Check the operation of the water pump--does the motor run slowly? Check the drain port from the outer tub, it may be partially plugged by a sock or other clothing that got into the outer tub by mistake. Look for collapsed, kinked, or damaged hoses to and from the pump. This is a timed event, so rapid removal of the water is important.
Was this helpful?
Yes
No
Popular Solutions for Kenmore 23822 Top Load Washer
washer will not spin, or drain. bypassed lid switch with jumper wire and still will not do either....
(More)
washer will not spin, or drain. bypassed lid switch with jumper wire and still will not do either. took pump off and there is no blockage. what is next thing to look for?
washer does not start. filled up with water but then stopped. Attempted to unplug and plug. still...
(More)
washer does not start. filled up with water but then stopped. Attempted to unplug and plug. still did not start. Have taken clothes out but water is still in there.
