a fairly simple DIY fix. All projection sets including Samsung, RCA, Sony, Philip Magnavox, Panasonic, Pioneer, Akai, GE, JVC, Toshiba, and others at some point will have the same problem.
Common Symptoms include....
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
  • TV shuts off after powering on. Power light will blink. TV may also make a chirping noise.
Here are some photos of convergence problems.
Here is a quick test....
Using your original remote go-to the settings menu then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move RED and BLUE in all directions - up, down, left, and right. And you should be able to get the grid straight.
If you can't move them in all directions or cant move them far enough your convergence chips are bad and should be replaced. This is a common problem.
Note: If you TV has as flash focus or magic focus button only try pressing the button. If it fails to fix the convergence your need to fix it. See below for a fix
69189a5.pngCONVERGENCE SOLUTION
You can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Sep 24, 2009 | JVC AV-56WP30 56" Rear Projection...
Convergence problem
Did you lock the adjustment into the TV's memory? This step is the most often missed. Please follow the directions on the Users manual or on the service manual on how to set your memory to hold the configuration.
Find the menu item on setting the convergence adjustment into memory (the menu should have an informational screen on this topic)
I hope this helps
Thank you,
Shuttle83
http://www.electron-age-technologies-llc.com
Mar 06, 2009 | JVC AV-56WP74 56" Rear Projection...
Jvc projection tv
try this site http://www.sharefx.net/index.php
Jul 16, 2008 | JVC AV-56WP74 56" Rear Projection...
Remote LOST - need info on what button to press...JVC AV-48WP30
There might be some features that the universal remotes aren't able to do. To perform the convergence alignment you should have the original remote.
Do you have the user manual or service manual?
The service manual will explain this process better.
Apr 10, 2008 | JVC AV-48WP30 48" Rear Projection...
Red Convergence on JVC AV- 65WP74
convergence amp ic bad
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Sony Convergence
http://www.techlore.com/blog/entry/19694/Sony-Convergence-Repair-My-Sony-TV-has-a-distorted-picture-/
http://www.techlore.com/article/19631/Sony-Convergence-Procedure/
Jan 28, 2008 | JVC AV-65WP74 Rear Projection Television
Manually adjusting convergence
convergance amp is might have a loose connection or be bad
Jan 07, 2008 | JVC AV-48WP30 48" Rear Projection...
JVC convergencehas to be adjusted everytime the TV is turned on
You will need to enter servicer mode to do the alignment then
save changes.....info is in service manual........
Does your set have an auto-focus selection ? Try that first...T.
Dec 26, 2007 | JVC AV-48WP30 48" Rear Projection...
JVC AV-56WP74 56" Rear Projection HDTV-Ready Television Logo
85 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
